'95 Classic - Page 24 - Defender Source
Old May 10th, 2015, 12:45 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Smooth and shiny!!
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old May 10th, 2015, 11:19 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Originally Posted by Blueboy View Post
Smooth and shiny!!
It's a lot of work. In the small areas I'm doing it by hand with a cotton swab, or if I am lucky a 1" polishing pad. The large areas I'm using a 3" foam pad. For heavy staining I use the red compound first, which will leave a tint to the white paint. Then for the oxidation and removing any red tint I use the white compound.
Yes I'm polishing the entire surface of the truck with a 3" foam pad chucked in a drill. It's maddening.
In comparison the wax application seems easy. I let it dry and remove the bulk with a terry cloth, then buff it with a new wool pad on a 10" random orbital buffer, then final wipe down with microfiber. End result is slicker than new paint.
Old May 10th, 2015, 12:11 PM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Yes it is a large surface area which I say each time I do it! I'm using a Griot orbital for polish and wax. The end result is worth it especially if you keep up with it. BTW, Griot has a product for refreshing black vinyl roofs. It works great on the rear vinyl pillars.
You have gone where most have not and it shows!!!
Old May 11th, 2015, 06:58 PM
crown14's Avatar
crown14
Verticalscrote
Well, I made a tail lense gasket, sort of.
Old May 12th, 2015, 06:15 PM
crown14's Avatar
crown14
Verticalscrote
Finished up buffing out the last couple doors and the tailgate... waiting on wax to dry now!
Old May 12th, 2015, 09:37 PM
crown14's Avatar
crown14
Verticalscrote
Old May 13th, 2015, 05:22 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Looks great!
Old May 14th, 2015, 11:38 PM
crown14's Avatar
crown14
Verticalscrote
Ok I'm going to TRY to upload photos that show recovering the headliner...
Old May 14th, 2015, 11:41 PM
crown14's Avatar
crown14
Verticalscrote
Old May 14th, 2015, 11:42 PM
crown14's Avatar
crown14
Verticalscrote
Old May 14th, 2015, 11:48 PM
crown14's Avatar
crown14
Verticalscrote
It's sideways time
Oh well, I was only posting the instructions for those who may come across the thread and get the DIY bug.
Old May 15th, 2015, 02:03 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Makes a huge difference in the interior doesn't it! With the amount of glue you used, should stay in place for awhile. Really nicely done.
Old May 15th, 2015, 07:17 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Wow.. that headliner was probably one of the worst I have seen...
But the results are amazing.
I tried to recover my headliner a couple of years ago. Removed it, slightly washed it, put it back on with new glue, looked great for 6 months, and started sagging again in the back around the speakers. Tried again with a lot more glue, and it only lasted 1-2 months.
I'll be trying again with some new fabric... since that looks really good!
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old May 15th, 2015, 09:21 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Originally Posted by belgian View Post
Wow.. that headliner was probably one of the worst I have seen... But the results are amazing. I tried to recover my headliner a couple of years ago. Removed it, slightly washed it, put it back on with new glue, looked great for 6 months, and started sagging again in the back around the speakers. Tried again with a lot more glue, and it only lasted 1-2 months. I'll be trying again with some new fabric... since that looks really good!
Oh man! That sucks to do all that work just to have it fail so soon. It's a rather big and messy job to have to repeat. When you were applying the glue, did you let it sit for 10 minutes or so to get really tacky? That was the hardest part for me as it seemed counterintuitive. I just had to trust the instructions that it would work. I hate trusting directions, let alone reading them. I used new material as someone had said that reusing the old material wouldn't work. Obviously, that's not true. But it may take more finesse to get the glue to work with the original material. Good luck with everything this time.
Old May 15th, 2015, 02:04 PM
crown14's Avatar
crown14
Verticalscrote
I don't understand how reusing the old material is even possible.
Old May 15th, 2015, 02:33 PM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Oh it is possible, and actually looked quite good. For a short time, If I remember, I'll take a picture next time.
Old May 15th, 2015, 10:01 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
You have to get all of the old foam and junk off or it will always sag.
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old May 16th, 2015, 12:01 AM
crown14's Avatar
crown14
Verticalscrote
I forgot to mention those are brand new dome lenses...
Got the rest of the interior reinstalled, also put the wood trim back on the right front door, and did some repair to the speaker grille. The driver door panel is gonna be a little more of a challenge.
I also put new Genuine door pulls on, three of the originals were cracked. Naturally now the fourth is cracked too.
Making an appearance tomorrow at the British Car Show in Raleigh.
Old May 16th, 2015, 12:16 AM
D90Overkill
David Frank
1995 ST #2615
Maaaan! That looks great! Leaving the seat covers on for the show or barebacking it? ;-)
Pm'd you for info on the codes for the wet okole seat covers. Love them!
Old May 16th, 2015, 01:33 AM
crown14's Avatar
crown14
Verticalscrote
Why???? 4yds new material is only $36
Reusing the old stuff is just a waste of glue.
------ Follow up post added May 16th, 2015 01:38 AM ------
Seat covers are here to stay.
Let me see if I can look up my order form. Once made the order, they emailed me the next day and wanted pics of my seats, I really appreciated that attention to detail, that they wanted to make sure they got it right.
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
