'95 Classic - Page 23 - Defender Source
Old May 6th, 2015, 03:12 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
ID:	120091   Click image for larger version
Old May 6th, 2015, 03:14 PM
crown14's Avatar
crown14
Verticalscrote
You must enter a message.
ID:	120094   Click image for larger version
Old May 6th, 2015, 04:47 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
Damn that grille looks awesome
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old May 6th, 2015, 05:23 PM
crown14's Avatar
crown14
Verticalscrote
I polished the white paint at the bottom... then used SEM cleaner and adhesion promoter but painted the black with Duplicolor bumper and trim paint. I'm happy.
I have a NOS grille emblem for it also... but can't find a flaw with the one that's on there, so I'll leave it.
The second I saw this truck I felt like it had potential. It's working me to death but starting to feel I was right
Old May 7th, 2015, 02:07 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Paint turned out great.
So you liking the autoscrub sponges?
What do you use on the black trim parts to keep them fresh looking?
Feel sure the work is tiring, yet, the end result is really, really nice.
Went through the thread again and once again realize you also worked on the mechanical side as well.
Just a great RRC!
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old May 7th, 2015, 04:50 PM
crown14's Avatar
crown14
Verticalscrote
Just a great RRC!
The autoscrub... well I'm not sure yet. No complaints, just haven't used them enough yet. Two points of note: they must be "broken in" before actually using them, and the glide lubricant they come with must be diluted- 2oz makes a 16oz spray bottle.
I haven't used anything on any trim yet! But I usually use a product called 303 inside and outside. Very good stuff.
Took a little break from the paint and put the carpets and console back in. Thinking about doing the headliner before I put the front seats back in.
Old May 8th, 2015, 08:25 PM
crown14's Avatar
crown14
Verticalscrote
Old May 8th, 2015, 11:20 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I've been following your restoration and didn't notice anything about your center console cubby being recovered in what looks to be a leather. That looks sooooooooo choice!
Now that your center console is in, have you noticed the two circle knockouts on the sides of the lower rear fascia? I figured that they had been for a factory option rear 12v outlet on either side, servicing the backseat. Thus, I drilled them out and installed 12v sockets. Any inklings to do the same? Now is obviously the time. ;-)
Old May 9th, 2015, 08:13 AM
The truck is looking friggin awesome Joel. Nice work!
Originally Posted by pendy
I'm here for the D's
Old May 9th, 2015, 08:28 AM
crown14's Avatar
crown14
Verticalscrote
That's a leather lid from a 99-02 Discovery.
Those circles were for the seat belts on 94-95 Discovery vehicles (remember this is a Discovery console setup)
Old May 9th, 2015, 10:29 AM
crown14's Avatar
crown14
Verticalscrote
Hmmm...I was going to ask if you've found a substitute for that dry foam shit.
Also, in that same neighborhood, what bulb are you using for that small side marker light?
I haven't checked mine in forever, and I found that 3/4 are burned out on 2 trucks.
I just put in some Sylvania 13v/4.3W bulbs with a liberal coating of vaseline on the bulb/socket.
I am doing the Crown14 screw replacement therapy today and checking all bulbs.
On a whim I have purchased some 1/4" closed cell foam. It's white instead of dark grey but otherwise appears to be the same density and approximate thickness as the NOS gasket I have on hand. Now all I need to do is get a circle hole punch and I think I can make my own new taillight lens gasket.
Somewhere I used to have the number of that little bulb and a source for them... can't find it now.
Old May 9th, 2015, 11:20 AM
D90Overkill
David Frank
1995 ST #2615
That's a leather lid from a 99-02 Discovery. Those circles were for the seat belts on 94-95 Discovery vehicles (remember this is a Discovery console setup)
Ahhhhh! Good point. Forgot that fact! Oh, well. I've got mad aux power in back now ;-)
Your truck looks awesome, man! It'll be better than new. Nice work! Fun to follow.
Old May 9th, 2015, 11:35 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
X-acto knife? Cut out gasket that way?
I got the closest bulb from Vatozone; mine weren't working because of corrosion-nothing major but just enough.
All new bulbs, contacts all clean, all working now.
Rent my
Old May 9th, 2015, 02:30 PM
crown14's Avatar
crown14
Verticalscrote
Hole punch set is en route
Old May 9th, 2015, 02:42 PM
crown14's Avatar
crown14
Verticalscrote
In other news, paint correction continues slowly. Just need to put a couple coats of wax on the roof and it will done.
I know it didn't look bad in the before pictures, but it was a little bit oxidized (naturally) and there were these dingy stains at almost every edge. The oxidation isn't such a big deal. The staining is a pain in the ass.
Old May 9th, 2015, 02:44 PM
crown14's Avatar
crown14
Verticalscrote
Well the app isn't turning my photos sideways today, but it's not uploading them either, so....
ID:	120301   Click image for larger version
Old May 9th, 2015, 02:45 PM
crown14's Avatar
crown14
Verticalscrote
Then they decide to show up...
Old May 9th, 2015, 03:57 PM
D90Overkill
David Frank
1995 ST #2615
Ha! Better to keep the gremlins in the app and out of the truck. Don't set your phone down in the RRC for fear of infection ;-)
Old May 9th, 2015, 06:00 PM
crown14's Avatar
crown14
Verticalscrote
Old May 9th, 2015, 06:01 PM
crown14's Avatar
crown14
Verticalscrote
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
