Alaska D110 Build for expo use - Page 4 - Defender Source
Old March 6th, 2014, 05:14 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Ash View Post
I'm sure it helps stabilize the truck just like any swaybar would, but I can't understand why you'd want to hang all of that equipment below your fuel tank when an Anti-Rock can be tucked 100% out of harms way on the top side of your chassis. Just because the components are above your axle doesn't mean you're not compromising ground clearance. Looks awfully obtrusive to me.
Look at the departure angle from the base of the rear tire to the bass of the rear crossmember. The X-Deflex doesn't encroach. The only way you'd hit it is if you dropped your ass on a boulder. That's a poor picture too. You can actually mount it to the fuel tank skid and tuck it up there rear tight.
ID:	90802   Click image for larger version
Semper Fi!
Old March 6th, 2014, 10:01 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That doesn't look bad in the pics. But why does the one side have such a curved bracket? Can you order with 2 straight brackets and then route the exhaust or whatever to work with it?
Old March 6th, 2014, 05:59 PM
Wolf Fabrication
Sterling Archer
'08 D3
The curved bracket is for the stock exhaust. I am sure that if you emailed Si at X-Eng he'd supply two straight brackets. FYI, X-Eng has great customer service. When a bolt worked loose and I lost a part to it on the trail he sent me a new one free of charge.
Semper Fi!
Old March 6th, 2014, 06:19 PM
Landy_Andy's Avatar
Landy_Andy
Andy
You have to remember that this product is made/sold mostly for the UK market, Currie gear is not generally available and installing Anti-Rock isn't just 'bolt-on'.... a significant proportion of UK LR owners can't or simply don't have the time/equipment to make & build their own stuff. Add to that the complete lack of 'extreme' terrain that's open to wheel'in in the UK and Si's kit becomes a great option for a fair price.
BTW, Si's not selling direct now..... he moved that to Foundry 4x4 so he can concentrate on new product design.
Linky http://foundry4x4.co.uk/index.php?ro...tegory&path=65
Old March 6th, 2014, 09:36 PM
Wolf Fabrication
Sterling Archer
'08 D3
Or buy direct through Lucky8 here in the US.
Semper Fi!
Old March 6th, 2014, 09:55 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Is this the one you had on the 110?
Ah never mind just read the whole thread...
Old March 8th, 2014, 10:46 AM
oilburner's Avatar
oilburner
JL
large pile of parts
Originally Posted by aka rover View Post
I have a 94 disco in the shop that we are parting out that has a serpentine belt setup. Was wondering is there any down side to swapping all the components over to the this set up . Is the PS pump as good as the 3.5 . I like the alt up high for sure and the space to run a AC type air pump . Looks like I can just take timing cover and all brackets and be good to go.
Thanks Ed
Hey Ed,
I know that the crank on the serpentine belt engines has a longer snout, so you need a spacer going from serp to V belt, but I think you can do it the other way without too much trouble. The only issue might be that the crank is a little short inside the damper, then again, you could always have someone alter the damper or just run a spacer on the crank end.
I think for water crossings serp belt is the way to go, and the alt up high is a good idea, I say why not.
JL
Old March 8th, 2014, 11:15 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks for the info Wolf. I am now torn between fabricating stuff to make Bucks arms work or just pony up for an X-Eng. But to be honest I am a long way out from either way.
Old March 8th, 2014, 04:33 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Originally Posted by oilburner View Post
Hey Ed,
Hey thanks for the response , I measured the snout on the two motors and and they appear to the same ? . Mark at D&D said that since both motors where 94s there might be a chance they are the same. It looks like I got lucky on this and will be able to simply swap over the early SERP stuff . It looks like the early 94-95 discos with CUX 14 might run the shorter cranks ? A few years ago I put a 95 disco motor in my daughters 92 RRC and used all her stock components with no issues . Ill post up my findings after my D&D cam lifters and timing set get here.
85 D110 3.5 3 DR
Old March 8th, 2014, 05:02 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Liking it Wolf.
Legend in My Own Mind.
Old March 8th, 2014, 07:50 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Excellent, if they are the same I think it will work out. I remember there being a difference but it might be only certain years, I am definitely no expert when it comes to rover V8s...
JL
Old March 10th, 2014, 06:27 PM
Wolf Fabrication
Sterling Archer
'08 D3
I just ordered another X-Deflex from Lucky8. Justin does have a few in stock. I also asked to see if he can supply another straight arm vice the curved arm for the exhaust.
Semper Fi!
Old March 10th, 2014, 08:51 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks Johnathan
I'm still on the fence with Currie or x-deflex , with time not in my favor and Justin having them in stock it might be the route I take.
85 D110 3.5 3 DR
Old March 12th, 2014, 06:03 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Not a lot to show on this build except some tear down . Look at that tail shaft !! . Just put my order in with Ashcroft for trans and Tcase rebuild parts . Also worked on the wiring tonight as well , anybody done a CUX14 conversion and not use a VSS ? Ed
ID:	91132 Click image for larger version
ID:	91133 Click image for larger version
85 D110 3.5 3 DR
Old March 12th, 2014, 06:14 AM
aka rover's Avatar
aka rover
ed angel
95 D90
This is the cage I decided on , it should be here in another few weeks . It just got out of powder coating and is being loaded on the ship out way .
85 D110 3.5 3 DR
Old March 12th, 2014, 06:26 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Did some floor work , rather than buying new floors I decided to cut out the rust and fab up some replacements ,
Now some grinding and welding I'll have a place to put my feet .
85 D110 3.5 3 DR
Old March 16th, 2014, 04:28 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Transmission rebuilt thanks to Ashcroft , the Santana LT85 is ready for action
85 D110 3.5 3 DR
Old March 16th, 2014, 07:42 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
That is a beast
Old March 17th, 2014, 12:59 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Originally Posted by TDI Guy View Post
That is a beast
Yea not as easy to move around as my R380s .
85 D110 3.5 3 DR
Old March 17th, 2014, 01:48 PM
Look at those bearings! Makes my LT77 bearings look like puny little things...
110, d110
RiverHouse 1985 D110 Build Stormer Truck Build-up's & Restores 20 March 24th, 2012 12:22 PM
Project D110 hi-cap Shane@EVS Misc. Chit-Chat 9 February 26th, 2006 10:05 PM
Land Rover Anckorage Alaska Dealership T-shirt jack frisch For Sale - Parts 2 February 25th, 2005 09:18 AM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
