'95 D90 Overhaul w/ 2.8L Diesel - Page 4 - Defender Source
Old September 5th, 2010, 11:26 PM
Chris, you need to get this truck finished! Drove past The Black Horse last night...will need to see your truck out front there in a few months.
Old September 5th, 2010, 11:45 PM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
For comparison, I wonder what the typical thickness is for a rhino lined truck bed?...
Josh,
Wishful thinking, but hopefully it will make it to MAR... ROAV at The Cove for sure.
Old September 6th, 2010, 12:00 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
The attractive linings are typically sprayed on up to a " thick on truck beds
Old September 6th, 2010, 10:04 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Looks like the diffrence is 2mm or .080, I like the way it looks but I wonder if it cuts down on noise at all when applied that thin?
Old September 6th, 2010, 01:45 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Perhaps Chris can confirm that at the point where he took his measurement, that the seatbox had 2 layers of aluminum. It looks like he has removed the boxes from the seatbox, which may result in his measurement only being 1 layer (?). If so the relevant comparison measurement would be 1.5mm
Old September 6th, 2010, 02:05 PM
Chris Vitale
Not sure how much total noise reduction I can expect with a soft top...but point taken.
I plan to apply a slightly heaver coat for the front floor boards and rear tub floor to keep up with the heavier foot traffic, but not as thick as a typical bed liner (.25" or 6.35mm). From a looks perspective, floor boards are a little more forgiving than the seat box too, so I will likely go for a thickness in the range of 3 - 4 millimeters. Not too heavy, not too thin...but just right.
My overall rhino line goals in priority order:
1. Clean look
2. Durability
3. Sound deadening
------ Follow up post added September 6th, 2010 02:13 PM ------
Paul,
I did remove the battery box. I don't have my battery box with me, but correct me if I am wrong...when referring to the tab that my arrow points to, the battery box is not in play?... Did you take the measurement at the tab indicated in my pic?
Old September 6th, 2010, 03:33 PM
grnrvrs's Avatar
grnrvrs
Paul
88
So the comparison measurement is 1.5mm v 5.1mm i.e. 3.6mm (1/8") of rhino. 1/8" should be good enough to cut down on vibration of the panel but not absorb much sound.
Old September 11th, 2010, 03:31 PM
Chris Vitale
Magic garage unveiled
Brought the seat frames back to life as well as treated them to new foam cushions and upholstery.
Sad to report, at this point, it doesn't seem like this project will be complete in time for MAR...but hopefully it will make it's debut at ROAV at The Cove.
Many of you may not know, but Randy, AKA TDI Guy, has been the mastermind behind this build all along.
While the project has progressed better and faster than I ever imagined, I believe more recently the pace has slowed ever so slightly, so that Randy's D90 can bask in glory at MAR, for one more year, before his envy kicks in.
Kidding.
Thank you Randy...If it were not for you, I am sure I would never have even had the courage to rotate my tires. You the man Randy!
ID:	30946   Click image for larger version
ID:	30948   Click image for larger version
Old September 13th, 2010, 08:17 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Seats look nice....
Legend in My Own Mind.
Old September 29th, 2010, 12:21 AM
rovertrader's Avatar
rovertrader
Dale
Chris- looking good, she's come a long way since I saw her for sure!!
My '95 is rocking, motor is doing great- thanks!!
Old October 8th, 2010, 10:13 AM
Chris Vitale
Thanks Dale. Great to hear the motor is working out well.
Just picked up some stuff from galvy. Only missing one rear seat bracket from the galvy dip process...The bracket shouldn't be too difficult to replace.
Progress will be picking up shortly with everything coming back from galvy and paint. Will post more pics shortly.
ID:	31983   Click image for larger version
Old October 14th, 2010, 07:21 PM
Chris Vitale
Tub is back...and back at home on its chassis.
ID:	32138   Click image for larger version
ID:	32140   Click image for larger version
ID:	32142   Click image for larger version
Old October 14th, 2010, 07:23 PM
Maybe I missed it along the way, but who did your paint work? I may need one some day.
Looks great!!
Old October 15th, 2010, 08:22 AM
KKilo23's Avatar
KKilo23
Kenny
Chris looks great!
+1 Where did you get the paint work done? Did they have to do any body work or was it a re-spray?
Old October 15th, 2010, 10:18 AM
Chris Vitale
Thanks.
Had the paint work done by a family friend. Body work wasn't needed...all the panels were in excellent shape.
Old October 15th, 2010, 12:46 PM
KKilo23's Avatar
KKilo23
Kenny
Originally Posted by Chris Vitale View Post
Thanks.
Does he do work on the side or own a shop.
I am doing a frame up this winter and will need to get the truck re-sprayed somewhere...
Old October 15th, 2010, 03:33 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
When you are ready for paint, shoot me a PM...
Old October 15th, 2010, 04:07 PM
KKilo23's Avatar
KKilo23
Kenny
Will do. It's going to be a couple of months.
Old October 20th, 2010, 08:12 AM
Chris Vitale
Much more progress:
1. Aligned tub with bulkhead
2. fastened down the Seat box
3. Installed battery in battery box
4. Completed fuel assembly
5. Installed rear door
6. Restored and installed rear ID plate
7. ERC LED lights installed...these are worth every penny.
Ran into a glitch with galvanizing hood support bracket...When it came back from galvy, it was all jangeld at one corner. It must have gotten hung from this corner and the weight of the bracket must have warped the bracket. It's not worth repairing the support bracket as the hood needs considerable repair too. As a result, looks like I am in the market for a new hood...
ID:	32296   Click image for larger version
ID:	32300   Click image for larger version
Old October 20th, 2010, 09:25 AM
Is it going to make it to ROAV at The Cove?
90, 95, d90, diesel
2.8L jeep diesel D90user Defender Technical Discussions 22 September 2nd, 2005 02:31 PM
Diesel D90 in Colorado with Warn sticker dnewman9 Misc. Chit-Chat 2 October 3rd, 2004 11:54 AM
D90 Engine Overhaul Landyfun1 Defender Technical Discussions 19 April 20th, 2004 06:02 PM
FS: Four SW Jump Seats from 95 D90 DJ Menasco For Sale - Parts 4 December 19th, 2003 12:28 AM
