97 SW getting a few upgrades - Page 11 - Defender Source
Old January 2nd, 2010, 11:32 AM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
Originally Posted by crown14
I feel they are pretty bright, but you are onto something here. Perhaps a full on side by side comparison between the X-Lites on the D90 and my Disco's Hella 4000s is in order!
Yes PLEASE!!!
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old January 2nd, 2010, 01:31 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
OK
X-Lite vs. Hella 4000 Comparison Test will happen tonight then. I am thinking find a good spot with an object like a shed in the distance and then one at at time park each truck in the same location and take a photo showing how well the shed is illuminated. Ill try and get a shot without the headlamps on, then one with, etc etc.
I will go ahead and point out a couple of things that might matter to most people regarding these lamps. First, the Hella 4K uses a 100W bulb. That means that as the available battery voltage changes, a pair will draw as high as 22A depending on if you are winching or running down the road. So the most you can power through one 30A relay is two- and as most everone throws 4 on the roof, there is a little extra work in wiring two relays to power two pair. The X-Lites however are only 50W each, meaning it is safe to wire all 4 together powered by a single 30A relay. Also for the Hella 4K, most of your local parts stores will have replacement bulbs of the same physical type but with a 50 or 55 watt rating- if you burn out a bulb replacements can sometimes be tough to find. The X-lites use bulbs straight out of light fixtures found in homes and offices, I literally have several of the same bulbs hanging from a ugly lamp in my kitchen. While the Hellas can get pretty warm, the bulb is pretty well protected inside the housing. The bulb is well exposed on the x-lite and I am pretty sure it gets quite hot- a splash of water on it might be all it takes to blow the bulb. Covers are available for the hellas (3 types at least) but nothing for the X-lites. Hella 4000s are designed to be, and usually are, waterproof. The X-lites have a big open hole in the bottom where the wiring enters. The actual bulb is the same for all 4000s and it is protected behind the lens. Different variants (euro beam, pencil beam, fog, etc) of the 4000 are created by using different combinations of reflectors and lenses. The lens is part of the bulb itself on the x-lite, and the spot and fog variants are only different in bulb design alone. The Hella 4K mounts in the traditional way on a stud, then is adjusted on a special swivel mount. It can be pointed up/down to a certian extent and adjusted left/right easily. The X-lite butts up against the roll bar and mounts via a standard type hose clamp and can only be adjusted up/down.
Old January 2nd, 2010, 07:53 PM
crown14's Avatar
crown14
Verticalscrote
Ste: I got your pictures taken today, but later it was so cold I hit the wrong button and deleted ALL of them, so I will try again tomorrow.
OK
No flash was used, pictures were taken after dark, before the moon was high enough to make a difference. The first pics were taken 20 feet in front of the truck with just headlamps on, second with headlamps and roof lamps. Then from inside, center of the dash area, .5 second exposure- first with just headlamps, then with headlamps and roof lamps. No highbeams were used at all.
The D90 has stock headlamp wiring, with brand new Sylvania Silverstar Headlamps, and mounted to the top of the roll bar over the windscreen- two fog X-Lites (outer) and two spot X-lites (inner).
The Disco has stock headlamp wiring, with 2yr old Sylvania Silverstar bulbs, in dirty D2 housings that are almost 4 years old and at least one has condensation inside at the moment. On the roof rack are 4 Hella 4000 Euro beam lamps.
Voltmeters on both trucks read 13.7 volts at time of test.
1. D90 with just headlamps on
2. D90 with headlamps and X-Lites on
3. D90 just headlamps
4. D90 headlamps and X-Lites
5. Disco with just headlamps
6. Disco with headlamps and Hellas on
7. Disco with just headlamps
8. Disco with all lamps on
You be the judge!!
ID:	24079   Click image for larger version
ID:	24081   Click image for larger version
ID:	24083   Click image for larger version
ID:	24085   Click image for larger version
Old January 2nd, 2010, 10:29 PM
crown14's Avatar
crown14
Verticalscrote
Originally Posted by TDI Guy
Or shim the ones you have even know the the nut will not lock well and just test it around the block. If it goes away, then I would go for different links and be done with it.. Whats a few more $$$$$ lol
Today I bit the bullet and made an attempt to shim the rear links out, went as far as I could and still get the nut on there (about 1/2 inch) and it wasn't enough. I looked on the Disco and the RTE links are shimmed out 13/16 and I don't think that is even quite enough.
ALSO I MEASURED THE TIRES and at 40psi they only measure 32 11/16 tall, and the tread is 9.5 wide. Kinda lame considering the Interco spec is 33.9 and 11.4 wide. They sure look big as hell though.
Old January 3rd, 2010, 12:07 PM
jaygoss's Avatar
jaygoss
Jay Goss
You be the judge!!
