A cautionary Tale :welding under the vehicle: fire - Defender Source
Old September 16th, 2017, 09:38 PM
caj13
Carl
D-90 SW # 434
so this does not involve my 110, but it could have, and it muight be of value to you DIY guys
so I am welding sheet metal patches on the holes on my 72 Porche 914 (volkswagon in disguise) I started thinking I had 6 holes, now I'm at 12, and will be rebuilding the bottom back 1/4th of the tunnel before I'm done with thew welding.
Car is up on the lift, I'm welding between the rear of the pan, and the bottom of the firewall - Ironic , as it turned out.
So my left shoulder is getting hot - that seems odd. I stop welding, and there seems to be more smoke than normal. Luckily, since i had already cut out the bottom of the tunnel, I happen to see flames inside the cabin - weird, I have it stripped, and just got done painting it.
so now : shut down the welder, move it from under the lift, lift the lift a few inches, that allows me to pull the safety catch cables, then finally lower it down till I can see inside. full blown campfire on the floor.
Turns out I had left a nylon bag fiull of my rags inside, as well as a roll of masking paper and they were fully engulfed. Threw on the welding blanket, shut it down pretty quick, but it shook me up a bit. I guess I'm done for the night.
Be carefull out there guys!
Old September 16th, 2017, 10:56 PM
The Dro
Dro
1988 Ninety
Dam... glad to see you're fine and no major damage was done
Old September 16th, 2017, 11:38 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I knew a guy who was either welding or using a blow torch to strip undercoating from under the nose of a Porsche 911 without removing the fuel tank first. Since he didn't survive we're not sure exactly what he was doing at the time of the explosion....
Old September 17th, 2017, 09:47 AM
glad you're ok! I've been there. Small paper fires, no gasoline, thankfully.
fire
Series III Lightweight - Restored jac04 For Sale - Vehicles 12 April 16th, 2014 01:26 PM
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
Coil sprung series vehicle w/ diesel engine geneseemtn Misc. Chit-Chat 19 February 26th, 2006 09:52 PM
Wanted to Trade Disco or SE Tow Vehicle racerbvd Wanted 0 February 19th, 2006 02:28 PM
Can anybody do a Vin Check for me? Quimbola Misc. Chit-Chat 7 February 18th, 2004 06:24 PM
