'95 Classic - Defender Source
Old July 18th, 2014, 09:47 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
'95 Classic
I have been waiting for the right truck to come along, and last week the clouds parted and this rolled in... a 1995 Range Rover Classic SWB
Originally sold in Mobile, to a physician in the Atlanta area who was murdered in Uganda before the odometer hit 10K, it was sold from his estate to a local gentleman... and then to me makes three. All things considered, the second owner took very good care over the years, but parked it about two years ago with transmission trouble. It needs the basic odds and ends like any truck that has been used over the past two decades... should be a fun project.
If you know your RRCs here is the money shot:
Old July 18th, 2014, 10:38 PM
crown14's Avatar
crown14
Verticalscrote
I was told the transmission went completely out, but that it would work for a little before warming up? Also, that it would not start due to bad gas.
Well my guess was seized fuel pump... sure enough, it had no fuel pressure. Quick fix, with a fresh battery it fired up instantly, and even better, it drives. No reverse, but drives nice.
------ Follow up post added July 18th, 2014 10:44 PM ------
I'm going to need a quarter...
Old July 19th, 2014, 12:45 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Nice.
Good money shot picture.
I've seen some fuel pump access doors that you could not tell what kind of screws were on there because of so much rust....
Rent my
Old July 19th, 2014, 02:38 AM
so was it fuel pump or battery, or both?
Old July 19th, 2014, 12:02 PM
roversnorth has good stuff from time to time
Old July 19th, 2014, 12:22 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
very nice truck
good luck with your search
Old July 20th, 2014, 02:07 AM
Wow. When you were describing it and told me what you paid for I expected a beater.
Old July 22nd, 2014, 01:22 PM
crown14's Avatar
crown14
Verticalscrote
OK brand new liftgate struts are here, new front lower lights are on the way, and the previous owner stopped by with the missing wood for the passenger front door, and I have began to accumulate other various small parts... and I already have some of the large parts I need for the LT230 conversion/transmission swap.
------ Follow up post added July 22nd, 2014 01:24 PM ------
I didn't know what to expect before it showed up, and once it got here I couldn't wipe the smile off my face, it is a keeper for sure.
Old July 22nd, 2014, 02:30 PM
corrumpu
chris b
1995/RRC SWB
Subscribed. I too have a 95 classic SWB in white. Should be fun to watch you clean this one up. I love my classic!
Old July 22nd, 2014, 02:45 PM
crown14's Avatar
crown14
Verticalscrote
I didn't even bother with the old battery, it might take a charge but I am sure what I swapped in is a better one. Someone had recently tried to jump start it, and they might have checked for fuel pressure at the rail, but they didn't go as far as checking relays or voltage to the pump, so I I checked the relay (it worked) and the pump (no noise) so that is why it would not start.
Old July 24th, 2014, 12:50 PM
crown14's Avatar
crown14
Verticalscrote
Found out it does not want to start in 100% humidity. More new parts ordered, hope to get it cleaned up this weekend. I did get the liftgate struts on the other day.
Old July 28th, 2014, 06:59 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Did you find this on craigslist?
Old July 28th, 2014, 10:50 AM
It found him on Craigslist
Old July 31st, 2014, 01:04 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Here are a couple pics
ID:	99815   Click image for larger version
Old August 4th, 2014, 07:25 PM
crown14's Avatar
crown14
Verticalscrote
*Not pics of my truck, or my build
Old August 5th, 2014, 12:27 AM
crown14's Avatar
crown14
Verticalscrote
OK for an on-topic update: been ordering parts... here is just a few of them...
Old August 5th, 2014, 06:21 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
our RR rubber mats are now probably 15 years old and still in good shape.
look forward to seeing the steel structure under the quarter panel when you remove it.
nice looking RRC!
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old August 5th, 2014, 06:33 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Everything looking great. Wow what a find congrats
Old August 9th, 2014, 04:21 PM
crown14's Avatar
crown14
Verticalscrote
This week- found a quarterpanel (should be here soon), and got another box of parts, and a big box of paint. Oh, and a transmission as well as complete LT230q swap setup. Waiting on some oil cooler lines, then will begin the mechanical side of the project.
On the interior side, I believe I have nearly everything worked out... including restoration of all the original wood. Also got some carpet samples in this week, looks like "Cafe Latte" is a better match than "Mocha".
Old August 9th, 2014, 05:06 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
you know, that was one of the first things I bought for my 1st RR when I found Rovers North circa '99 and that set of mats is still going strong...
Keep posting the updates C14, is this Classic coming to URE11?
Rent my
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
