'93 Classic - Page 6 - Defender Source
Old October 29th, 2014, 06:27 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Jeff just put the catch can on. The oil+vapors go in, and the oil gets caught in the steel wool and runs down to the bottom of the can (you periodically drain it from the plug in the bottom) while the vapors come back out and go in the intake. Kind of like the flame trap on the V8 distributor engines.
Old October 29th, 2014, 06:58 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
This little catch can showed up from Buckhorn Imports today along with my repaired seat base.
Thanks!
Putting the can on tonight.
I'll put it where the gas charcoal canister used to live.
Originally Posted by Jymmiejamz View Post
I would guess that you would need to connect the two wires for the sensor, or disconnect them depending on how the circuit works.
I was afraid of that... I think the wiring is hard to get to...
Rent my
Old October 29th, 2014, 07:02 PM
You don't necessarily have to do it at the connector. Just find the wires in the harness further back. You could also just remove the bulb.
Old October 29th, 2014, 08:46 PM
crown14's Avatar
crown14
Verticalscrote
What if you pull the "plung-o-cap" out of the washer bottle and rig it? Zip-tie?
Old November 4th, 2014, 10:03 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Pulled the sump on Saturday; cleaned and resealed with Right Stuff.
Will T told me after 24 hours you can remove the bolts and use 'em for something else...
Added the oil catch can for Crown14 and routed the pcv hoses.
No leaks after 2 days.
I'm defintely pulling the pan if/when the trans or motor has to come out again-look at that access to the flywheel bolts!
Name:	Tdi oil pan 009.jpg
ID:	106341   Click image for larger version
Name:	Tdi oil pan 010.jpg
Name:	Tdi oil pan 006.jpg
ID:	106343   Click image for larger version
Name:	Tdi oil pan 005.jpg
Rent my
Old November 4th, 2014, 10:18 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I also put a new fan resistor in...this is my third one(not same truck) and I did it a little differently.
The harness of the old one was still ZIP-tied so I could not get it loose.
I cut it right at the old resistor and soldered/shrinkwrapped the AB replacement right there in place.
Not much working space...
What are you RRC guys using as replacement filter material?
I cant remember what this stuff is, but I put it in about 3 or 4 years ago and it still looks great.
Name:	RRC HVAC resistor 001.jpg
ID:	106345   Click image for larger version
Name:	RRC HVAC resistor 002.jpg
Name:	RRC HVAC resistor 003.jpg
Rent my
Old November 4th, 2014, 10:24 AM
crown14's Avatar
crown14
Verticalscrote
Great question on the filter media, it's been on the back of my mind. The vents are different on a 95 and supposedly the earlier filter inserts won't work... but I have not gotten that far yet.
Old November 4th, 2014, 11:36 AM
Pine straw
Old November 4th, 2014, 01:24 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by o2batsea View Post
Pine straw
That's odd, my previous owner was using a mixture of oak leaf and maple leaf.
Rent my
Old November 5th, 2014, 06:05 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
bugger...
any good ideas?
Rent my
Old November 5th, 2014, 06:21 PM
crown14's Avatar
crown14
Verticalscrote
Myself, I would just swap out the entire rear axle housing and spend the time I would have spent drilling that out cleaning, painting and replacing bushings. But that's just me.
Old November 5th, 2014, 06:26 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
LOL -crap
Ive got the hub off now so I can get access from the outside.
I think I can drill the bolt, thread a smaller grade 8 into it, and work it out...
Rent my
Old November 5th, 2014, 06:43 PM
LOL -crap
http://www.zoro.com/i/G3268587/?utm_...FUlk7AodjVgAiw
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old November 9th, 2014, 02:09 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Brake caliper still on; tapped the broken bolt for a smaller bolt...for now.
Got the throttle cable replaced.
Also checked the pcv hosing and can.
After a week there is a small leak at the rear but nothing like it was before...probably the rear seal or crucifixes... which will wait.
Rent my
Old November 9th, 2014, 02:14 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Got the front radius arms/rubber bushings replaced.
Now I'm running non-bump radius arms on a former EAS truck...just feels so wrong.
Rent my
Old November 13th, 2014, 10:32 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Replaced the rear rubber tri-angles.
Suspension feels much better.
Question for Bill and Joel et al:
What maintenance do you recommend for my LWB rear windows/regs?
Both work, but a little slow...
Also, what's the current status on LWB rear window parts?
Last I heard it was NLA...
Rent my
Old November 13th, 2014, 10:35 AM
crown14's Avatar
crown14
Verticalscrote
Grease up the regulators. The guide channels I use silicone spray. In the older trucks I've seen weak motors cause slow operation but your 93 seems too new for that.
Old November 13th, 2014, 10:53 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Silicone spray-I've got some of that.
They're not super slow, but it could just be regulator drag.
Are 93-94 rear LWB regulators still out there?
Rent my
Old November 13th, 2014, 05:03 PM
crown14's Avatar
crown14
Verticalscrote
Jeff did you fix your brake light switch?
Old November 13th, 2014, 07:36 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah, it had gotten knocked slightly out of place-put it back in correct position and its been good.
Rent my
classic
Wife wants a Range Rover Classic SWB mdmccallum Defender Technical Discussions 13 February 14th, 2005 03:48 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
Need to sell fast...Well Equiped Range Rover Classic RedRhinoProducts For Sale - Vehicles 0 November 20th, 2004 02:21 PM
Sweet classic BMW , partial trade for ST outwest For Sale - Vehicles 1 October 9th, 2004 07:12 PM
'92 Range Rover Classic Workhorse RedRhinoProducts For Sale - Vehicles 2 September 27th, 2004 06:51 PM
