'95 Classic - Page 5 - Defender Source
Old September 14th, 2014, 10:23 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Well I spent too long looking at power mirror wiring diagram today and didn't have much luck with all that, so I am going to hold off on rewiring the mirrors for now.
But I did accomplish something. The seat base trim on the driver's side was a little busted:
But all the broken parts were still there, so I decided to go ahead and repair it with my hot stapler.
And I forgot the "after" photo of the other side so expect another update.
Old September 15th, 2014, 08:20 AM
crown14's Avatar
crown14
Verticalscrote
After
That's 100% original plastic repaired and reinforced with stainless steel. No glue. No epoxy.
Old September 15th, 2014, 09:30 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
That's pretty remarkable. Nice work.
Old September 15th, 2014, 09:41 AM
You can also use model airplane glue
Old September 15th, 2014, 09:56 AM
Listen, Betty, don't start up with your "white zone" shit again.
Old September 15th, 2014, 10:01 AM
crown14's Avatar
crown14
Verticalscrote
http://youtu.be/oXeacki20Qc
Old September 15th, 2014, 01:04 PM
DesertEagle
99 disco
where did the floor mats come from? I have a 95 SWB also and there are no floor mats in it currently...I could really use a set.
Old September 15th, 2014, 01:28 PM
Rovers north and Atlantic British usually have them. LWB rear mats are unobtanium
Old September 15th, 2014, 01:29 PM
crown14's Avatar
crown14
Verticalscrote
http://www.roverparts.com/Parts/STC8053G
The cargo mat is a Weathertech, I got it in Black to match the other mats, but they also sell it in Tan and Grey
http://www.roverparts.com/Parts/9465
Old September 16th, 2014, 01:32 PM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
It's weird now that I'm used to the Euro light set-up with clear lights the all amber look strange. Good find though.
------ Follow up post added September 16th, 2014 05:36 PM ------
How true. I'm lucky only the one Lab lays on mine and it's usually covered with a towel for his comfort as getting older now. The front ones are showing some wear yet those are findable.
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old September 20th, 2014, 12:03 PM
crown14's Avatar
crown14
Verticalscrote
Ok I'm gonna button up the seat project today and then do the tune-up. The goal is still to get it fully operational for URE next month and it has a long way to go.
Old September 20th, 2014, 12:37 PM
that hot stapler is amazing. expensive but amazing
Mark Kellgren
KM4BOR
Old September 20th, 2014, 12:38 PM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Tune up is pretty straightforward as you know well. What about the tranny issue you mentioned earlier?
Old September 20th, 2014, 09:15 PM
crown14's Avatar
crown14
Verticalscrote
I have a good used one to swap in, at the same time I am going to do LT230 conversion.
Old September 21st, 2014, 04:42 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Yeah, I wanted to do that swap as well and it just didn't work out. No doubt it really improves off highway performance, yet, will wait until we get back to the U.S. before considering it again.
Old September 21st, 2014, 10:55 AM
crown14's Avatar
crown14
Verticalscrote
This is what the passenger side seat base trim looked like. Ouch.
When Doug sent me the quarterpanel, I had him send me the the trim from his parts truck. With a slight trim and a new screw hole or two, the pre-95 trim fits perfectly.
Door sill plates and this part is all done. Over the winter, or maybe before, the seats are coming out, the carpets getting cleaned, and that light rust getting taken care of.
Old September 21st, 2014, 12:26 PM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Well removing the carpets is pretty easy lol as mine are up all the time drying out the floor although now that I have the flap holes filled with epoxy as temp fix, much less water intrusion.
When I reinstall the sills I wrap the screws which are now SS with plumber tape. Keeps the water out from coming up the screws.
So what seat covers did you purchase?
Old September 21st, 2014, 01:05 PM
crown14's Avatar
crown14
Verticalscrote
Got the seat covers from Kexby. I installed the passenger front almost a month ago, and it finally seems to have settled into place. Installed the driver front last night. Will put the rears on later today. They are pretty stout and I will go into more detail about them in... about a month when the rest of them settle in.
Right now I'm under the hood...
Old September 21st, 2014, 02:13 PM
crown14's Avatar
crown14
Verticalscrote
Flame trap.
Flame trap after soaking in gasoline for an hour, then being flushed/backflushed with water, sprayed out with brake parts cleaner, and sat in the sun to dry.
New breather hoses, tee, idle control valve hose.
We have these hoses in stock, PM/email if you want to replace yours...
Old September 21st, 2014, 03:41 PM
did you get those mudflaps installed
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
