91 Range Rover Classic "Silver Surfer" - Page 6 - Defender Source
Old January 16th, 2015, 07:51 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Originally Posted by ukoffroad View Post
What are you asking for it?
PM Sent
Old January 16th, 2015, 07:53 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Originally Posted by WeBeCinYa View Post
I am at a loss and ready to throw in the towel. Let's start from beginning...
Ordered rebuilt ZF4HP22 from Rover land Parts. Found tranny shop locally that has done RR, Volvo, BMW, Mercedes rebuilds to replacement. Shipped tranny to shop, when it arrived discovered the torque converter was not in the tranny/crate. Had to wait a day for it to be sent again. Once it arrives, shop has it for a couple days, refits new tranny, new gear oil, I go pick it up. Drives GREAT home on the 25 mile journey. Shifts like brand new through all gears. Go out today, jump in, put it in reverse and it slams into reverse hard, but reverse works. I drive it around to a few errands, and reverse again and it seems ok, now that its warm. Drive another hour around and when I get home I park it, and put in reverse again to see if it would shift into that gear smoothly, and I hear an awful noise as it goes into reverse. I proceed to drive in reverse and it barely reverses. It will go, but its clearly slipping.
Shop that did work only covers their rebuilds, RL Parts only covers parts, no labor. So looking at another 10+ hour job at $85/hr to get this removed/replaced and fixed, IF it can be. I'm over it and ready to get back to something else.
Ready to cut my losses, its for sale.
To the new owners: I can supply a good Transmission, remanufactured converter, new kick down cable, filter/pan gasket, new mounts, etc. Even have a LT230 for transfer case conversion if so desired.
Old January 16th, 2015, 08:24 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
To answer some questions on what I've done...
-New fuel pump
-Replaced both fuel pump relays
-Put slightly used (1k mikes) BF Goodrich tires on
-Replaced driver side brake lines, front driver side lines under hood.
-Replaced ABS pump with used working one
-Swapped transmission with rebuilt one that seems to have reverse issue.
-Oil change
Needs:
-Front floorboards where mud flap mounted needs replaced.
-Rear hatch lock needs repair
-Rear window shocks
-Needs new Cats, found direct fit Y pipe for 350
-Paint/clear coat faded on top/tailgate
Leather interior is 9/10
Typical cracking of wood grain
Hunter gun/dog rack in rear
Engine runs strong
All electrics work except passenger seat forward/back
Recommend anyone interested come drive and check it out. Open to offers.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old January 16th, 2015, 09:15 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
That's too bad...there has to be another way!
Old January 16th, 2015, 09:46 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Tell me about it. I'm just the one that paid for tranny and install, and reverse doesn't work right. I don't see the shop throwing their hands up saying "It was our fault we'll take care of it." And RL Parts would probably supply any parts deemed bad, but getting there and back is 85/hr. It took 10 hrs to get old out and new in, so at least that same amount of time plus repair. I can't justify it. I took the risk, didn't work out. Someone who has the time/expertise to pull tranny and sort out the reverse issue is going to get a great deal.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 17th, 2015, 10:56 AM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
I am at a loss and ready to throw in the towel...
Sorry to hear about your project truck. I know your pain, though I'm too stubborn to quit on my RRC, too much damn sentimental value tied to it. I think you're fortunate that you can cut bait and spare your bank account.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old January 17th, 2015, 11:56 AM
UKmtrsp
Chip
95 RR Classic
Matt,
Thats a tough spot. Not sure what your total $ is at this point, but at least you know what you've got and know what needs to be done. A different project truck will involve the same sorting process...some good and some bad. My thoughts here would be to suggest that you find a project that is mechanically sound and only needs cosmetics. As cosmetics won't keep you off the trail. Pretty and clean is not practical for a trail rig. Case in point is my Hunter which has a bunch of trail rash and dented panels...who cares. If your trying to get away from automatics then you might need to go to a earlier Series truck or Defender, or go the way of a Jeep or Toyota....say it ain't so...Your situation is not the norm as very few LRs have trani trouble, especially if serviced regularly. You've come this far. Maybe you just need to take a breath and think about it a while.
Old January 17th, 2015, 01:37 PM
pl626's Avatar
pl626
Peter
Originally Posted by UKmtrsp View Post
M... Maybe you just need to take a breath and think about it a while..
Chip - you're wise beyond your years... x2 on Chip's advice to take a breath and percolate...
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Old January 17th, 2015, 01:44 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I'm off the ledge. Took it back to tranny shop this morning. Drove great until it got hot then reverse started acting up. Left her there and they will dig into it next week. I'm going to have whatever it needs fixed to correct. In the meantime I leave for Palm Springs, CA Monday for some R&R. Talk about great timing!
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 17th, 2015, 09:12 PM
Man I hate to hear that, pulling transmission is a pita for sure. I was pretty down on my RRC recently, did some work and now it makes me smile again.
Old January 17th, 2015, 10:37 PM
UKmtrsp
Chip
95 RR Classic
And he's back in the game!
Old January 18th, 2015, 12:01 PM
pl626's Avatar
pl626
Peter
AKA, Moneypit...
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Old January 21st, 2015, 05:36 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Nothing like some sand to take your mind off the transmission issues in VA!
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 23rd, 2015, 08:20 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Update: Rover Land parts is rebuilding another tranny for defective replacement and will be shipping it up for install. I'm impressed with their customer service so far. Hope to have this all sorted in the coming week or so.
California was a blast and much needed! Another pic of the fun in the dunes.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 26th, 2015, 08:06 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Another rebuilt transmission being sent up Wednesday for install. Ordered new direct fit Y pipe with cats today for replacement while they are in for the tranny. Ready to get her back on the road!
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 26th, 2015, 08:11 PM
Bill Larson
Bill Larson
Out freakin standing Pyle! We look forward to seeing the Surfer ride again!!
Old January 26th, 2015, 09:00 PM
UKmtrsp
Chip
95 RR Classic
Old February 14th, 2015, 07:17 PM
crown14's Avatar
crown14
Verticalscrote
Any update?
Old February 15th, 2015, 03:44 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Originally Posted by crown14 View Post
Any update?
Hopefully this week...
Old March 4th, 2015, 05:16 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Sold, new owner may or may not chime in. Thanks for all that helped and advised!
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
range rover, classic
FOR SALE: 1989 Land Rover Range Rover Classic (lifted) Rovercox For Sale - Vehicles 33 May 28th, 2014 09:44 PM
FS: Land Rover Discovery I, Range Rover Classic, Defender custom HD Radius Arms RadiusArms4Sale For Sale - Parts 4 November 7th, 2012 12:15 PM
TWO STAINLESS CAP LAND ROVER LUG NUTS- FITS DISCO I-RANGE ROVER CLASSIC-D-90 Alloy NashvilleRover For Sale - Parts 6 December 31st, 2011 08:10 PM
1995 Land Rover Range Rover Classic SWB NRO For Sale - Vehicles 4 April 3rd, 2011 10:18 PM
