Alaska D110 Build for expo use - Page 2 - Defender Source
Old February 19th, 2014, 03:11 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Nice can you get pics of the rear shock setup ? Sounds like a nice setup.
85 D110 3.5 3 DR
Old February 19th, 2014, 04:29 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Here are some extremely random pics. The first 5 were sent to me from Qt and show the various parts. The last one is my cobbled together suspension:
Rear: Qt heim jointed rear links and shock relocation brackets. 3" TF HD springs (I actually LOVE these springs and prefer them). Qt heim jointed A Arm bracket. COR4 2" spring spacers/relocation ramps.
Front: Qt shock relocation brackets to move shocks outside the springs. Qt castor corrected arms. L8 5" springs.
Shocks will be FOX remote reservoir 12" or 14". I won't decide until the truck is complete and leveled out.
Hopefully I'll have some pics of this stuff on the rolling chassis in the next few days.
ID:	89982   Click image for larger version
ID:	89984   Click image for larger version
ID:	89986   Click image for larger version
Semper Fi!
Old February 19th, 2014, 05:19 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Interesting. Have you come up with any valving numbers yet? With the shocks so far inboard and at those angles I'd expect to have to run them a fair bit stiffer than a traditional setup.
Geared Restoration Co.
352-572-3236
Old February 19th, 2014, 05:36 PM
Wolf Fabrication
Sterling Archer
'08 D3
Not yet, but I prefer a stiffer ride [insert joke here]
Semper Fi!
Old February 19th, 2014, 06:03 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks for posting up the pics, the new angle isn't all that different than a lot of US trucks . I to prefer a stiffer ride , the truck seems more predictable as speeds with a firmer suspension. My current shocks on my 90 are 400/100 and I love how they feel at speed .
85 D110 3.5 3 DR
Old February 19th, 2014, 06:22 PM
Ash's Avatar
Ash
Ash Heller
Cool, I'm interested to see how that ends up working. I've been toying around with a few non-traditional ideas myself to combat the poor ride quality and body roll inherent with a lot of these setups.
352-572-3236
Old February 19th, 2014, 07:00 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
What springs are you referring to as TF 3"? Do you mean the HD 2"?
Old February 19th, 2014, 07:07 PM
Wolf Fabrication
Sterling Archer
'08 D3
You are correct, TerraFirma 2". The HD ones seem to give a bit more lift depending on the weight of your truck.
------ Follow up post added February 20th, 2014 09:09 AM ------
I fought body roll for a long time in my 110. I cured it with stiffer springs (TF), better shock valving, and a X-Eng rear X-Dflex sway bar. The truck took sharp exit ramps off the highway like NASCAR.
Semper Fi!
Old February 19th, 2014, 08:42 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Wolf, I can't wait to see this stuff installed
Legend in My Own Mind.
Old February 19th, 2014, 09:26 PM
Wolf Fabrication
Sterling Archer
'08 D3
Me too, any day now.
Semper Fi!
Old February 19th, 2014, 10:19 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
[QUOTE="Wolf Fabrication;509117"]
Do they sell these separately from their kits? If so, where did you get them? I've been wanting to get a set of these for awhile...
Old February 20th, 2014, 01:36 AM
Wolf Fabrication
Sterling Archer
'08 D3
Yes. Call L8
Semper Fi!
Old February 20th, 2014, 01:53 PM
aka rover's Avatar
aka rover
ed angel
95 D90
The 3.5 is out . Now to clean and prep for the 4.2 .
85 D110 3.5 3 DR
Old February 20th, 2014, 02:23 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Help me understand, guys: what's up with the enthusiasm for 35" tires and 5" lifts for an "expedition" truck? That's a huge, huge setup for a Defender. That's how you'd set your truck up for rock crawling at the off-road park. Add a RTT on the roof and a bunch of heavy Pelican cases in the back and you're dangerously top-heavy. For long distance overlanding, you generally want to shoot for something that's as close to stock as you can get and super-reliable. Super-reliable to me means:
No dual cardan driveshafts. They always blow up at the worst of times, usually on a long trip and in the worst circumstances:
Super-reliable also means spare suspension components that I can share with every other truck in my group:
I think it's a myth that you need an incredibly built truck to do an "expedition". I ran our last Utah trip in my completely stock 110: 7.50 XZLs, no lift, no lockers, crusty old MOD-spec shocks. 1,200 miles mostly off-road in Southern Utah and the truck did fine. I was rolling with a bunch of Discos with 3"+ lifts, HD axles, fully locked, etc., but we never once ran into anything that I couldn't make it through with careful driving. The stock Defender is an amazing 4WD vehicle!
Can someone explain the whole 5" lift + RTT + trailer thing to me?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old February 20th, 2014, 02:43 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Your correct you don't need a large built rig for Expo type over landing. But the places I see in Alaska and the type of back country I'm looking at visiting 33" tires just don't cut it . My D90 is but on 5" lift and 37" tires and drives great at freeway speeds . But I want to go out longer and into the woods deeper . I won't have a RTT I will be sleeping in the back ,away from the brown bears :-) . So my current build is going to be able to handle the places I want to go with the ability to cruise at 65 to get there .
Yes this build is a little different than the cookie cutter expo builds but it will be self sufficient and take me where I want to go . As far as CV joints go I have never broke one ? And I have traveled around Australia and through the Rainforest's of Malaysia with them in some pretty extreme situations . If your suspension is set up right you'll be fine with them . Yes I know more moving parts means more to break .
Here's my D90 most of you will hate it but it's purpose built for this area . It's on 37s .
And here's a poor pic of my old jeep on 36" tires crossing one of about 20 crossings to get to some of my favorite remote areas Alaska has to offer .
So that's my .02 on big Goofy Rigs :-)
85 D110 3.5 3 DR
Old February 20th, 2014, 03:41 PM
Those look good for the terrain your in. Those are tiny compared to the rubber they put on arctic trucks. For purpose built, there is no such thing as lame. It's the posers that put big tires on their trucks for the looks, with no intention of using them in the correct environment that will attract disdain.
Mark Kellgren
KM4BOR
Old February 20th, 2014, 04:19 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I personally take offense to that remark...(hater)...
------ Follow up post added February 20th, 2014 03:22 PM ------
It's the resolve of the man and the machine that finishes the expedition!
Old February 20th, 2014, 04:23 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
That you are correct, they are a taller lift than the RTE 3" MD
Old February 20th, 2014, 04:55 PM
Wolf Fabrication
Sterling Archer
'08 D3
Nevermind
Semper Fi!
Old February 20th, 2014, 06:52 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
I think the key here is the word "expedition" as to each its something different that requires a completely different setup.
Defender 110
110, d110
RiverHouse 1985 D110 Build Stormer Truck Build-up's & Restores 20 March 24th, 2012 12:22 PM
Project D110 hi-cap Shane@EVS Misc. Chit-Chat 9 February 26th, 2006 10:05 PM
Land Rover Anckorage Alaska Dealership T-shirt jack frisch For Sale - Parts 2 February 25th, 2005 09:18 AM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
