'95 Classic - Page 9 - Defender Source
Old October 9th, 2014, 09:46 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Originally Posted by Jymmiejamz View Post
I can appreciate that.
I once had some of those guys fix a seat on a Cadillac I was flipping. It was summer. A guy came to test drive it, when he got out, the seat "repair" was stuck to his pants. He didn't notice, and I didn't say anything. I was hoping he would buy the car, and the seat would be whole again on his drive home. I could imagine him getting back in and the sticky chunk of vinyl falling right back into place. "Oh man, something about me in this caddy feels SO RIGHT!" I started laughing to myself like a crazy person and I think it spooked him, needless to say he didn't buy, and my mobile upholstery repair rode off into the sunset on the back of his pants.
Old October 9th, 2014, 10:17 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ I am literally LOL'ing at that story ^^
Rent my
Old October 10th, 2014, 06:15 AM
Leather repairs rarely last if it is a high traffic area. I don't think they will screw up dying a load space carpet.
Old October 10th, 2014, 07:17 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
not sure if I've posted this before, yet, in case not:
http://www.leathercaredirect.com/index.php
as we are close to GB toying with the idea of sending the driver's seat over.
and they have a "kit" if you have a decent shop that you can "diy" so to speak.
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old October 10th, 2014, 08:16 PM
crown14's Avatar
crown14
Verticalscrote
If it dye would fix this carpet, then I'm there. But it won't.
Old October 11th, 2014, 09:28 AM
crown14's Avatar
crown14
Verticalscrote
Cleaned and painted transmission/transfer case mount brackets. Installed new brake cable. Cleaned and lubed CDL shifter, today I will test fit it and adjust the CDL light switch as needed. I also need to pull the three bolt flange off the rear differential...
Old October 11th, 2014, 11:26 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
everything looks awesome man!
Old October 11th, 2014, 06:22 PM
crown14's Avatar
crown14
Verticalscrote
Been messing around under the truck a little today. Check this out.
Before
After
Behind the crossmember
Behind the transfer case mount bracket
And these are spots that weren't undercoated at the dealer! NO I didn't paint it! (Yet) All I used was this:
All the hardware thus far went straight into the parts washer. I took it out, rinsed it, and aside from exhaust studs/nuts, there isn't a single piece that I can't reuse.
Old October 11th, 2014, 06:37 PM
crown14's Avatar
crown14
Verticalscrote
Took another cue from the Discovery II, and robbed the insulated brake cable sheath off an 04 parts truck. Fits perfectly. Then I rewrapped it with some tape from DEI.
Here you can see why you have to use the LT230 frame mount bracket, a little different than the Borg Warner on the left.
One of the studs on the heat shield that goes above the muffler broke, easy fix, I just welded another next to it.
Old October 12th, 2014, 05:08 PM
crown14's Avatar
crown14
Verticalscrote
I am pretty much to the point now of reinstalling the transmission. I need to pull the remnants of the old cooler lines off. Clean the AC drains. Got the difflock shifter all sorted out. Recovered the muffler heat shield. Gave up on the three bolt flange, it can wait till later. Removed a ton of unused air lines from the old air suspension. I have painted the inner frame since it's easily accessible with the transmission/transfer case out of the way, but I won't waste any more time on paint or undercoating until the truck is cleaned after Uwharrie.
Old October 14th, 2014, 12:16 PM
crown14's Avatar
crown14
Verticalscrote
Drilled two holes in the BW (now unused) mount to chassis bracket and bolted it to the ZF, then to the shitty autozone transmission jack adapter.
That will be better than just laying under the truck like I was planning on doing.
Old October 14th, 2014, 12:42 PM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Really looking forward to seeing the Rangie go forward or reverse lol under its own power. If possible would like to see pics of cleaning the ac drains.
Old October 14th, 2014, 01:15 PM
crown14's Avatar
crown14
Verticalscrote
Ac drains. I just took off the ends and washed them with soapy water. Not much to it.
Old October 14th, 2014, 02:28 PM
crown14's Avatar
crown14
Verticalscrote
Old October 14th, 2014, 04:08 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Nice heat shield!
Got any more of those??
Rent my
Old October 14th, 2014, 07:11 PM
crown14's Avatar
crown14
Verticalscrote
Nice heat shield!
It's the original, recovered with DEI Heat Screen
http://www.designengineering.com/cat...hesive-backing
I threw a few rivets in it because I cleaned it before putting the Heat Screen on (it has adhesive backing) and it was still wet.
Old October 14th, 2014, 10:15 PM
Get those tires mounted!
Old October 15th, 2014, 03:21 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
thanks! and second on the heat shield - very nice.
Old October 15th, 2014, 10:21 PM
crown14's Avatar
crown14
Verticalscrote
Got double sidetracked today. First I sold my rear differential, which makes the 3 bolt to 4 bolt flange conversion a bit simpler. Or more complicated... anyway.
Second, the original owner ordered the extra dealer installed undercoating. I can say this because there is a ton of the shit all over down there, which is good and bad. The good, it protected the vehicle really well. The bad, now it's dried up and not good for much else than being a dirty mess.
So I went at some of it with a wire wheel...
Only doing this on a limited area right now, due to time constraints. Also testing a new paint product, and I am very curious to see how it holds up.
Old October 16th, 2014, 06:28 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
hum, the underside of mine looks like that as well - the before pic.
will have to look closer now and see if it is undercoating as well.
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
