86 110 pickup shop truck project - Defender Source
Old August 20th, 2013, 10:13 AM
Mike Sandone's Avatar
Mike Sandone
Mike Sandone
1984 Defender 110
The goal of this project is to turn this beat up 110 into reliable, left hand drive, turbo diesel shop truck.
This is the is the starting point for the new shop truck project
The previous owner had the body improperly sand blasted and every panel buckled and warped
the only part of the truck that was really any good was the rust free frame
The tear down begins
Incomplete 2.5 diesel is removed
The body is completely dissembled in about a day. 300tdi motor mounts are welded in.
The surface rust on the frame is ground down and the frame is waxoyled.
Smashed front axle housing will need to be replaced
Rear differential was filled with muddy water, it needs to go too
Truck cab was straightened out and repainted Alaska white
A decent bulkhead was sourced and bead blasted, this one only needed floor pans and minor rust repair
Since the replacement bulkhead was from an air con Rover I had to cut out the holes for the vent flaps and form a lip around the aperture for the vent flap gaskets to seal on
Etch primed, 2k urethane primed then painted in Alaska white acrylic enamel
The tub was straightened out as best as possible
Bulkhead, tub and top go back on the frame
Right hand drive heater box needs be converted to LHD position
All the rivets and spot welds are drilled out
It is cut on this line
All the individual parts that make up the heater box
The cut piece is flattened and the bent in reverse
The heater controls are removed and reinstalled on the opposite side
When reassembled it will look like this. Also a d shaped cut out needs to be made for the heater core pipes to exit on the opposite side. The cut out piece can be welded where the piped exited previously.
I opted to buy a new blower motor housing for about $65
The lower bracket also needs to be flattened and bent in reverse. When done it will look and function just like a LHD box except for the now upside down Land Rover label
Old August 20th, 2013, 10:57 AM
Mike Sandone
Mike Sandone
1984 Defender 110
Vdo gauges are installed in place of the stock gauges
The dash wiring harness needs to be slightly changed to work with the VDO gauges
The key to a clean install is having all the Land Rover correct connectors and crimping tools
a properly installed spade terminal just like from the factory
A nice clean dash harness
All the correct terminal covers
Old August 20th, 2013, 11:04 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Subscribed.
I will be keeping an eye for pointers on my build. Love the cleanliness of the VDO setup.
Old August 20th, 2013, 11:58 AM
Nice work. You have to wonder wtf was going through the sand blasters mind after he ruined the first panel but kept going ?
Old August 20th, 2013, 12:05 PM
Dollars to donuts the sals will be fine with a couple oil changes and a new pinion seal.
Old August 20th, 2013, 12:13 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Wondered the same thing.
"Uhh...I think they all leak like that."
Old August 20th, 2013, 12:23 PM
Mike Sandone
Mike Sandone
1984 Defender 110
No, they ran it like this for a while. Every bearing was pitted, even the splines on the axles where worn to a razor edge.
Here is the way I converted the lower dash to LHD
Cut out made to steering column
Ducting put in for heater box
Top cover cut down and heater cable position moved to opposite side
Upper dash support had a cut out made for the heater cables and a square section cut out for air flow from the vents which was then tack welded onto the other side behind the dash
It all went in like this
Old August 20th, 2013, 12:27 PM
That is too bad about the sals. On the plus side, axles and bearings are cheap. I think I gave away my spare sals carrier, but if I find it I will let you know.
Old August 20th, 2013, 03:15 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I like the fact that the body is rippled. It guarantees this will be a workhorse, not a showhorse.
Keep it comming.
-Jeff
I couldn't agree more.
Salisbury's are not too hard to rebuild and axle shafts are easy to get or to have made. I had some front Salisbury shafts made for me by Moser.
Old August 21st, 2013, 09:53 AM
aloharover's Avatar
aloharover
Peter
1970 Series IIa 105
Yeah just amazing.
Co Springs, CO Based FFL-07/SOT
Old August 21st, 2013, 10:23 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Very nice, Mike. I know that you're running a shop but where did you source the parts in that little plastic parts bin? I would love to score some LR spades and Genuine rubber plugs and grommets.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old August 21st, 2013, 10:56 AM
All available from autosparks.co.uk in the UK or from Britishwiring.com here in the USA.
There's not much they do not stock. I love shopping at both websites. Super fast shipping.
Old August 21st, 2013, 10:59 AM
Mike Sandone
Mike Sandone
1984 Defender 110
http://www.britishwiring.com/
At a minimum on a 25 year old Rover I'll replace every snap connector on the headlight and taillight harness http://www.britishwiring.com/Single-...tor-p/c311.htm.
If the bullet connectors are corroded it's worth replacing them too http://www.britishwiring.com/Crimpin...ire-p/c314.htm
You need this tool but it's a pleasure to use http://www.britishwiring.com/Ratchet...ool-p/tt85.htm
I also add some dielectric grease since these connections are in no way waterproof.
My favorites are these locking spade terminals http://www.britishwiring.com/1-4-Pos...nal-p/c219.htm. Perfect for use on anything that might vibrate loose like the fuel cutoff solenoid, sending units etc.
Old August 21st, 2013, 11:03 AM
Looks like the stuff from British Wiring.
Old August 21st, 2013, 11:17 AM
Mike Sandone
Mike Sandone
1984 Defender 110
Yes, this one http://www.britishwiring.com/Ratchet...nals-p/pr4.htm.
Very nice tool, perfect crimp every time.
Old August 21st, 2013, 11:34 AM
chris snell
Chris Snell
87 Ex-MOD 110
Damn, that's awesome. I bought a custom wiring harness for my old D90 from British Wiring. They are good guys.
2013 LR4
Old August 22nd, 2013, 10:26 AM
Mike Sandone
Mike Sandone
1984 Defender 110
Bent up all new brake lines for the truck, the only good use for the original brake lines is as a template for new ones.
A roll of brake line and some fittings is cheap insurance, under $50
rolled a disco axle into place temporarily
new bullets and snap connectors on tail light harness. Also taillight harness rewrapped in harness tape http://www.britishwiring.com/Harness...ack-p/c453.htm
NOS engine harness for 65 amp alternator
Old August 22nd, 2013, 10:40 AM
Mike Sandone
Mike Sandone
1984 Defender 110
I tried out these led lights
I like the fact that they are completely sealed units
They are noticeably brighter
However I ended up switching back to normal Land Rover lights; this is a work truck.
Old August 22nd, 2013, 11:12 AM
Hmm I gotta get some of those Plano boxes. I'm getting tired of fishing around in the bottom of cardboard for parts....
Old August 22nd, 2013, 01:32 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Who sells those LEDs?
110 pickup mgreenspan For Sale - Vehicles 21 December 7th, 2012 08:27 PM
Just saw 2006 110 at local indy shop Spook Misc. Chit-Chat 7 April 18th, 2012 12:24 AM
D130 High-Cap pickup Project Shane@EVS For Sale - Parts 5 October 10th, 2011 06:28 PM
110 Pickup North bound on 295 in Portland phoenix37 Misc. Chit-Chat 4 April 22nd, 2009 11:11 AM
Defender 110 Hi Cap Bed and Truck Cab FS SafariHP The Vendors Loft 2 April 14th, 2009 06:34 PM
