97 SW getting a few upgrades - Page 8 - Defender Source
Old December 10th, 2009, 10:52 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
light wiring
Joel...(post 109)...any tips for running the wires through the roll cage and drilling into the mount under the cage/and through the firewall? Did you mount relays under the hood or drivers seat...additional pics would be awesome. Been planning this for a while...just haven't got around to it. thanks j
Old December 11th, 2009, 09:57 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
There are plenty of holes in the firewall already, I will try and find a pic of what I used. Relays are mounted on the firewall behind the air cleaner. I drilled holes to pass the wire through in the roll bar prior to it going out for sandblasting and powdercoating. The hole in the mount in the fender was drilled to match so the wires wouldnt get pinched. Kinda tricky but hiding the power/ground inside is a nice touch I think.
Old December 11th, 2009, 10:10 AM
KKilo23's Avatar
KKilo23
Kenny
Looking good..
Old December 12th, 2009, 06:56 PM
crown14's Avatar
crown14
Verticalscrote
Got the swing out spare tire carrier mounted today, mounted and wired the modified X-lite on it and finished up the rear door.
Old December 12th, 2009, 07:23 PM
Which one did you end up using?
Old December 12th, 2009, 07:57 PM
crown14's Avatar
crown14
Verticalscrote
The Bearmach one
Honestly the drilling through the body part wasn't so bad. But if you arent careful installing it, you could end up with a bunch of really ugly holes all over the place. I spent at least 6 hours on it just making sure it was right.
Old December 13th, 2009, 10:25 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Joel...what gauge wires did you run for your lights? thanks j
Old December 13th, 2009, 11:50 AM
crown14's Avatar
crown14
Verticalscrote
14 guage wire
Old December 13th, 2009, 11:48 PM
crown14's Avatar
crown14
Verticalscrote
more pictures- showing where wiring passes through bulkhead for dash switches, spare tire carrier plus rear floodlamp, etc
also assembled but uncleaned and VERY dusty interior shots
more from todays work on the way... soon (hopefully)
TODAY I cleaned up the whole interior, trimmed and installed the new front rubber mats, replaced the front seat shoulder belts (worn a little from being closed in the door?), and spent a good while fine tuning the adjustments for the hood (bonnet) so that the wing top protectors (Equipe) can be installed...
also drilled the hole for the antenna and since the powdercoat/adonizing (whatever) on the wing protectors didnt match closely enough they are going to my powdercoater ASAP... meaning I had to smooth out some rough spots first.
Is anyone else running wingtop protection from Equip? How do they fit?
ID:	23679   Click image for larger version
ID:	23681   Click image for larger version
ID:	23683   Click image for larger version
ID:	23685   Click image for larger version
ID:	23687   Click image for larger version
ID:	23689   Click image for larger version
Old December 14th, 2009, 05:37 AM
whats the deal with the console?
Old December 14th, 2009, 07:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
How do you like those seats Joel?
Legend in My Own Mind.
Old December 14th, 2009, 08:02 AM
deslandes's Avatar
deslandes
Deslandes stéphane
1998/Defender 90 300Tdi
Really fanstatic looking ninety, have you already take pictures with LTB-08? (Can you please give me exact dimensions of these?)
Regards
desLANDes is my real Name... I can't own anything else and I'm happy with... I'm french, so excuse me if sometimes you don't understand xhat I mean and reverse...
My 90Tdi :
Old December 14th, 2009, 08:54 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
another stupid ?
Joel....are those black AL/anodized door hinges...or did you paint them? If you painted..do you know what color code you used? thanks for all the responses!!!
i've got those heated seats as well...not super warm but definitely helps in the cold weather!!!
Old December 14th, 2009, 10:09 AM
crown14's Avatar
crown14
Verticalscrote
Post #141, top of this page
The tilt mechanism feels flimsy, they are a little too wide and contact the roll bar when slid all the way back (look close at the roll bar pads), the frames seem to be a little off square making them hard to slide at times, they are actually somewhere between dark grey and black, and the leather does not feel like leather. They are on Mud UK seat rails though so that's why they hit the roll bar. Just my opinion here. Knowing what I know now I would have rather kept the original seats and used an Exmoor retrim kit instead. The seatback tilt thing is the nail in the coffin for me, I hate that feeling.
Regards
Sorry, what is an LTB-08? These pictures are from last night, the truck is pretty much as you see it here.
These are the black alloy hinges from AB, I did not paint them but they match the powdercoat really well. The seats we used aren't heated, I understand that was an option but its going to live at the beach, really a summertime vehicle.
Old December 14th, 2009, 10:17 AM
deslandes's Avatar
deslandes
Deslandes stéphane
Sorry, I was talking about 285/75-16 SSR as I want to buy this one, I'm just trying to find pictures of a ninety with those tires.... Can you do it for me?
"Page 1 : Follow-up Post:
now the fun part, I won't be too descriptive (this way you can have more fun looking at the pics)
new tires (285/75-16 SSR, measure out to 33.9)"
My 90Tdi :
Old December 14th, 2009, 10:24 AM
crown14's Avatar
crown14
Verticalscrote
Don't worry, as soon as those tires/wheels get installed D90 Source gets the first update complete with pics!
Old December 14th, 2009, 07:46 PM
marcingham
Marc Ingham
1967 IIA 88
sliders
Joel - are those rocksliders I see there?
Old December 14th, 2009, 08:40 PM
crown14's Avatar
crown14
Verticalscrote
Cool
yes... But.
Hate typing on phone
yes.
Old December 16th, 2009, 12:19 AM
specops1526's Avatar
specops1526
Beluga '97 90
Is that a naked chick on your iPhone?
http://www.defendersource.com/forum/...chmentid=23684
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old December 16th, 2009, 09:08 AM
ROFL. I'm surprised you didn't warn him there was someone hiding behind the truck!
Speaker placement - '97 D-90 SW owners Chaucer Defender Technical Discussions 4 October 4th, 2010 02:44 PM
1997 SW side doors, top and rear door avail, and more from 97 LE wicks For Sale - Parts 21 April 28th, 2010 02:53 PM
97 D90 SW stuck in reverse. woldd90 Defender Technical Discussions 9 September 9th, 2009 09:56 AM
97 SW doors for sale kevorkjan For Sale - Parts 2 May 11th, 2009 10:05 AM
Looking to swap 95 ST for 95 / 97 SW unit3a Wanted 0 November 28th, 2008 12:55 PM