Wow. Thanks Joel for taking the time to do that. It looks like the D90's lights are aimed a little lower than the Disco's as the glare is much more in the "frontal" shot. That being said, the Hella's seem too give off a crisper image with a more focused beam. If anyone else interprets this differently let me know- this is just an amateur observation. i like the looks of the new lights on the Rover but I like the performance of the Hella's- enough to offset the coolness factor of the X-Lites. I think you just saved me some $ and possible buyers remorse! Thank you!!!
Old January 3rd, 2010, 12:20 PM
crown14's Avatar
crown14
Verticalscrote
Jay the Disco is a lot taller too. I agree the X-Lites look great, and dont get me wrong, they do put out a lot of light, but its hard to compete with the sheer size and double wattage of the Hellas. Keep in mind also that I am using Euro beam 4000s. If I had a more similar array to the two fog and two spot on the D-90, such as two fog 4000s and two pencil 4000 it wouldnt even be close to a fair fight.
What really made the difference for me is behind that shed is another house, and then a 6 lane highway, and an intersection with a RR crossing. With the Hellas I could light up the reflective tape on the crossing arms from over 120 yards.
Old January 3rd, 2010, 12:33 PM
deslandes's Avatar
deslandes
Deslandes stéphane
1998/Defender 90 300Tdi
Thumbs up
Thanks a lot for the measure...
desLANDes is my real Name... I can't own anything else and I'm happy with... I'm french, so excuse me if sometimes you don't understand xhat I mean and reverse...
My 90Tdi :
Old January 3rd, 2010, 11:52 PM
crown14's Avatar
crown14
Verticalscrote
few pics
ID:	24106   Click image for larger version
ID:	24108   Click image for larger version
Old January 3rd, 2010, 11:55 PM
KKilo23's Avatar
KKilo23
Kenny
Thumbs up
few pics
Joel, came out great! That color looks good on the black.
Old January 4th, 2010, 12:57 PM
crown14's Avatar
crown14
Verticalscrote
Yeah I think the window tint looks pretty good, its max legal in NC, 35%.
What do you all think of the tailpipe? Does it seem to stick out in an odd way?
Keep in mind I have not resolved the fender flare situation yet or gotten the wingtop protectors on, so its not done yet.
ID:	24114   Click image for larger version
ID:	24116   Click image for larger version
ID:	24118   Click image for larger version
ID:	24120   Click image for larger version
ID:	24122   Click image for larger version
Old January 4th, 2010, 01:03 PM
That's how mine used to look. It will change if you take it on trails though
Old January 5th, 2010, 01:03 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
I love this truck. Great job. Tailpipe looks fine.
Old January 5th, 2010, 04:16 PM
tailpipe looks stock, how much was the tint job?
Old January 7th, 2010, 12:39 PM
crown14's Avatar
crown14
Verticalscrote
Tailpipe is stock, tint is 35%
------ Follow up post added January 7th, 2010 01:20 PM ------
http://i424.photobucket.com/albums/p...0/100_9407.jpg
Old January 7th, 2010, 03:06 PM
draaronr's Avatar
draaronr
Here
LR3
get that shit bent right so it comes from the top down.
Old January 7th, 2010, 11:36 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Rear bumper needs to be black to balance front bumper and sliders......doesn't look right.
Old January 14th, 2010, 08:51 PM
crown14's Avatar
crown14
Verticalscrote
Truck's gone to the paint shop today, big problem now is finding a suitable paint for the new fender flares...
Old January 22nd, 2010, 02:25 PM
crown14's Avatar
crown14
Verticalscrote
I think we vetoed 3 dozen paints before just deciding to just go with a Dupont flat plastic paint for the fender flares, but they should look fine. Truck will be back from the paint shop possibly as soon as tomorrow, then I can finish up the list of little left-over items-
Wingtop Protectors
Rear seat trim
Right Rear sidemarker
Aim X-lites
Front Diff guard
new RTE rear links
Found a place local who can hopefully modify the Tuffy console we have to work in the truck, then the Engle can go in. Then its detail, snap a few final pics and I'll be done. (fingers crossed!)
Old January 22nd, 2010, 02:39 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Be very interested to see what you do with the Tuffy to accomodate the Auto set up. Waiting patiently for lots of pics....
Old January 22nd, 2010, 03:01 PM
crown14's Avatar
crown14
Verticalscrote
Here is the basic idea...
ID:	24623   Click image for larger version
Speaker placement - '97 D-90 SW owners Chaucer Defender Technical Discussions 4 October 4th, 2010 02:44 PM
1997 SW side doors, top and rear door avail, and more from 97 LE wicks For Sale - Parts 21 April 28th, 2010 02:53 PM
97 D90 SW stuck in reverse. woldd90 Defender Technical Discussions 9 September 9th, 2009 09:56 AM
97 SW doors for sale kevorkjan For Sale - Parts 2 May 11th, 2009 10:05 AM
Looking to swap 95 ST for 95 / 97 SW unit3a Wanted 0 November 28th, 2008 12:55 PM
