86 110 LS Build and Restore - Page 6 - Defender Source
Old April 6th, 2016, 03:35 PM
Ack's Avatar
Ack
Liam Farrell
1971 Land Rover Santana IIA 109
Originally Posted by Omero View Post
They could be short. The alloy wheel carrier has a flange for the wheel to rest on and 3 short studs. The 3 long studs are usually for steel and has threaded washers for the wheel to rest on, but if they were long - and strong - enough, then it could handle alloy with big rubbers.
Couldn't you just mount it face in like a G wagon does?
Old April 6th, 2016, 03:46 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Too much leverage on the studs welds
Old April 6th, 2016, 05:59 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
What are you talking about?
He has a 265 Duratrac on a Rover alloy wheel. Total weight should be under 75lbs. I bet just one of those posts on the tire rack would be enough to support that wheel/tire combo.
If the alloy lug nut bottoms out then add 3 steel lug nuts to the studs and space as needed.
And the build is coming along very nicely 86Defend110!
Old April 7th, 2016, 12:31 AM
Omero's Avatar
Omero
Omar Alomar
Offroading with the spare put face in? I bet not.
Steel lug nuts too small, you need washers but you won't have enough remaining thread anyway. Been there.
Old April 7th, 2016, 11:42 AM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Bulkhead!!
Got some great news from Ashtree this morning!
This baby is finally on its way across the pond. I have basically been at a standstill on the truck without it...
Old April 7th, 2016, 09:42 PM
86Defend110
Jesse
Looks like it will work out good. With washers on I still have about a 1/4 of thread sticking out with the lugs tightened.
Old April 8th, 2016, 02:24 PM
Omero's Avatar
Omero
Omar Alomar
Fantastic!
Old April 8th, 2016, 06:25 PM
Raquen
Matthew
none
Humm must be why they are taking so long on my door order. Looks good. l'd like to hear how long it takes to deliver. I have a full set of doors coming from them.
The build looks great! I have been thinking about the 5.3 LS conversion my self. Looks like you put the manual transmission in. Did you run into any space issues fitting the tranny and the transfer case?
What tranny and transfer case did you use?
Old April 8th, 2016, 07:09 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Raquen View Post
Looks like you put the manual transmission in. Did you run into any space issues fitting the tranny and the transfer case? What tranny and transfer case did you use?
It's a 6 speed auto.... plenty of info on manual install in the Gen III thread here :
http://www.defendersource.com/forum/...iii-52933.html
Happy reading
Old April 8th, 2016, 09:56 PM
86Defend110
Jesse
That's why I added that it is Finally on the way! They originally said 4 weeks and we are going on 10... I probably would have had the truck driveable if I had the bulkhead 6 weeks ago.
Old April 10th, 2016, 07:57 PM
vrivas
Victor Rivas
1994 D90
Awesome build, looking forward to seeing the rest. Good luck!
Old April 11th, 2016, 02:56 PM
86Defend110
Jesse
Painting...
Spent this weekend painting a lot of pieces parts with POR-15 and getting things ready for when the bulkhead arrives. Got the heater all put back together with a new blower motor and heater core.
ID:	146992   Click image for larger version
ID:	146994   Click image for larger version
ID:	146996   Click image for larger version
ID:	146998   Click image for larger version
ID:	147000   Click image for larger version
Old April 11th, 2016, 03:01 PM
86Defend110
Jesse
Brake Booster
Cleaned up a brake booster and master cylinder I pulled out of a salvaged Disco 1. Put in new seals and a new brake light switch also.
ID:	147002   Click image for larger version
ID:	147004   Click image for larger version
Old April 11th, 2016, 05:34 PM
6 pot's Avatar
6 pot
Rob
more than one
Hi
Could you please tell me if these are the same manifolds you have fitted?
http://www.summitracing.com/int/part...1hkr/overview/
Would they fit OK with a 6.2 LS3 in a 90? I am in England so I need to get it right the first time as I cannot just nip round the corner and get some different ones. Is the LS3 block the same external size as your engine? if so they should fit. I am struggling with all the US parts as none of them are in any of my Land Rover parts books and I have zero previous experience of US or non Land Rover parts or using them.
Thanks Rob
Old April 11th, 2016, 05:53 PM
86Defend110
Jesse
Yes those are the headers you need. Good luck with your build!
Old May 16th, 2016, 11:59 AM
86Defend110
Jesse
Bulkhead!
Well it took a long time to get here from Ashtree but I finally got the bulkhead I ordered on February 16th....
It came galvanized with an etch primer on it. For good measure I roughed it up a bit and put POR-15 on it. I mounted a plate over the clutch pedal opening and enlarged the opening for the heater.
Finally can make some progress again now that the bulkhead is here....
ID:	149655   Click image for larger version
ID:	149657   Click image for larger version
ID:	149659   Click image for larger version
Old May 16th, 2016, 12:02 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
What are your thoughts on the quality of the Ashtree bulkhead? I ordered two of them last year for projects and was tremendously disappointed in how poorly they were put together. Curious if they've gotten better.
-Ash
Geared Restoration Co.
352-572-3236
Old May 16th, 2016, 12:25 PM
86Defend110
Jesse
This one seems to be done pretty well. The mounting holes lined up nice and the wings fit very well. I was worried about it being warped after galvanizing but that part seems to be fine. The only thing I can compare it to was my original that was completely rusted out.
The time frame was frustrating as they told me 4 weeks and it took 12, but I do know Jan was very sick with shingles....
Old May 16th, 2016, 01:00 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Jesse, the build looks good. Can I ask what your plan is for the wiper motor as I see you cut out the larger opening for the heater box on the nice bulkhead?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 20th, 2016, 01:21 AM
Shoe
Jacob
1989 110
Really digging the Build !
110, 6l80, build, conversion, gen iv, ls, project, restoration, restore, swap
'87 110 Refresh, Restore, Rebuild and Update TheOneTen Truck Build-up's & Restores 240 April 6th, 2018 10:31 PM
Defender 110 and want to restore , was 200 tdi and ant upgrade Camel 422 Truck Build-up's & Restores 23 February 6th, 2013 01:06 PM
If I could restore my 110 bjf Misc. Chit-Chat 45 December 12th, 2009 02:50 PM
110 CrewCab restore project ... Retrofit Truck Build-up's & Restores 99 July 13th, 2009 07:16 PM
Restore or Not to Restore Heathbarcrunch Defender Technical Discussions 6 November 12th, 2007 02:05 AM
