86 110 LS Build and Restore - Page 5 - Defender Source
Old March 21st, 2016, 03:12 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Daddymow View Post
I would say no more than any other 110. It is not about a powerful engine pulling a load but way more about controlling and stopping that load. Also what the frame can handle as well, I literally bent the frame on one of my F150s from towing too much heavy stuff with it.
Towing capacity is a function of the GVWR, unless your going to get that changed with your local DMV it'll be the same as before. However, actual 'performance' when towing should be significantly improved across the towed weight range with less stress on the engine / trans at higher towed loads.
------ Follow up post added March 21st, 2016 12:15 PM ------
Originally Posted by 86Defend110 View Post
Got all the fluids poured in, new plugs and the MAF installed this weekend. Started up the motor for the first time, sounds great but a tad loud with no exhaust! I was happy there were no leaks anywhere though!
Awesome, just got to finish my ECM loom, headers & plumb up the rad.... then time to let her breath fire too
Old March 22nd, 2016, 08:21 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
New dubs....
Sent these 5 wheels off to be powder coated a satin black. I originally bought two full sets locally and pretty reasonable. I sent the best 5 to be coated. If anyone needs 1, 2, or 3 wheels let me know. Otherwise I may buy one more and keep a set of studded Duratracs on them for the winter...
ID:	145668   Click image for larger version
ID:	145670   Click image for larger version
Old March 23rd, 2016, 06:55 PM
86Defend110
Jesse
Hit a Snag....
Ran into a little snag with the hood clearing the alternator. Apparently with the large 120a alternator the stock defender hood will not clear it.
Options were to mount a smaller alternator, move the alternator using different mounting brackets, or a Puma hood.
I was planning on getting a new hood as mine was in pretty rough shape, but I would have preferred a new non-Puma hood.
To save some $$ I ended up with the Britpart fiberglass Puma style hood. It has plenty of clearance, a good 2-3 inches over the alternator. Hopefully it holds up....
ID:	145761   Click image for larger version
ID:	145763   Click image for larger version
ID:	145765   Click image for larger version
Old March 23rd, 2016, 11:38 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I think with this build the Puma hood will look really good. Plus you have the clearance for the alternator and some more room for air to move around for cooling.
Old March 24th, 2016, 10:34 AM
86Defend110
Jesse
Good point, I definitely like how much extra room it gives the motor, it will be nice for air circulation. I can even fit the plastic dust cover now.
Old March 29th, 2016, 05:15 PM
86Defend110
Jesse
Powdercoat
Picked up the wheels from the powder coater, they turned out great and look brand new!
I also took the seat box and floor panels to them just to be sandblasted. The owner offered to coat them the same color as the wheels for next to nothing so I said why not as it saves me from having to hand paint them with POR-15.
ID:	146300   Click image for larger version
ID:	146302   Click image for larger version
ID:	146304   Click image for larger version
Old March 29th, 2016, 06:05 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
I also took the seat box and floor panels to them just to be sandblasted. The owner offered to coat them the same color as the wheels for next to nothing so I said why not as it saves me from having to hand paint them with POR-15.[/QUOTE]
Good call and looks great!!!
Old March 29th, 2016, 08:26 PM
Nice!
Old March 30th, 2016, 08:20 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
The seat box has large flat panels that could have some flex or movement to them over time. How does powder coating handle that?
Firemanshort
1980 Stage One 109
Sterling, VA
Old March 30th, 2016, 09:37 AM
phoenix37's Avatar
phoenix37
john
according to this pretty well.
Seattle Powder Coat - How is Powder Coat Better than Spray Paint?
Old April 5th, 2016, 06:24 PM
86Defend110
Jesse
Weekend Worker
This weekend I patched a couple holes in the rear door from previous water damage. After I got the new metal on I threw a coat of rust preventing primer on and mounted the door with new hinges. I plan on having the inside of the rear door sprayed with Line-X before putting all the guts back inside.
Mounted the spare tire carrier and the roof ladder also.
Took the tires in to be mounted and balanced, but I still need to buy a spare.
ID:	146687   Click image for larger version
ID:	146689   Click image for larger version
ID:	146691   Click image for larger version
ID:	146693   Click image for larger version
Old April 6th, 2016, 12:06 PM
86Defend110
Jesse
Installed gasket material around the rear floor panel and seat box and got them both installed along with the TerraFirma rock sliders. Also installed the battery tray in the seat box, working on the wiring and isolator for a second battery now.
ID:	146725   Click image for larger version
ID:	146727   Click image for larger version
Old April 6th, 2016, 12:33 PM
Hache
Henry Lambert
1983 Ex-MOD 90 2.5N/A
Looking great!
Old April 6th, 2016, 12:51 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Where did you get that gasket material? I've got gaps in my rear floor and need something like that to seal it up.
Old April 6th, 2016, 12:53 PM
Looks like closed cell foam weatherstripping. Any hardware store.
Old April 6th, 2016, 02:00 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Great job 👍. Make sure that your alloy wheels fit the spare carrier, I have 3 posts looks like yours protruding from my rear door and they fit only steel wheels.
Old April 6th, 2016, 02:22 PM
Ack's Avatar
Ack
Liam Farrell
1971 Land Rover Santana IIA 109
Don't quite understand what you mean by this, is it that they may not be long enough or is it the stud pattern.
Old April 6th, 2016, 02:37 PM
86Defend110
Jesse
Weather stripping from ACE Hardware. Nice thing is it is super cheap, comes in different widths, thicknesses and has an adhesive on one side. I used 3/4 inch wide and 5/16 thick, which matched the stock stuff the closest.
Old April 6th, 2016, 03:13 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
homo depot too. i bought some to put around the inside of the gutter kit on my d90 soft-top.
Old April 6th, 2016, 03:53 PM
Omero's Avatar
Omero
Omar Alomar
They could be short. The alloy wheel carrier has a flange for the wheel to rest on and 3 short studs. The 3 long studs are usually for steel and has threaded washers for the wheel to rest on, but if they were long - and strong - enough, then it could handle alloy with big rubbers.
110, 6l80, build, conversion, gen iv, ls, project, restoration, restore, swap
'87 110 Refresh, Restore, Rebuild and Update TheOneTen Truck Build-up's & Restores 232 January 16th, 2018 10:03 PM
Defender 110 and want to restore , was 200 tdi and ant upgrade Camel 422 Truck Build-up's & Restores 23 February 6th, 2013 02:06 PM
If I could restore my 110 bjf Misc. Chit-Chat 45 December 12th, 2009 03:50 PM
110 CrewCab restore project ... Retrofit Truck Build-up's & Restores 99 July 13th, 2009 08:16 PM
Restore or Not to Restore Heathbarcrunch Defender Technical Discussions 6 November 12th, 2007 03:05 AM
