86 110 LS Build and Restore - Page 2 - Defender Source
Join the Defender Source Community Today
Old December 28th, 2015, 05:31 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by 86Defend110 View Post
Yes, exactly! It would be an easy conversion and now would be the time to do it as I have the truck down to a rolling frame, but the dash pieces are just too much $$ to justify it for me. Plus I kinda like the RHD...something different and some of the looks from other drivers are priceless.
I was in the same boat... so I made my own http://www.defendersource.com/forum/...ion-42326.html
D100 5.3 LS powered truggy under construction....
Old December 28th, 2015, 09:27 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
You may want to research getting it acid dipped instead of blasted....it is a much cleaner and better process. PLUS, after it you can really see the parts requiring repair better. And it is something that needs to be done anyway prior to galvey dip.
Crud! Wish I would have explored this option earlier as the frame is at the blasters shop now and was probably done today or may be tomorrow.
Old December 29th, 2015, 03:33 PM
86Defend110
Jesse
Wow! absolutely amazing work man! But well beyond my fabrication level...
Old December 29th, 2015, 04:48 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
Andy, thanks for sharing that RHD to LHD panel conversion link and build. Wow the gift-giving season never ends.
Old December 30th, 2015, 11:20 AM
86Defend110
Jesse
The Frame Survived!
Got the frame back and I am very surprised how well it looks after being blasted! There are only a few places that will need repair. I was expecting swiss cheese everywhere and was pleasantly surprised to see I wont have to spend $$$ on a new one or a ton of hours on this one.
Worst spot was the rear crossmember for the rear passenger footwell which is a removable piece.
Cleanest spot was under the manual steering box after I removed it....
ID:	138166   Click image for larger version
ID:	138168   Click image for larger version
ID:	138170   Click image for larger version
ID:	138172   Click image for larger version
Old January 4th, 2016, 04:01 PM
86Defend110
Jesse
4 Days Off...
I was able to make decent progress this weekend over the New Year's Holiday. Spent four days in the garage....Patched up the frame where it needed work, got the new engine mounts on, put two coats of POR 15 on the frame except for the very front end where I still need to do some work and fabricate brackets for my bumper.
Took apart the rear end and got it all cleaned up. Have all the parts to convert to rear discs, just need to find them!
I also need to decide if I want to splurge on the ARB locker or get a Detroit...I have already purchased heavy duty rear axle shafts as I am going from 55hp to 325hp...
ID:	138484   Click image for larger version
ID:	138486   Click image for larger version
ID:	138488   Click image for larger version
ID:	138490   Click image for larger version
ID:	138492   Click image for larger version
Old January 4th, 2016, 04:22 PM
86Defend110
Jesse
New Bushings and stuff...
Wow, spent about 3 hours on what I thought would be a half hour job of putting new poly bushings in the link arms to the rear axle. The old rubber bushings at the rear axle and thin steel sleeve were pretty much welded in over the last 30 years! Had to drill out the old rubber bushings and then chisel/hammer out the metal sleeves.
Finally got them out and the new poly ones in with lithium grease. Hopefully the other 300 or so bushings in the kit don't go like these two! The new springs and shocks only took about 30 minutes to install, go figure.
ID:	138494   Click image for larger version
ID:	138496   Click image for larger version
ID:	138498   Click image for larger version
ID:	138500   Click image for larger version
Old January 7th, 2016, 12:51 PM
86Defend110
Jesse
Ls3 lc9
Started getting the LC9 ready to go. Even though it has only 30k on it I am putting on a new belt, tensioner, idler pulley, plugs etc...
Took the A/C compressor and mounting bracket off. Removed the manifolds (they will be good paperweights). Removed the intake for the install and to rotate it 180 degrees. Will get the 6L80 and Disco 1 LT230 bolted up this weekend hopefully.
ID:	138694   Click image for larger version
ID:	138696   Click image for larger version
Old January 11th, 2016, 01:39 PM
86Defend110
Jesse
Moving Along
This weekend I found a Trans and Transfer Case from a wrecking yard in Phoenix. 6L80 Trans came out of a 2012 4x4 Silverado with 29,000 miles and the case is from a 97 Disco with a 1.2 ratio. Got them home and started getting them ready. Pulled the pan from the trans to check the fluid and change the filter and fluid. Bolted up Nick's shiny adapter and them did some work on the case.
