Almost Finished 94 D90 Complete Rebuild w/LS2 engine swap - Page 6 - Defender Source
Old August 18th, 2014, 06:13 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Originally Posted by LRNAD90 View Post
I've never really considered myself a 'purist', but that looks like any number of J**P projects from underneath, with a Defender Body on top. I also wonder how much front axle articulation there could actually be. It doesn't look like much room for that front drive shaft to move within that opening in the new cross member..
Not my taste, but someone put alot of work into it. In the end, I have to wonder, how better does it actually work, than a mildly modified Defender..
Originally Posted by cgalpin View Post
Yeah the room for the driveshaft looks iffy, but more importantly I don't like the fact they welded in that rear crossmember!
FYI this isnt the "let's shit on the linked truck" thread, it is the actual build thread... go back and do a little reading, there are lots of details.
I didn't build the suspension, it was done by Jordan @ Rovertym before he moved out to Montana, but IIRC from my time under this truck, there was plenty of clearance for the front shaft. That camera angle may be showing it poorly.
Also IIRC the rear chassis xmember isn't the thin factory type, its a whole new piece of pipe, and welded in for the benefit of the additional chassis strength. It's just a 500hp (oops I mean "over 400" ) hot rod truck with a part time case wearing a D90 suit. Some strength was in order.
Old August 18th, 2014, 08:10 PM
Sorry, wasn't meaning to shit on his thread and should have looked back. I can remove my post if you'd like. I'd personally just prefer something bolt in so it can be altered more easily if so desired.
Originally Posted by pendy
I'm here for the D's
Old August 18th, 2014, 08:19 PM
crown14's Avatar
crown14
Verticalscrote
Charles it wasn't you taking the poop
90, d90, engine, rebuild
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
94 D90 stalling when load put on the engine makof-16 Defender Technical Discussions 7 May 31st, 2007 08:23 AM
1994 D90 Yellow ST for rebuild project chrisvonc For Sale - Vehicles 1 April 17th, 2006 10:33 AM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
94' D90 ST, 55k miles LOWERED to 21.7k or BEST OFFER in CT. PIX link januconn92 For Sale - Vehicles 1 March 15th, 2004 09:46 PM
