86 110 LS Build and Restore - Page 3 - Defender Source
Old January 19th, 2016, 06:41 AM
Contractor's Avatar
Contractor
Will
1969 IIA
I had to get rid of some of that crap one time..........I used a heat gun to get the big stuff and came back with acetone to get all the other crap.
Good luck, it was a mind numbing experience.
Old January 19th, 2016, 04:47 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
I agree, so far this has been the worst job....
Old January 19th, 2016, 05:17 PM
86Defend110
Jesse
Grease and more grease
Well along with getting grease everywhere I managed to get some in the new wheel bearings and get the hubs, stub axles cleaned up and painted....what a mess! Finished 3 out of the 4...front right will have to wait until this coming weekend.
I did get new rotors, calipers, pads, tie rod ends, adjustable panhard bar, shocks, springs, bushings, bump stops, etc etc etc installed though!
Pretty sure I inhaled way too much brake cleaner, POR 15, grease, primer, spray paint, old diff lube, degreaser, WD40 this weekend! Good times....
ID:	139847   Click image for larger version
ID:	139849   Click image for larger version
ID:	139851   Click image for larger version
ID:	139853   Click image for larger version
ID:	139855   Click image for larger version
Old January 19th, 2016, 05:22 PM
phoenix37's Avatar
phoenix37
john
looks great...
Old January 19th, 2016, 05:28 PM
86Defend110
Jesse
Rear Hubs
A few pics of the rear set up, went from drums to discs using defender front hubs and disco 1 rear calipers via the conversion thread on the forum. Got everything mocked up. Think I will get some black caliper paint and spray the calipers before final installation, the finish on them looks like it would get surface rust pretty quickly.
ID:	139857   Click image for larger version
ID:	139859   Click image for larger version
ID:	139861   Click image for larger version
Old January 25th, 2016, 05:52 PM
86Defend110
Jesse
Drivetrain!
Finally got to the point where I was ready to install the drivetrain. I measured the frame height before and after install and the drivetrain dropped the front end 1.5".
Also got the new gas tank mounted and the front diff skid plate painted and mounted.
ID:	140407   Click image for larger version
ID:	140409   Click image for larger version
ID:	140411   Click image for larger version
ID:	140413   Click image for larger version
ID:	140415   Click image for larger version
Old February 2nd, 2016, 12:32 PM
86Defend110
Jesse
Another weekend
Made a bit more progress this weekend.
Installed new cathedral port intake gaskets and mounted the intake.
Cleaned up, painted and installed new parts in the handbrake drum.
Installed new fuel tank sender.
Installed more bushings...(finally done with bushings)!
Now onto rust repair in rear door, bulkhead, sills etc...(I have been procrastinating working on these but it is time)
ID:	141142   Click image for larger version
ID:	141144   Click image for larger version
ID:	141146   Click image for larger version
ID:	141148   Click image for larger version
Old February 9th, 2016, 02:54 PM
86Defend110
Jesse
More tinkering
This weekend I installed all new U-joints, high pressure in tank fuel pump, ARB breather lines to the front and rear diffs and the T-case (love the pic on the box), and fitted the front skid plate prior to painting. Driving to Cali this Saturday to pick up a used bulkhead that is in much better shape than mine. This should save me some serious time in the long run....
ID:	141955   Click image for larger version
ID:	141957   Click image for larger version
ID:	141959   Click image for larger version
ID:	141961   Click image for larger version
ID:	141963   Click image for larger version
Old February 16th, 2016, 05:01 PM
86Defend110
Jesse
Slow but Steady......
Another weekend down but managed to get a few things accomplished...
Got the Hooker headers coated and installed with new gaskets.
Got the Lokar auto shifter and linkage installed.
Transfer case linkage installed.
Ran some of the fuel lines...
ID:	142541   Click image for larger version
ID:	142543   Click image for larger version
ID:	142545   Click image for larger version
ID:	142547   Click image for larger version
Old February 16th, 2016, 05:28 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Damn.....that looks GOOD!!
Old February 22nd, 2016, 12:00 PM
86Defend110
Jesse
Wiring
Got my wiring harness back from a local guy who builds stand alone harnesses from your factory harness. It looks great, we will see how everything works in a couple weeks hopefully!
ID:	143112   Click image for larger version
ID:	143114   Click image for larger version
Old February 22nd, 2016, 12:02 PM
that all looks so good...
Old February 22nd, 2016, 12:03 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Nice, I'm working on a complete custom loom for my D100.... might as well renew & include all the new bits at the same time
Old February 22nd, 2016, 12:07 PM
86Defend110
Jesse
Misc....
Worked on mocking up the radiator, got the power steering box bolted on, Visited a junkyard and spent some time under a Disco 1 to remove the transfer case brackets that mount to the frame. Got them home, cleaned them up, hit them with a coat of paint and installed them.
ID:	143118   Click image for larger version
ID:	143120   Click image for larger version
ID:	143122   Click image for larger version
Old February 22nd, 2016, 12:08 PM
86Defend110
Jesse
Very nice man, I wish I knew more about wiring, coulda saved some $$$ but I don't feel comfortable messing with it yet.
Old February 22nd, 2016, 12:44 PM
Overall it looks great. Though, personally I cannot stand the sight of those red/yellow/blue plastic crimp connectors. IMO they are worthless on vehicular applications outside of a stereo install. Especially if they are anywhere that salt and/or moisture might be a factor. I usually cut the cheezy plastic insulator off and shrink wrap them. After crimping and soldering. Just my $.02
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old February 22nd, 2016, 01:02 PM
The proper method is to use uninsulated connectors with a correct racheting crimp tool and then dual layer heat shrink. You should not solder. Nobody should ever use insulated crimp connectors other than for a field repair.
Old February 22nd, 2016, 01:15 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I'm not following. What is better than Anchor marine grade insulated (heat shrink and glue) crimp connectors with their corresponding crimper?
Old February 22nd, 2016, 01:20 PM
Okay. Some speciality insulated terminals are probably okay, but I prefer to see that the crimp is correct before insulating. the crimp needs to grab the strands correctly to ensure a long lasting and solid connection.
I'm talking about the standard nylon insulated terminal you get everywhere that we can see in the loom pictures above. They do not form a proper connector to the wire.
Old February 22nd, 2016, 09:10 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Care to enlighten us ?
But in a new thread so this one doesn't go off track
Oh... and it's pronounced sol'der, not sod'er.....
110, 6l80, build, conversion, gen iv, ls, project, restoration, restore, swap
'87 110 Refresh, Restore, Rebuild and Update TheOneTen Truck Build-up's & Restores 240 April 6th, 2018 10:31 PM
Defender 110 and want to restore , was 200 tdi and ant upgrade Camel 422 Truck Build-up's & Restores 23 February 6th, 2013 01:06 PM
If I could restore my 110 bjf Misc. Chit-Chat 45 December 12th, 2009 02:50 PM
110 CrewCab restore project ... Retrofit Truck Build-up's & Restores 99 July 13th, 2009 07:16 PM
Restore or Not to Restore Heathbarcrunch Defender Technical Discussions 6 November 12th, 2007 02:05 AM
