90 Face frame swap and LHD conversion - Page 2 - Defender Source
Old January 21st, 2013, 09:02 AM
winn442's Avatar
winn442
Winn Bearden
I know you've got a while before you have to worry about this, but it looks like a Disco 200 so make sure you fab up your steering shaft before you put the left wing on, helluva lot easier.
I envy you, wish I had the time to do ground-ups.....nowadays it hard to find time just to rotate the tires....
Winn Bearden
Old January 21st, 2013, 07:25 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
So today I removed the old motor mounts and welded up the new ones for the 200 tdi on the NAs frame. Removed everything from the frame and assembled everything for sand blasting. The truck is loaded up with the frame and suspension ready to first thing in the morning. Tomorrow dropping everything off and then starting the break down of the bulk head, gonna try and get the tub, flooring and channels to the rhino liner by the end of the week.
ID:	64928   Click image for larger version
ID:	64931   Click image for larger version
Old January 22nd, 2013, 08:09 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Sooo, still rocking and rolling! Dropped off everything at the sandblasters this morning, should be ready Friday for pick up. For today I got the rear end out and wish bone as well. Here are some pics of the old frame and where its at on the break down and some pics of the rot. The green tub is the 97 NAS, I have it just sitting on the frame to to some work on it.
ID:	64967   Click image for larger version
ID:	64969   Click image for larger version
ID:	64971   Click image for larger version
ID:	64973   Click image for larger version
Old January 23rd, 2013, 06:08 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Lazy day, went to my upholster to drop off my lower and upper dash to get worked on. I also met with my paint guy to nail down the paint code to get the material ordered. Came home and broke down the bulk head, still need to power wash and dynamat before taking it to paint.
Old January 23rd, 2013, 06:48 PM
What are the bolts on the back of the frame for?
Old January 23rd, 2013, 07:18 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by Brewie212 View Post
... still need to power wash and dynamat before taking it to paint.
You're going to dynamat before painting? Interesting.
MUDSUX
Old January 23rd, 2013, 07:43 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
That is my old frame, I made my own rear cross member that bolts on and off.
------ Follow up post added January 23rd, 2013 07:48 PM ------
Paint has a cure time of 6-8 weeks after spraying, even longer this time of year, before you should rhino line or dynamat. Other wise the paint will peel. Lay it first and paint over and you seal everything and you don't have to worry about it peeling, or water damage. I am going to dynamat the whole tub before rhino lining as well.
------ Follow up post added January 23rd, 2013 07:49 PM ------
What the hell is that grey piece of steel hanging on the wall to the right.
-Jeff
Haha, something shot on my last hunting trip! Nah, it's the front clip from my last project that was left over.
Old January 23rd, 2013, 09:00 PM
I do not recommend dynamat for a defender. It's expensive and does almost nothing for the noise in a defender.
Maybe others have better experiences with it than I do.
Old January 23rd, 2013, 09:06 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I've used in several applications in old jeeps and first gen broncos. If done properly it makes a world of difference in the decibel level. It is expensive, and worth every penny!
Old January 24th, 2013, 10:27 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Is it too early to nominate this truck?? LOL
Old January 24th, 2013, 10:42 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I did not use dynamat because of the cost but the roofing material from lowe's instead. Much cheaper and is basically the same thing as dynamat. I for sure think the truck is quieter with it. How much I have no idea but even my wife noticed it.
Old January 24th, 2013, 06:12 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Nominate for what?
Old January 28th, 2013, 08:43 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Ok, so things have slowed down now. Waiting on chassis to come back and body from paint. This weekend will probably be balls to the wall! So far I dynamated both sides of the bulkhead, the floor panels. Chanels, doors and the bottom of the tub. When I pick it up from paint it will be going straight to get rhino lined, inside and the under body. The rear end is ready for a coat of Por 15, and the front housing will be built hopefully tomorrow. Got my 300tdi intake and exhaust manifolds in today!!!! Next week if all goes well, Ill be overhauling the motor, detailing it and getting a fresh coat of Por15. I will also be workin on my front exo cage!!!
ID:	65401   Click image for larger version
Old January 29th, 2013, 08:06 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Funny how I have to fabricate my own panels for my body guy. The rear quarters are shot so I fabed up a new set, along with new side panels for the hard top. I think I went a little over kill but I used .080 thick and dynamated as well. This sucker is going to be solid!
ID:	65444   Click image for larger version
ID:	65446   Click image for larger version
Old January 30th, 2013, 02:51 AM
durt d1ver
BrianFennessy
04 d2
Looking good, can't wait to see it finished
Old January 30th, 2013, 09:47 AM
awesome, its really moving a long.
Old January 30th, 2013, 07:00 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Today was a funny day, first I knocked out my wing tops. I still need to cut out the vent holes, and powder coat them satin black. Love the idea of them but I hate the checker plate. I finished breaking down the front end pressure washing and getting ready for Por 15 this weekend. While breaking down my front wing the bondo broke off. Man this guy put a half inch of bondo on the whole front fender. Glad I am replacing all the front body panels along with doors. Here are a few more pics.
ID:	65489   Click image for larger version
Old January 30th, 2013, 07:32 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Ha. That bondo pic at first glance looked like bacon.
1970 SIIA 88, Sold
Old January 30th, 2013, 10:45 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
you need to hang one of those bondo chunks up on the wall! I dont think ive ever seen it that thick.
-Jeff
$5 and Ill send you one!!! Rare chance to own one of the thickest pc of bondo to ever to fall off a land rover! Don't pass this by only two available!! This is a chance of a life time.
Old February 2nd, 2013, 08:24 AM
Wow! A fiver wouldn't cover the shipping! When you started I was wondering why you were restoring your truck...now I know why!
90, ac, conversion, lhd
NAS 90 ST to a import 110? don Defender Technical Discussions 13 August 23rd, 2012 06:40 PM
Axle swap 90 and 110 101 tomaco1 Defender Technical Discussions 6 November 22nd, 2010 08:27 PM
diesel swap in petrol LHD with AC and PS kjva Defender Technical Discussions 7 April 22nd, 2010 08:04 AM
Question about LHD VS. RHD Turbofan Defender Technical Discussions 6 August 31st, 2009 04:58 PM
RHD to LHD swap & respray LenB Smaller Projects 11 July 24th, 2008 06:02 PM