The speedo cable attachment and the hand brake cable were different along with some of the mounting holes for the hand brake. To make things easier I decided to swap out the housing from my 1.6 case. Except for cleaning everything up to get a good seal this was not too bad of a job.
ID:	139150   Click image for larger version
ID:	139152   Click image for larger version
ID:	139154   Click image for larger version
Old January 11th, 2016, 01:41 PM
phoenix37's Avatar
phoenix37
john
dont forget to connect the wiring harness to the trans before bolting on the transfercase...almost made that mistake.
Old January 11th, 2016, 01:48 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Ahh, I see that the 6L80E is a two OD trans, with that 1.2 transfer case and 3.54's that's an awesome gear setup! I'm not a huge auto fan but this looks like it will be a nice build!
Old January 11th, 2016, 01:55 PM
86Defend110
Jesse
Brakes
Had a little time left this weekend to start working on the rear brakes. Going from my crusty drums to discs in the rear using Disco 1 rear calipers. Swapping to vented discs and new calipers in the front. Also bought a new brake line kit and 2" extended braided lines for the front two calipers and valve on the rear diff.
All the parts I purchased new from LR Direct. They have great prices, shipping across the pond is not cheap but still beats any US prices by a lot!
ID:	139158   Click image for larger version
ID:	139160   Click image for larger version
ID:	139162   Click image for larger version
ID:	139164   Click image for larger version
Old January 11th, 2016, 01:59 PM
JohnsD90's Avatar
JohnsD90
Did you do the later style sals disc brake conversion? or did you get early 110 front hubs and do the conversion that way? I believe the latter one makes the rear track 23mm narrower than the front.
Old January 11th, 2016, 04:07 PM
86Defend110
Jesse
Oh yes, good call, thanks for the reminder! I hope to get the motor, trans and T-case all installed into the frame this coming weekend.
------ Follow up post added January 11th, 2016 02:08 PM ------
Yes, it should cruise along nicely on the freeway at low RPM's. Thanks
Old January 11th, 2016, 04:17 PM
86Defend110
Jesse
I am using front hubs for a Defender. (FRC6139)
Old January 14th, 2016, 05:34 PM
86Defend110
Jesse
This stuff is nasty!
So have been trying to remove the insulation from the interior of the truck so I can get it sprayed with Line-X....
I have tried sandblasting, grinding, adhesive remover etc....
Nothing works that well. Goo-Gone does ok after numerous applications and letting it soak overnight then scraping, scraping, scraping, makes a nasty mess though!
Anyone have a better method of removing this glued on insulation? The seat boxes are covered, trans tunnel, rear cargo area, etc..
Been trying to enlist my wife to help with this part but she's not having it!
ID:	139440   Click image for larger version
Old January 14th, 2016, 05:37 PM
phoenix37's Avatar
phoenix37
john
plain old gasoline... worked for me when someone had carpeted the bed of my 109 pickup. also a nasty mess but it came off.
Old January 14th, 2016, 05:38 PM
Heat and scrape maybe?
Old January 14th, 2016, 06:06 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I had good luck with brake cleaner... make sure you are in a well ventilated area.....
good luck with your search
Old January 19th, 2016, 07:26 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I agree. Controlled burn in small patches. Careful with all those toxic chems.
110, 6l80, build, conversion, gen iv, ls, project, restoration, restore, swap
'87 110 Refresh, Restore, Rebuild and Update TheOneTen Truck Build-up's & Restores 194 February 21st, 2017 02:14 AM
Defender 110 and want to restore , was 200 tdi and ant upgrade Camel 422 Truck Build-up's & Restores 23 February 6th, 2013 02:06 PM
If I could restore my 110 bjf Misc. Chit-Chat 45 December 12th, 2009 03:50 PM
110 CrewCab restore project ... Retrofit Truck Build-up's & Restores 99 July 13th, 2009 08:16 PM
Restore or Not to Restore Heathbarcrunch Defender Technical Discussions 6 November 12th, 2007 03:05 AM
