'93 Classic - Defender Source
Old August 18th, 2014, 10:21 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
'93 Classic
Putting a 300Tdi in my '93.
ZF is already in the truck.
Changed my kickdown cable yesterday wich wasnt terribly bad.
Made a xerox of the valve body diagram and punched holes for all the bolts so I wouldnt mess up the different lengths.
On another note--
Bolting the torque converter??
WTF dude....these bolts are impossible to access!?
I'm going through that bottom access door as it is bigger than the starter access(17mm socket wont even fit there...)
Literally had to grind down my socket and make it "thin-walled" to fit...
Anyone done this?
My cool trans bolt diagram on a shoebox lid so I could just punch holes to hold bolts.
Starter access.
Bottom access in front of sump.
ID:	101105   Click image for larger version
Rent my
Old August 18th, 2014, 10:45 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You using the V8 ZF or the TDI ZF?
RDavisinVA
Old August 18th, 2014, 11:28 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Its a TDI ZF... but someone previous to my ownership had put a gas kickdown cable on---too short!!
So I had to change it out after I put the trans in the truck.
It just seems really difficult to bolt up the torque converter---am I missing something?
Rent my
Old August 18th, 2014, 11:54 AM
I have always used a long box wrench
Old August 18th, 2014, 02:00 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I cant see how that would work.
I have to use a 17mm socket(ground into a thin wall) and there is no room to work.
The shortest extension and the ratchet is in the sump---no extension at all and the socket is so deep it almost comes off the ratchet.
The socket wont even fit through the notch by the starter access so that's a no-go.
I got 2 bolts into the torque converter through that bottom access door and called it quits after that.
I'll try and finish the other 2 bolts this week...<sigh>
Of course, is it possible there is a different bolt? The diesel torque converter uses the same size bolt(thread) as the V8 but is it possible they have a smaller bolt-head?
That's why I had to grind the socket thin; the bolt faces come so close to edge of the flywheel...
Rent my
Old August 18th, 2014, 06:49 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Well, mystery is solved.
The 300Tdi(and D2s,P38s) uses a 14mm bolt WITH A SHOULDER to the torque converter.
Thats why I'm having a hell of a time fitting the older V8(17mm) bolts in there...
Rent my
Old August 18th, 2014, 07:06 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Will you have this ready by EXPO?
Old August 18th, 2014, 07:41 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Mark...I hope to have it ready by URE.
We'll see...
Rent my
Old August 18th, 2014, 08:16 PM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
Glad to hear about your progress! The bolts are a bit problematic but I didn't think they were THAT bad...glad you figured it out!
My 93 lwb is getting an isuzu 3.1 tdi & an r380. The install begins this week! Just waiting on the last couple of pieces in the mail as everything is pulled, cleaned and ready for reassembly.
Happy wrenching.
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old August 19th, 2014, 09:10 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Thanks, Frank.
I wish I'd remembered the D2 style torque converter bolts---I've helped pull and replace a D2 motor at least 3x-once on my own truck.
Kinda wish I'd done a manual transmission but I'm too far in to go back now.
I still have a million little things to finish up, but at least I got the motor bolted to the ZF last night.
Rent my
Old August 20th, 2014, 09:25 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
TDi injection pump experts---
What is this blank threaded hole below the upper right torx bolt?
Because I'm going to use it for my bracket unless that is forbidden...
ID:	101292   Click image for larger version
Rent my
Old August 20th, 2014, 10:05 AM
so if its in and bolted up have you fired it up yet ?
Old August 20th, 2014, 10:31 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
ha ha ha ha ha ha
um no...
Rent my
Old August 29th, 2014, 10:36 PM
Greenbull's Avatar
Greenbull
Mark Miller
We'll see...
Good, I can't wait to see that zf tranny hookup....
Old August 31st, 2014, 09:07 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Got her to run tonight.....for 30 seconds.
Shut it off to check for leaks and whatnot.
It stinks, too.
Diesel fumes in the garage....
Need to clean out the garage so I can move it out a bit.
Rent my
Old August 31st, 2014, 10:04 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
My creative piping for turbo to intercooler over the LWB front shock mounts...
No A/C compressor yet...RockShow has a working Disco compressor he's going to give to the cause...
ID:	101890   Click image for larger version
Rent my
Old August 31st, 2014, 10:08 PM
It stinks, too.
Welcome to the dark side
Old August 31st, 2014, 10:42 PM
Mtanzania
Frank
I love that smell!
94 D1 300tdi - Sold
Old August 31st, 2014, 10:46 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Cool. You'll love it offroad, I ran mine all over Uwharrie when it still had the sway bars on and no lockers and it was a blast. With the sway bars off it was ridiculous, it would just keep going as long as the tires had grip, I found that it did quite well without the CDL engaged too, a little more maneuverable. The TDI/auto isn't as prone to wheelspin as the V8 either, so much easier on axles, etc.
Have you got a muffler on it?
Old August 31st, 2014, 10:54 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
After Doug's (and my) weekend motor swap on my 110 I can't how nervous I was when we fired it up! But that shit was bad ass!
classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
