'95 Classic - Page 14 - Defender Source
Old October 27th, 2014, 08:50 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
The few I've checked out that were *glued* to the floor was because the rust had stuck to the sponge pad!
I peeled up some around the edges and didn't see a single spec of rust... I hope this isn't the case. There are no other spots on the truck at all, granted I haven't checked the loadspace or passenger footwell, but everything is really clean.
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old October 27th, 2014, 08:52 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
You're gonna have to get a look at those front flap brackets.
Old October 27th, 2014, 09:03 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
I'm going to clean up all the dirt on Wednesday, I may get to it. It seems to be in strips. I'm a little nervous about taking it out, and yes it still seems glued down.
1965 IIa 88
98 Discovery LE7
2000 DII (SOLD)
Old October 27th, 2014, 09:28 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I'm worried...
Is this a '95 Classic?
Get a thick scraper of some kind and get that pad up for a look-see.
Rent my
Old October 27th, 2014, 09:43 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
I'm worried...
It's a 95 25th anniversary... I got most of the pad up, couldn't get to the bracket, but it is extremely clean under there all the way up to the bend.
1965 IIa 88
98 Discovery LE7
2000 DII (SOLD)
Old October 28th, 2014, 11:18 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
certainly is. on both my '93 and '94 the pad was not glued in place - could be a '95 deal?
I cut mine into small pieces and threw it out.
Then POR15'd everything to make sure no rust would continue as on the driver's side by the flap bracket there was rust.
------ Follow up post added October 28th, 2014 04:20 PM ------
Over the winter I'll pull the front seats, console, dash, carpets, and padding and go to town
wait a minute here - how can it be for sale when you're tearing up everything....
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old October 28th, 2014, 11:46 AM
roverguy's Avatar
roverguy
Robert
1995 RRC
After getting the back edge up the rest came up easy, just the edges appeared to be glued.
1965 IIa 88
98 Discovery LE7
2000 DII (SOLD)
Old October 28th, 2014, 12:26 PM
crown14's Avatar
crown14
Verticalscrote
It's for sale??
Old October 28th, 2014, 12:46 PM
I smell a thread hijack coming on....
Old October 28th, 2014, 11:17 PM
UKmtrsp
Chip
95 RR Classic
Console
Joel,
Great job on the truck!
I was looking to do something similar to the original center console on my 95 with some black spray on rubber coating. Wasn't aware that the disco console was a drop in. Can you review what year disco console will work and the modification steps...also what other dash/console/shifter/interior bits are interchangeable? Thanks
Sorry I missed URE this year....hope to catch you next year or at the Spring event.
Chip
Old October 28th, 2014, 11:49 PM
crown14's Avatar
crown14
Verticalscrote
Originally Posted by UKmtrsp View Post
Joel,
Chip
The 95 RRC console is the same as any D1 with automatic transmission and without power seats- only the Range Rover version was wrapped in textured vinyl. I didn't put a disco console in this truck, but if you wanted to, you would not need to modify it.
The shift indicator assembly is widely advertised as being the same as in the D1, 95 RRC, and 97 D90 but in reality the disco version is slightly different. The shifter itself and the knobs are the same. The console lid is interchangeable with any discovery model 1994 to 2004. The larger style cup holders that began showing up on 2002 discovery models fit perfectly, as does the dash cup holder delete, which I illustrated. The rubber mat on the top of the dash and the HVAC controls are the same as all Disco 1 models. The center dash facia panel, side vents, glovebox, instrument cluster bezel, passenger airbag, and driver side fuse panel door are all unique to the 95 RRC as is the dash pad assembly itself.
Old October 29th, 2014, 12:49 AM
UKmtrsp
Chip
95 RR Classic
Bezel
Thanks Joel,
What about the fit of the Disco window switch bezel....only D1?
Chip
Old October 29th, 2014, 02:42 AM
crown14's Avatar
crown14
Verticalscrote
Thanks Joel,
Chip
That fits Disco 1 or 2 but the rubber console mat has to come from a D1 with auto transmission to work in 95 classic.
Old October 29th, 2014, 06:59 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
It's for sale??
only kidding and wishful thinking on my part.
if you ever do though, I certainly would be interested.
Old October 29th, 2014, 07:45 AM
UKmtrsp
Chip
95 RR Classic
Parts
Thanks, I ordered most bits from your ebay page last evening...will order the switch bezel this morning. Great info...trying to keep the old truck on the road and looking good
Chip
Old October 29th, 2014, 07:47 AM
roverguy's Avatar
roverguy
Robert
1995 RRC
Doug (Roving Beetle) swapped in a Disco II dash into his RRC. From the pictures he posted it looked pretty good.
1965 IIa 88
98 Discovery LE7
2000 DII (SOLD)
Old October 29th, 2014, 08:36 AM
crown14's Avatar
crown14
Verticalscrote
Yeah I sold him that RRC! And look what he went and did to it! That truck wasn't a 95 though, it's a 93 so it had a different dash to begin with. It was not a direct swap, he has done lots of fabrication to get it to fit. Doug's a good guy, I got my quarter panel and some other hard to find parts from him. Plus he builds million dollar boats or something like that so he was able to make his own parts when needed.
Old October 29th, 2014, 11:04 AM
crown14's Avatar
crown14
Verticalscrote
Chip
I put some additional stuff in your box that you might need...
Old October 29th, 2014, 11:22 AM
roverguy's Avatar
roverguy
Robert
1995 RRC
This thread has been great, hopefully this spring I will start a thread on mine, pulling the seat ecu while I still have full control of everything
1965 IIa 88
98 Discovery LE7
2000 DII (SOLD)
Old October 29th, 2014, 11:40 AM
crown14's Avatar
crown14
Verticalscrote
Before I forget I should probably list my current issues
Drivers seat belt "button" missing
AC inoperable
Driver's lower door hinge issue
Rattle in RH lower dash area
Some of the "new" door seals not working great
A few switches in the dash not working (dome light, etc)
Radio back light out
Catalytic converters rattling
To do list
Instrument cluster bezel repair
Strip and powder coat roof rack
Finish detailing chassis/wheel wells
Trim/reinstall front valance maybe?
Replace steering linkage components and align
Maintenance
Renew cooling system components, thermostat, all hoses, etc
Evaluate condition of brake discs and pads, wheel bearings, etc
Replace brake hoses
Replace power steering hoses
I'm seriously considering refinishing the original alloys and using them instead of the steel wheels. Or painting the steelies white. Or maybe white wolf wheels.
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
