'93 Classic - Page 7 - Defender Source
Old November 23rd, 2014, 02:07 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Any of you Classic guys know what this little wired box is?
In front of the washer bottle beside the charcoal canister...
Also, do the small copper washers from D2 oil drain plugs fit the 300tdi?
I have a bag of them and can't find out till the next oil change...
Rent my
Old November 23rd, 2014, 02:37 PM
I'm pretty sure they don't. I think I tried and ended up just using some generic copper washers I found in my tool box.
Old November 23rd, 2014, 02:57 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
D2 drain plug had aluminum washers
Old November 23rd, 2014, 03:12 PM
No clue what that thing is. Not stock.
Old May 5th, 2015, 10:33 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
update: finally broke off the one remaining "HOLD" tab.
Crown14, what is the process for removing/replacing these?
I assume drilling those small rivets comes first.
Rent my
Old May 5th, 2015, 10:37 AM
Stupidest part on the vehicle. Made to break.
Old May 6th, 2015, 11:04 AM
crown14's Avatar
crown14
Verticalscrote
They are designed to break. Also intended to keep your hands clean/dry instead of forcing you to touch the dirty tailgate.
Remove the #1 Phillips head screws, then drill out the rivets in the retainer strip.
Old August 2nd, 2015, 10:17 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Finally got my parking brake drum problem remedied today.
If you're putting a 300tdi in a Classic you'll need the later style parking brake/cable setup.
Mine originally had the old style cable anchored on the passenger side of the LT230.
This cable is infringed on by the Tdi crossmember.
I pulled the drum and brake mechanism off and found where all the gear oil had been going...
I didnt have any seals....but I did have a spare LT230 that I had changed the rear output bearing and seal in a few years ago before that truck was parted out.
Leaky one on left; hopefully non-leaky one on right.
Rent my
Old August 2nd, 2015, 10:31 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I use Right Stuff to seal the output housing to the tcase.
Rent my
Old August 2nd, 2015, 10:34 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
X2. Right Stuff is awesome!
Old August 2nd, 2015, 10:42 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Oh yeah, the Right Stuff is great.
After it sets up, I can pull these bolts out and use 'em on another project.
Right Stuff is just that good.
Here is the newer style parking brake with the cable that comes out towards the drivers side.
It also just has a rubber type end that sticks through to the handle.
I don't know what year trucks had this style but I'd like another one.
Rent my
Old August 13th, 2015, 09:14 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Got to try my new spring retainers last weekend.
Paracord is strong stuff.
I think Fireman Short was jealous that he doesnt have coils that fall out...
Rent my
Old November 5th, 2015, 07:35 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Found my oil leak.
AND... I replaced this o-ring 13 months ago!!
Should this be an annual replacement??
Jeeez.....
Rent my
Old June 5th, 2016, 08:14 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
---should my water pump be this loose??
Rent my
Old June 5th, 2016, 09:09 PM
are you home or still on the OBX ?
Old June 5th, 2016, 09:31 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
LOL- home now- water pump decided to get loosey-goosey outside of Richmond--
AAA finished up the ride-you know, a Rover in its natural environment= a rollback!
Rent my
Old June 5th, 2016, 09:35 PM
I'm sure your wife was thrilled
Old June 5th, 2016, 09:43 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
No, she's still down at the beach with the Excursion!
Rent my
Old June 5th, 2016, 09:44 PM
Bullet dodged then
Old June 6th, 2016, 07:17 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Damn!
classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
