'87 110 Refresh, Restore, Rebuild and Update - Page 8 - Defender Source
Join the Defender Source Community Today
Old June 29th, 2016, 09:42 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Pulled my frame out of the warehouse and drug it home. Quite a battle to get it in the garage!
Going to be working on it pretty much all weekend, so expect some solid updates over the next few days!
Old July 3rd, 2016, 09:44 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Busy couple of days. Met with my painter to confirm plans to paint the frame (doing it in my garage on Tuesday), so until then, I can start working on redoing all of the wheel bearings and seals!
Oil is leaking from every single axle, so I figured it would be best just to dig into it. From my quick inspection, the interiors look good - no major rust or anything, so it should be in pretty good knick.
Like most everything, removing, wire-wheeling, painting/repairing, is the mode of operation. Replacing hardware, seals, gaskets, and bearings as we go.
ID:	153040   Click image for larger version
ID:	153042   Click image for larger version
ID:	153044   Click image for larger version
Old July 4th, 2016, 06:45 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
... and finished up one side. What a pain, but now on to the other side!
Also replaced the front diff seal, as it was leaking a little bit.
Tomorrow - finish up the other side of the axle and possibly get the brake lines redone before the painting of the chassis at 6pm!
ID:	153097   Click image for larger version
ID:	153099   Click image for larger version
ID:	153101   Click image for larger version
ID:	153103   Click image for larger version
Old July 5th, 2016, 06:08 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
And now the chassis is painted. I'm going to hell for painting a galvy chassis, right?
Just wanted an extra layer of protection to prevent things from chipping/rusting, and my painter came to my house to do the job. Bonus!
ID:	153164   Click image for larger version
ID:	153166   Click image for larger version
Old July 5th, 2016, 09:48 PM
Naah, probably smarter than not painting.
Looking good.
Good meeting you today, and thanks for the beer!
Originally Posted by pendy
I'm here for the D's
Old July 5th, 2016, 10:13 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Looking good.
Good times! And remember, the race is on!
Old July 7th, 2016, 09:38 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Slow night tonight, but still made some progress. Ran fresh brake lines for the rear axle, and changed out some small fittings.
ID:	153338   Click image for larger version
Old July 11th, 2016, 11:37 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Major surgery on the front axle in the last few days. Learning the ins and outs of swivel replacement is interesting to say the least. I'm only planning on keeping the main swivel housing, but pretty much everything else is being pitched (brakes included).
Note to anyone else tackling the swivels: make sure that you put the rear oil seal, gasket, and lock plate on BEFORE the swivel goes on, and further, make sure that the gasket and lock plate are oriented properly. IT WILL ONLY FIT ONE WAY
Still need to test the end float, torque down the bearing to get preload and setup all of the lock washer stuff, but this corner is almost done!
ID:	153648   Click image for larger version
ID:	153650   Click image for larger version
Old July 13th, 2016, 09:39 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Hustled this evening and was able to get the whole right front rebuilt and cleaned up. Good thing for 15-minute enamel!
You can clearly see that the swivel on this side is shot.
ID:	153801   Click image for larger version
Old July 13th, 2016, 10:04 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Looking good
Old July 13th, 2016, 10:44 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Originally Posted by Wilboro View Post
Looking good
Thanks. Slow. steady progress! I'll need to retorque a few things one I get the radial arms bolted up, but need to figure out if I want to buy the front swaybar mounts now and weld them on to the axle or wait a bit.
My gut tells me do it now.
Old July 14th, 2016, 09:12 PM
At the risk of spuring you on - nice work!
Old July 15th, 2016, 11:12 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Didn't do too much in the last 36ish hours. Got the wheels put on the front axle and the harness pulled through the chassis. The later took a bunch of time to get the fish tape fed through the right path in the chassis.
Tomorrow, I need to go to the post office to pick up my package of ball joint covers from Bulgaria (I kid you not) which I will attempt to use as a gaiter for the upper ball joint in the Boge unit. The proper part is no longer available (of course) so I'm going to try to improvise.
Assuming it works, I'll get the Boge all assembled and bolted up, just awaiting a replacement axle bracket from the UK by the end of next week with the latest round of parts shipment!
ID:	153903   Click image for larger version
Old July 16th, 2016, 07:34 AM
Eric, everything looks nice and clean and you are doing a thorough job. I would suggest turning that 3 way brake junction 90 degrees clockwise as viewed from the top. The flex should come out of the leg of the T and the lines to the wheels come out of the arms of the T. That way the lines themselves can be routed tightly along the casing so as not to get caught by on road or off road debris.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 16th, 2016, 08:11 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
Interesting. I redid it exactly as it came off of the truck.
Old July 17th, 2016, 03:51 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Had a bit of time in the garage to see how on-measurement the "hand built" Richards Chassis was. Well, turns out that the R380 crossmember was about 5-6mm too long. So out comes the angle grinder and welder!
ID:	154000   Click image for larger version
ID:	154002   Click image for larger version
ID:	154004   Click image for larger version
Old July 17th, 2016, 04:05 PM
You should have just spread the frame a bit with a jack!
Old July 17th, 2016, 04:22 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Nah, that would be way harder and would have damaged the paint for sure. Remember, this frame has thicker steel than OEM, so I'm sure that some of the variability is associated with that.
Old July 19th, 2016, 08:20 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Received the YRM front swaybar brackets and got them all welded up. The RHS bracket needed a little work to get it just right, but overall fitment is great!
The front swaybar setup (amongst other things) should be arriving tomorrow so we can keep plugging away. Chassis will be rolling this weekend!
ID:	154131   Click image for larger version
ID:	154133   Click image for larger version
ID:	154135   Click image for larger version
Old July 19th, 2016, 08:34 PM
vrivas
Victor Rivas
1994 D90
Nice work!
110, rebuild
Defender 200Tdi refresh BostonAndy Smaller Projects 5 June 10th, 2015 05:25 PM
Transceiver Refresh Bill Larson Misc. Chit-Chat 13 April 29th, 2015 06:51 AM
Rear Axle: 10 Spline to 24 Spline Conversion / Seal Refresh / Ashcroft Locker Install sonoronos Smaller Projects 44 February 27th, 2015 04:20 PM
Restore or Not to Restore Heathbarcrunch Defender Technical Discussions 6 November 12th, 2007 02:05 AM
Refresh me on the issues with 35's btate Defender Technical Discussions 15 September 12th, 2006 06:35 AM
