Alaska D110 Build for expo use - Page 8 - Defender Source
Old May 15th, 2014, 03:45 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Looks great. You might have already mentioned this but what shocks and what valving are you running?
Old August 1st, 2014, 08:04 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Sorry for the late reply , my shocks are fox 2.0 . The valving on the rear is 60/90 and the fronts are 45/90 with flutter valves .
Rear is a little soft.
85 D110 3.5 3 DR
Old August 1st, 2014, 08:07 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Here is a few more pics of the 110 . She has been handling the work load well . She just towed a new to me NAS 90 home .
85 D110 3.5 3 DR
Old August 1st, 2014, 08:13 PM
that's catalog material...awesome photographs.
btw are you running rovertym front springs or are you using high-rate rear springs in the front, ala OME 2781 (290 lb/in) or 300-340 lb/in progressives?
Old August 1st, 2014, 08:19 PM
aka rover's Avatar
aka rover
ed angel
95 D90
This rig has spent a lot of time the last few weeks getting a work out . Rock sliders and cage have proved to be a savior on several occasions . I'm really enjoying this build and find myself wanting to drive it instead of the 90 .
Next item on the list is rear corner protection , I think I'll Fab up something that matches the sliders .
85 D110 3.5 3 DR
Old August 1st, 2014, 08:22 PM
aka rover's Avatar
aka rover
ed angel
95 D90
that's catalog material...awesome photographs. btw are you running rovertym front springs or are you using high-rate rear springs in the front, ala OME 2781 (290 lb/in) or 300-340 lb/in progressives?
Running Rovertym 300-340 in the front . The tires in the pics are 37" BFGs .
iPhone pics , but the real pics will be on a catalog :-)
85 D110 3.5 3 DR
Old August 1st, 2014, 08:37 PM
you are still my damn hero!
Mark Kellgren
KM4BOR
Old August 2nd, 2014, 01:34 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Haha, I don't deserve that kind of credit , but thanks for remembering .
Cheers Ed
85 D110 3.5 3 DR
Old August 2nd, 2014, 01:38 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Another pic why I build my trucks this way , 5" 37" tires. . That's a deep hole .
85 D110 3.5 3 DR
Old August 2nd, 2014, 07:52 AM
Why am I moving to New York? I need to live in Alaska.
Old August 2nd, 2014, 09:48 AM
We offer simulations of the weather in winter ...
Old August 2nd, 2014, 11:05 AM
the rover shop
shayne young
Yeah.. But you have the same amount of people per square inch as Alaska does per square mile...
Old August 2nd, 2014, 11:50 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I am serious jealous of all the pics of this build in action. Color, stance, exterior cage, amount of protection is all just right.
How does the 4.2 so moving the 37's? I was hoping my Om617 would be able to turn 35's but from reading it seems the 255's will be the max and I will have to keep it on a strict diet.
Also how is the Detroit on road? You probably ride a lot of dirt roads up there and it must be nice going off road and just having things locked.
Real nice build and even more so I love see it getting used for how it was built!
Old August 4th, 2014, 05:09 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Originally Posted by don View Post
I am serious jealous of all the pics of this build in action. Color, stance, exterior cage, amount of protection is all just right. How does the 4.2 so moving the 37's? I was hoping my Om617 would be able to turn 35's but from reading it seems the 255's will be the max and I will have to keep it on a strict diet. Also how is the Detroit on road? You probably ride a lot of dirt roads up there and it must be nice going off road and just having things locked. Real nice build and even more so I love see it getting used for how it was built!
The 4.2 moves this brick around just fine , we have a stock 94 90 and they feel about the same as far as power goes . With the 1.67 transfer case it's almost to low with the 35 s.
I would stick with the 255s on your OM617 that's what I run on mine and that's about all that motor will pull , and that's with 4.70 gears a T176 and OD.
The detroit is just fine for everything but tight turns into parking lots , at times you get a bit of surging . But other than that with the wheel base I really don't know it's back there .
There is a the slop the Detroit has that makes the drivetrain feel clunky if you aren't used to it . So there is some Cons to running this setup , but I don't plan on changing it .
Thanks for the props we love the truck and plan on using it all over Alaska .
85 D110 3.5 3 DR
Old August 19th, 2014, 03:31 AM
aka rover's Avatar
aka rover
ed angel
95 D90
A few more pics of the 110 in action . Click image for larger version
ID:	101184 Click image for larger version
85 D110 3.5 3 DR
Old August 19th, 2014, 06:53 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Wow! Those AK mountains make a great backdrop. Seriously cool pics.
Thanks for the feedback in the prior post. It's great to hear what works on a build.
Old August 27th, 2014, 12:41 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks Don
I'm digging your build.
85 D110 3.5 3 DR
Old August 28th, 2014, 02:41 AM
ROVER-1's Avatar
ROVER-1
Jason Beard
1984 D90
I'll add to the pics. Handled the splash downs well.
'84 D90 300TDI RHD
'69 Series lla
Old August 28th, 2014, 09:35 PM
aka rover's Avatar
aka rover
ed angel
95 D90
You should post up some pics of your rig .. It's looks great .
85 D110 3.5 3 DR
Old August 29th, 2014, 04:44 PM
ROVER-1's Avatar
ROVER-1
Jason Beard
1984 D90
Nothing special. Click image for larger version
ID:	101807 Just an Alaskan D90.
'84 D90 300TDI RHD
'69 Series lla
110, d110
RiverHouse 1985 D110 Build Stormer Truck Build-up's & Restores 20 March 24th, 2012 12:22 PM
Project D110 hi-cap Shane@EVS Misc. Chit-Chat 9 February 26th, 2006 10:05 PM
Land Rover Anckorage Alaska Dealership T-shirt jack frisch For Sale - Parts 2 February 25th, 2005 09:18 AM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
