Alaska D110 Build for expo use - Page 6 - Defender Source
Old April 14th, 2014, 01:53 PM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
+1
Love the sliders !
Great stuff ! ! !
Originally Posted by aka rover View Post
Thanks I'll get better pics , but this is pics of them mocked up . They bolt in to the out rigger like most do , but I wanted more side protection so I tied into the radius arm mounts . It also bolts into the rear out rigger .
__________________________________________________
shoefnik wrote: "It’s funny how that moral line you draw for modifying your Rover changes as your needs change."
Old April 14th, 2014, 05:27 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Those sliders x2!
Can't wait to see how this shapes up. Seems like it will be a hardtop version of my truck - 3 door, 35's, Rockware bumper and maybe a couple of other items.
Old April 16th, 2014, 04:00 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks guys for all the compliments , Don sounds like our trucks will be very close indeed . You must have a very nice Rig ! :-) . Here's a few pics of the front light bar I bent up for the front Rockware .
Took some time to get my angles just right ! I'm a bit rusty, but got them spot on !
More to come shortly .
85 D110 3.5 3 DR
Old April 16th, 2014, 04:17 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Built the ARB for the front but can't remember when as the nights are starting to blend .
Case painted
Hole Taped
Bulkhead fitting installed
Heating ring gear for install
Torqued to spec
Backlash set to previous checked of 8 thou.
Air line ran and double checked for fitment in housing .
Installed in housing
85 D110 3.5 3 DR
Old April 16th, 2014, 05:31 AM
Alaskantinbender's Avatar
Alaskantinbender
jim
63 series 2A 109 3 door
Very nice fab work, one would think you have done it before......
Attachment 93158
Attachment 93159
Attachment 93160
Attachment 93161
Old April 16th, 2014, 06:56 AM
Great build. Looking good!
Mark Kellgren
KM4BOR
Old April 16th, 2014, 07:46 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
beautiful stuff!
Old April 20th, 2014, 04:35 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks guys
It's sitting on rubber now , have lights to see Moose a mile down the road on the dark Alaska "winter" nights . Winch installed , but die to time had to bolt on a lay down HS9500 warn I had laying around Soooo the 8274 stays here till I return from the states and can put it on .
85 D110 3.5 3 DR
Old April 23rd, 2014, 05:27 AM
aka rover's Avatar
aka rover
ed angel
95 D90
VDO gauges with red bulbs for that battle ship feel
85 D110 3.5 3 DR
Old April 23rd, 2014, 05:29 AM
aka rover's Avatar
aka rover
ed angel
95 D90
KC LED Dot head lights . These things will be great with our long Alaska winters .
85 D110 3.5 3 DR
Old April 23rd, 2014, 05:31 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Rear KC floods flush mounts , very nice spread of light with low amp draws .
85 D110 3.5 3 DR
Old April 23rd, 2014, 05:36 AM
aka rover's Avatar
aka rover
ed angel
95 D90
The Benz powered 109 getting a valve adjust for the trip to EXPO. A good friend of mine will be driving this one south . The 110 is getting closer here's a poser shot :-) .
85 D110 3.5 3 DR
Old April 23rd, 2014, 07:11 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Like the head lights. Where did you get them? How much?
Legend in My Own Mind.
Old April 23rd, 2014, 09:38 PM
aka rover's Avatar
aka rover
ed angel
95 D90
They are 430.00 a pair and I sell them , this is my first set in stock I will let you know how they work. the part number is a jeep JK number KC 42321 but you just delete the pig tail and they have a standard 3 wire hook up.
85 D110 3.5 3 DR
Old April 23rd, 2014, 10:10 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Concerns with LED not melting out snow accumulation? Modern vehicles running LED have heated headlight washer options to combat the last of heat buildup for snow removal on the lens.
Old April 24th, 2014, 02:32 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Agreed on the snow melt , a couple of the JK jeep guys have had good results in the winter months up here . But then again the last few winters have been very mild . I will report back in say 6 MONTHS :-) .
85 D110 3.5 3 DR
Old April 24th, 2014, 07:26 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Hearted washer tanks are not crazy expensive, I think the KC lights aesthetically look a little nicer than trucklites (though very similar overall)
Really digging the red gauges and the flush mount floods in the back. Digging this truck!
Old April 24th, 2014, 08:47 AM
tommyd's Avatar
tommyd
Tom
LR3
Very nice. I still want your 109.
Old April 24th, 2014, 09:12 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Pretty sure I saw a discussion on this on another forum, in which there was a reply from Trucklights. If I remember how it went correctly, Trucklight claims that the LED headlamp still produces a significant amount of heat, but that the enclosure is designed to vent this heat to the rear. So not helpful for snow melt, but interesting that they indicate the lamp produces significant heat.
Trucklights argument, however, is that by not heating up, snow is less likely to stick to the lenses, so let us know! LOL!
~Scott T.
'95 D-90 ST - AA Yellow
Old April 25th, 2014, 06:25 AM
Alaskantinbender
jim
Awesome trucks, great work.
Attachment 93462
Attachment 93463
110, d110
RiverHouse 1985 D110 Build Stormer Truck Build-up's & Restores 20 March 24th, 2012 12:22 PM
Project D110 hi-cap Shane@EVS Misc. Chit-Chat 9 February 26th, 2006 10:05 PM
Land Rover Anckorage Alaska Dealership T-shirt jack frisch For Sale - Parts 2 February 25th, 2005 09:18 AM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
