86 110 LS Build and Restore - Page 7 - Defender Source
Old May 20th, 2016, 04:35 AM
Chris B
72 + D1 drivetrain =?
Originally Posted by Ash View Post
What are your thoughts on the quality of the Ashtree bulkhead? I ordered two of them last year for projects and was tremendously disappointed in how poorly they were put together. Curious if they've gotten better. -Ash
Got mine a few years ago and it was fine. A second one bought at the same time wasn't 100% straight.
Old May 31st, 2016, 03:47 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
HD Springs
I was not happy with how low the front end of the truck was sitting and I haven't even added the heavy front bumper or winch yet. So I decided before I got the fenders on and everything put back together I would swap out the medium load Terrafirma front springs with the heavy version. When both sides were done it added and inch and a quarter and she is sitting almost level now from front to back. I also added a Terrafirma gas tank skid plate since the stock tank is pretty thin metal.
If anyone needs a brand new set of medium front springs let me know. They were installed but never driven on.
ID:	150639   Click image for larger version
ID:	150641   Click image for larger version
ID:	150643   Click image for larger version
ID:	150645   Click image for larger version
Old May 31st, 2016, 04:29 PM
86Defend110
Jesse
Swivel Ball Seals....UGH!
While I was swapping out the front springs I noticed the left side swivel ball seal was leaking pretty good and the truck has not even been driven yet. I guess I should have replaced these when I did the hubs and bearings, but at the time I did not want to dive into it.
I took the plunge and put in new swivel balls, seals, bearings and new CV joints. The old swivel balls weren't in too bad of condition just some light pitting. What a nasty messy job to replace them though....
ID:	150663   Click image for larger version
ID:	150665   Click image for larger version
ID:	150667   Click image for larger version
ID:	150669   Click image for larger version
ID:	150671   Click image for larger version
Old June 13th, 2016, 07:32 PM
86Defend110
Jesse
Slow but Steady...
Made a little more progress this weekend. Cleaned up the windshield frame and installed it along with new top and bottom seals. Got the vent flaps in and also cut out the openings for the new back up lights. I went with two 18 watt LED's. Should be nice and bright. I also have them on a switch along with two pivoting LED's at the top of the rear door to use when camping/off roading, etc...
ID:	151892   Click image for larger version
ID:	151894   Click image for larger version
ID:	151896   Click image for larger version
ID:	151898   Click image for larger version
Old July 11th, 2016, 04:34 PM
86Defend110
Jesse
Too HOT to work!
Well it has been 120 degrees outside and about 150 in the garage so progress has been slow! I have been doing what I can inside the house during the heat (the wife really loves this). I recently swapped out the glass fuses to blade fuses.
ID:	153600   Click image for larger version
ID:	153602   Click image for larger version
Old July 11th, 2016, 04:47 PM
86Defend110
Jesse
I wanted to cover up the opening in the front wheel wells so mud and rocks are not damaging the foot wells. An easy solution was to mount a set of mud flaps to cover the openings. I also got both wings mounted, the hood, release cable, hood latch and grille.
ID:	153605   Click image for larger version
ID:	153607   Click image for larger version
ID:	153609   Click image for larger version
Old August 2nd, 2016, 06:01 PM
86Defend110
Jesse
Few More Things...
A few more small things buttoned up. I installed the vent bug screens, floor panels and seals, bulkhead hump, gear box cover.
Also rebuilt the wiper assembly. Cleaned and re-greased the motor, installed a new rack and new wiper arm mounts. also have new tubing and spray nozzles to put in after paint.
I think she is almost ready to be sprayed....
ID:	154994   Click image for larger version
ID:	154996   Click image for larger version
ID:	154998   Click image for larger version
ID:	155000   Click image for larger version
Old August 10th, 2016, 02:53 PM
86Defend110
Jesse
Doors on..
Doors are on and I seam sealed all the areas that needed it on the floorboards and cargo area. She is booked to go to the Line-X shop on Monday the 15th of August.
Although I should probably leave her in this rainbow pattern of white, green, and black. I wouldn't have to worry about anyone messing with it that way I bet!
Old August 18th, 2016, 12:02 PM
86Defend110
Jesse
Back in Black
Dropped off Monday at local Line-X shop. They quoted 5-6 days for full interior and exterior spray. The next photo should look a lot nicer...
Old August 18th, 2016, 12:27 PM
Contractor's Avatar
Contractor
Will
1969 IIA
Wow, you are spraying the entire truck? Same color inside and out?
Old August 18th, 2016, 02:15 PM
86Defend110
Jesse
Yes, it will be a textured black finish with the UV coating.
Old August 18th, 2016, 05:50 PM
86Defend110
Jesse
Teaser Photo!
The guy spraying the truck just text me a teaser photo. The UV coating is not on yet, but I think it looks bad-ass! Not to mention this stuff holds up way better than paint and comes with a 10 year warranty.
Old August 18th, 2016, 06:32 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2516
Looks Killer! That was fast! Now it will take 4-5 days to do the interior?
"Barry is correct!"
Old August 18th, 2016, 06:49 PM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
nice
Old August 18th, 2016, 09:34 PM
86Defend110
Jesse
I dropped it off Monday and they thought 5-6 days to do the truck. Today they said it should be finished Friday so 5 days total. They still need to put the UV coating on.
Old August 18th, 2016, 10:10 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Is each piece being sprayed separately?
Sent from my SM-G920V using Tapatalk
1970 SIIA 88, Sold
Old August 18th, 2016, 11:18 PM
D90Overkill
David Frank
1995 ST #2516
Based on this seam line (which I'm sure dried cleanly), I'd guess not. But it looks great nonetheless and that stuff is so thick that fitment/re-joinery could have been affected had it been sprayed separately.
"Barry is correct!"
Old August 18th, 2016, 11:37 PM
86Defend110
Jesse
Correct, they took the 5 doors and hood off but nothing else.
Old August 19th, 2016, 06:17 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
a line-X'd example for sale on consignment in Virginia. It needs the UV treatment really bad.
Old August 21st, 2016, 12:52 AM
86Defend110
Jesse
Yikes! I'd say so. I wonder if that is Line-X, Rhino liner or a different product...
110, 6l80, build, conversion, gen iv, ls, project, restoration, restore, swap
'87 110 Refresh, Restore, Rebuild and Update TheOneTen Truck Build-up's & Restores 240 April 6th, 2018 10:31 PM
Defender 110 and want to restore , was 200 tdi and ant upgrade Camel 422 Truck Build-up's & Restores 23 February 6th, 2013 01:06 PM
If I could restore my 110 bjf Misc. Chit-Chat 45 December 12th, 2009 02:50 PM
110 CrewCab restore project ... Retrofit Truck Build-up's & Restores 99 July 13th, 2009 07:16 PM
Restore or Not to Restore Heathbarcrunch Defender Technical Discussions 6 November 12th, 2007 02:05 AM
