'95 Classic - Page 7 - Defender Source
Old September 28th, 2014, 10:33 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Originally Posted by rover4x4 View Post
can i send a set back for an asessesment?
Definitely get in touch with Tony, he has been very helpful with my situation.
Old September 29th, 2014, 07:57 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
On a different note, my latest rental car had LED headlights.
Drove through fog as well as dark road to use high beams.
My Saab has HID for high and low beam and these were almost as nice.
The lights on my RR are the DOT approved Hellas and they suck especially over here.
Have seen a few Defender folks install Truck Lite LED lights and am thinking about the same although I did have real Hella E-code on the green RR and they were pretty good.
What are you thinking about for the headlights unless there are no plans for night driving and the stock lights will be fine.
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old September 29th, 2014, 06:20 PM
crown14's Avatar
crown14
Verticalscrote
Great question... while the trucklites are cool, I have to check them out in person at night before I decide if I want to mess with the appearance of the front end that much. BUT I have been eyeing some stock-ish appearing glass replacement lamps with built in projectors, which might work really well with a HID setup... and not look any different than original during the day.
Old September 29th, 2014, 08:55 PM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
That could be very cool. Would you have to change some wiring though? HIDs as mentioned are great on my Saab for light, however, the downside is the replacement bulb is U$300.00 each. Still on my OEM set, yet, not looking forward to replacement day. The light output though is awesome.
Old September 29th, 2014, 10:28 PM
crown14's Avatar
crown14
Verticalscrote
Maybe some slight wiring changes, nothing difficult though. Certainly not any more dramatic than what I've already done to the seat switch, or than what I'll end up doing for the stereo, or the mirrors.
I've put in another order for seat covers, but it doesn't look like they will be done before URE. And now I am having to fix the transmission in my Mercedes before I can start on the Range Rover transmission...
Old October 1st, 2014, 08:48 PM
crown14's Avatar
crown14
Verticalscrote
Old October 2nd, 2014, 05:28 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Hum, those look familiar! What size did you end up with?
Old October 2nd, 2014, 07:44 AM
crown14's Avatar
crown14
Verticalscrote
245/75
Old October 2nd, 2014, 08:28 AM
IROKs and not KM2's I didnt realize SS made a 245/75, its kind of a game changer
Old October 2nd, 2014, 09:06 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
IROK NDs?
I heard about those on dweb.
Rent my
Old October 2nd, 2014, 10:34 AM
crown14's Avatar
crown14
Verticalscrote
IROK NDs?
Yes, the set of 4 delivered was under $600
Old October 5th, 2014, 04:57 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Very good price as my MTRs were more and can't keep them in balance for more than about 2,000 miles.
My OEM wheels were trashed by the PO and have found a replacement set in GB that might help the balance. For sure will at least look better.
Old October 5th, 2014, 12:03 PM
crown14's Avatar
crown14
Verticalscrote
Time to start some real work...
Old October 5th, 2014, 12:36 PM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
How true to original are you planning?
Old October 5th, 2014, 02:27 PM
crown14's Avatar
crown14
Verticalscrote
Only tasteful modifications will be performed... and nothing that couldn't be undone. I am not the type to take such a rare truck and butcher it at all. That said, most of the EAS system has been removed already, so I will be tidying that up by removing the remainder. The coil springs are a very tame OME Medium Duty. Keeping stock type shocks on the truck, at least for now. Obviously the original Borg Warner transfer case is coming out, and the tires are a little bit larger and more agressive...
Old October 5th, 2014, 03:21 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by crown14 View Post
Only tasteful modifications will be performed... Obviously the original Borg Warner transfer case is coming out, ...
Good.
I consider the Borg to be a bad factory mod, so putting in the LT230 is actually restoring to more original specs.
Rent my
Old October 5th, 2014, 06:03 PM
crown14's Avatar
crown14
Verticalscrote
Old October 5th, 2014, 06:25 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Looks good - subscribed .
Mike Hammond
Old October 5th, 2014, 06:40 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Good.
I kinda disagree. I actually missed the BW when i went to the LT230 in my old classic. I did some pretty crazy trails with just a BW and open diffs. Some dude in an FJ once asked me, after i went up some stupid kind of rock infested ridge, what kind of lockers i had. he was floored when i told him just a VC coupled center diff.
yes they fail, but when they work, i think BW are pretty great. And super quiet.
Old October 5th, 2014, 07:02 PM
crown14's Avatar
crown14
Verticalscrote
Ok I have everything except the other half of the bellhousing bolts off, that's enough for today.
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
