'95 Classic - Page 10 - Defender Source
Old October 16th, 2014, 09:45 AM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Originally Posted by crown14 View Post
... Also testing a new paint product, and I am very curious to see how it holds up...
What's the paint product you're testing?
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old October 16th, 2014, 10:14 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I just tried Master coat chassis paint a while back and it works awesome!! Way better adhesion and more versatile then POR. What is the product your using?
Old October 16th, 2014, 02:33 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
No more free advertising for products until they prove their worth, but don't worry- we'll name it when and if.
Old October 16th, 2014, 03:23 PM
crown14's Avatar
crown14
Verticalscrote
One week till the trip to Uwharrie...
Old October 16th, 2014, 04:15 PM
crown14's Avatar
crown14
Verticalscrote
Once you go black...
Old October 16th, 2014, 07:24 PM
crown14's Avatar
crown14
Verticalscrote
Well damn.
When I took it apart, one of the (four) torque converter bolts broke right off. At the time, I didn't care- I didn't want to reuse the converter off a bad transmission anyway. Well, turns out since my donor vehicle was a GEMS D1, which uses a completely different flywheel, I HAD to reuse the converter (or find another like it). So, I drilled out the broken bolt, made sure all the threads were in good shape, and painted it green for a laugh. The transmission itself couldn't have gone back in more easily, probably took 10 minutes. But the converter bolts... oh man. On the third out of four, it wouldn't thread and galled the threads. Willing to risk running with three, I moved onto the last one- which snapped right off halfway in. Fuck.
So the trans has to come back out and I will be finding another converter.
On a more positive note, I did make an effort to finish up something else productive, the door sill plates.
Snagged some off a Discovery LSE... only year and model with this style. They are a direct fit to the RRC (swb only)
Added Discovery II filler strips to hide the screws. End result very nice I think.
Also I found a replacement rear differential with a Detroit locker, and it's local too, but the guy is a real jerk and won't sell it to me!
Old October 16th, 2014, 07:43 PM
I assume you probably already know this, but I'll mention it anyway. Its important to start all of the torque converter bolts before fully threading them in, as the torque converter will slightly cock making it difficult to start the last two bolts. Sorry that happened to you, I'd be livid!
Old October 16th, 2014, 07:57 PM
crown14's Avatar
crown14
Verticalscrote
Yeah I know the drill, but it's strange. I've been through this dozens of times, and for that matter, taken hundreds of these apart, and I don't think I've never broken a converter bolt off like that. I was pretty pissed at first, but like I said, I REALLY did not want to reuse a converter off a trans that had eaten the reverse clutches anyhow. This is just the truck forcing me to go back and do it the right way. There is a company in downtown Raleigh that warehouses tons of transmission rebuild parts, converters, etc. so I will call them in the morning. If that doesn't work out, I think I know a guy local who has one in his stash.
Old October 17th, 2014, 03:08 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
does look nice and it is really different than the 94 backwards ones.
my 94 had a plastic strip which I replaced with the aluminum one from the 93.
doesn't say Land Rover on it though...
------ Follow up post added October 17th, 2014 07:10 AM ------
94 and earlier not backwards. not sure what I was thinking
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." Mr. T. Jefferson
Old October 17th, 2014, 05:07 PM
crown14's Avatar
crown14
Verticalscrote
Ok back on track now.
Old October 17th, 2014, 08:57 PM
Carolina blue, glad you found a newish one
Old October 17th, 2014, 09:11 PM
crown14's Avatar
crown14
Verticalscrote
Transmission is in and mounted, new motor mounts installed, transfer case to follow...
Old October 17th, 2014, 10:51 PM
jag v12 mounts or "oem"
i just jinxed myself...
Old October 18th, 2014, 07:41 PM
crown14's Avatar
crown14
Verticalscrote
Because I kept the RRC parking brake, I had to re drill the top two holes...
Lots of progress otherwise. Shifters, cooler lines, driveshafts, etc.
Old October 19th, 2014, 01:25 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Really looking good!
Old October 19th, 2014, 12:13 PM
crown14's Avatar
crown14
Verticalscrote
Slide under the truck this morning and I'm really not happy with the transmission mount.
Loosening it relieved the obvious tension on it, but it was still exposed. Originally there would have been a heat shield. Long gone. Here it comes! Another D2 heat shield mod!
D2 used two different transmission heat shield styles. My preference is on the right.
Slight modification needed, just cutting a slot in it is all.
Slid it in, tightened the mount back up, much better.
I also replaced a couple of needed exhaust manifold flange studs, as exhaust replacement, crossmember, and refilling fluids are on the list for today.
Old October 19th, 2014, 08:01 PM
crown14's Avatar
crown14
Verticalscrote
OK all buttoned up, except for the wheels/tires and the console. Runs and engaging gears, but the transfer case seems to be stuck in neutral? Haven't figured it out yet.
Old October 19th, 2014, 10:34 PM
crown14's Avatar
crown14
Verticalscrote
With some help from my lovely wife I'm happy to say
IT'S ALIVE!
Old October 19th, 2014, 11:25 PM
Time to rename this forum RRSourCe
Old October 20th, 2014, 01:48 AM
Blueboy's Avatar
Blueboy
James Thompson
1994 RR LWB
Looking forward to seeing it finished!
What is the sales price again....
95, classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
