'95 Classic - Page 21 - Defender Source
Old April 24th, 2015, 09:16 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
It looked like a sneaky toggle switch at first.
Old April 24th, 2015, 10:03 AM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Simply wow, Joel, you keep raising the bar, I may have to do my Concours project sooner than I'd like...
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old April 24th, 2015, 10:48 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Originally Posted by Kevin88RRC View Post
What is that in picture 4?
That's the grommet for the EAS stuff to pass through the floor under the passenger seat.
The big box with the compressor and manifold is missing-you can see one bracket on the frame(the very rust-free frame).
asked and answered!
The truck had been converted when I got it, but all the stuff was still there minus the air springs. In the beginning I removed all the lines and hoses, etc, and any other related item that would no longer be needed and clipped off that harness and sealed it so water could never get in. I am still finding left over clips attached to the frame every time I get under the truck. There has to be at least a couple dozen that I have removed so far.
Old April 24th, 2015, 10:57 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yep, I removed most of my air stuff-ECU, storage tank, some hoses, entire harness, manifold- left the pump for now.
I used that big grommet to pass my ARB harness through...
I just mounted my ARB air compressor inside the factory box in front of the original air compressor(no longer being used obviously).
Anyone ever use the EAS pump to air up tires? I wonder how long it will last--lol
Rent my
Old April 24th, 2015, 06:47 PM
crown14's Avatar
crown14
Verticalscrote
Old April 24th, 2015, 09:41 PM
Fuel filter?
Old April 24th, 2015, 09:46 PM
crown14's Avatar
crown14
Verticalscrote
Originally Posted by rover4x4 View Post
Fuel filter?
I have a brand new Genuine one for it. Actually I've bought 3 different brands and whichever looks the best I'll use.
Old April 25th, 2015, 08:16 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Paint, waxoil or other?
Old April 25th, 2015, 09:25 AM
crown14's Avatar
crown14
Verticalscrote
Eastwood Rubberized Rust Encapsulator
I bought some waxoyl but it's messy and doesn't apply as nicely as the eastwood stuff, and takes forever to cure.
The Eastwood stuff I tested out in a couple spots months ago because I needed to see how well they would hold up. The "toggle switch" thing was one test area that I sprayed. I painted the inside of the frame and undercoated the mid section of the floors when I had the transmission out of it. Since then it hasn't been a lot of miles, but over six months including a trip to Uwharrie and I am impressed so I went with that for the wheel wells etc.
Old April 27th, 2015, 06:15 PM
crown14's Avatar
crown14
Verticalscrote
This part can get discouraging for sure. All those dirty little areas, and you just know that down there somewhere things are gonna be ugly.
------ Follow up post added April 27th, 2015 06:23 PM ------
Let's try that again
Old April 27th, 2015, 07:50 PM
crown14's Avatar
crown14
Verticalscrote
4th try...
Old April 27th, 2015, 07:55 PM
crown14's Avatar
crown14
Verticalscrote
Old April 27th, 2015, 07:58 PM
crown14's Avatar
crown14
Verticalscrote
Bummer, I had more great pics but they keep getting turned sideways or upside down, so I'll post them on the Buckhorn Imports Facebook page.
ID:	119343   Click image for larger version
Old April 28th, 2015, 01:10 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
This is one area I need to tackle as well. For short term I used POR15 on the driver's floor, yet, need to get back.
What are you planning for the corrosion protection?
And really looking good!!
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old April 28th, 2015, 07:28 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Doesn't look too bad! The spot in the rear… it that from the exhaust?
I did this last fall but I have a water leak I still need to track down on the driver's side. Either windshield or door seal. Then I can put the rest of the interior back in.
Old April 28th, 2015, 11:32 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Checked out the FB pics and looks really nice. Very cool that Eastwood material also is available in white. What is the plan for filling the flap bracket holes? Really setting a high benchmark for RRCs!
Old April 28th, 2015, 12:08 PM
crown14's Avatar
crown14
Verticalscrote
The more "serious" rust patches were sanded/ground down or brushed the any rust was treated with Ospho (which is phosphoric acid driveway cleaner btw) and that converts the iron oxide to an inert iron phosphate. Then, white ERE
As usual, the front mudflap bracket was the source of this rust. Lucky me this all was in real nice shape and the bracket bolt plates both came off easily. Will be replacing them with stainless hardware, and if I need to remove the front mudflap bracket going forward I'll just have to pull the carpet back.
Besides that, it appeared the passenger was getting moisture through these 3 holes in the floor, which were originally "sealed" with duct tape dots...
Old April 28th, 2015, 03:42 PM
crown14's Avatar
crown14
Verticalscrote
In places where the original seam sealer has shrunk and cracked, such as here on rhe door sill, I resealed it using the same 3M brushable seam sealer I used in the cargo area.
Then, also used the white ERE on the sills and applied extra coats to the floor areas I hit earlier.
Also used the seam sealer along the door threshold area, which should have been sealed from the factory I think. See pic
Old April 28th, 2015, 07:00 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Joel, great looking truck. What was the process for the Ospho? How applied? Let it dry/wipe it off? How much did you use?
I have a gallon of the stuff for when my '95 D1 is ready.
Old April 28th, 2015, 08:17 PM
crown14's Avatar
crown14
Verticalscrote
Yes, at some point the LH converter broke apart and the substrate migrated to the center muffler, clogged it, and it got super hot. Melted the carpet and underlayment. I had hid it up till now (see the enthusiasm for the new Genuine rubber mats earlier in the thread) but when I put it back together I will be replacing the carpet.
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
