86 110 pickup shop truck project - Page 2 - Defender Source
Old August 22nd, 2013, 01:36 PM
Mike Sandone's Avatar
Mike Sandone
Mike Sandone
1984 Defender 110
Rovers North
http://landroverparts.roversnorth.co...287&type=0&eq=
Old August 22nd, 2013, 02:11 PM
Originally Posted by MikeCT View Post
Mike,
What double flaring tool do you use/recommend ?
Old August 22nd, 2013, 02:23 PM
Mike Sandone
Mike Sandone
1984 Defender 110
Mike,
I use a Craftsman one, works fine, made in USA
Old August 31st, 2013, 04:21 PM
Mike Sandone
Mike Sandone
1984 Defender 110
Time to get rid of these horrible corroded glass fuse boxes. Just $12 for the prc4826 fuse box, a bunch of $.50 connectors, and a couple hours work
IMG_9263 by northamericaoverland, on Flickr
IMG_9265 by northamericaoverland, on Flickr
IMG_9266 by northamericaoverland, on Flickr
Old September 12th, 2013, 06:10 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Great work.
Mike Hammond
Old July 12th, 2014, 05:08 PM
Mike Sandone
Mike Sandone
1984 Defender 110
It's been a while since I've had time for this project but here are the updates.
A good used discovery 300tdi was sourced
along with a good used discovery r380
Here are the defender and discovery shifters side by side. Obviously there is a huge difference and the discovery set up won't work in a defender.
To solve this I sourced this adapter from Ashcroft. It allows the defender shifter from the old LT77 to work on the Discovery R380.
The head is pulled from the motor to inspect the pistons and cylinders. The valves get a good clean up to remove caked on carbon and to install new valve seals. Several of the valve seals had risen off the valve guides. Also all the lifters are removed and inspected for wear or flat spots.
This was an early 300tdi and still did not have the updated timing belt, this is a must.
The lower pulley is pulled and replaced with a flanged one.
There is something satisfying about seeing the land rover logo on replacement parts.
The whole assembly is ready to go in. Tons of other parts were replaced as well, new oil cooler lines, fan clutch, thermostat, all hoses, water pump, clutch, rear main seal, glow plugs, the list goes on and on.
Old July 14th, 2014, 12:57 PM
mikeslandrover
Mike Hammond
Great job.
Mike Hammond
Old July 14th, 2014, 01:09 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I feel like there's been way more progress since those photos(based on the expo thread)
BUT... quick question for you Mike, as I trust your judgement. Where did you mount lifting attachments for the 300?
110 pickup mgreenspan For Sale - Vehicles 21 December 7th, 2012 08:27 PM
Just saw 2006 110 at local indy shop Spook Misc. Chit-Chat 7 April 18th, 2012 12:24 AM
D130 High-Cap pickup Project Shane@EVS For Sale - Parts 5 October 10th, 2011 06:28 PM
110 Pickup North bound on 295 in Portland phoenix37 Misc. Chit-Chat 4 April 22nd, 2009 11:11 AM
Defender 110 Hi Cap Bed and Truck Cab FS SafariHP The Vendors Loft 2 April 14th, 2009 06:34 PM
