85 ninety - Defender Source
Old July 31st, 2016, 10:03 AM
defenderholty's Avatar
defenderholty
Russell
1985 LR Ninety 200tdi
85 ninety
I started the tear down in November. To avoid paying for a build and a divorce, I only work around one day a week on it.
I started with a 1985 Ninety 2.5na and wasn't intent on rebuilding it, but as it turns out the $ I saved getting a good deal has been spent back 10 fold on the rebuild. It was in such bad condition that it was unsafe to drive -all covered by a heavy coat of waxoyl and thick paint. About the only thing I'll be able to reuse is the steering wheel.
The body had been tinkered with and hardly anything had been isolated, so swiss cheese. The rear cross member had ben replaced by an 8 year old with a hot glue gun. The frame was completely shot. The previous owner provided me with MOT pass paperwork, but I don't see how it would have.
anyway...
ID:	154826   Click image for larger version
ID:	154828   Click image for larger version
Old July 31st, 2016, 10:09 AM
defenderholty
Russell
More of the disassembly.
I did reuse the axles, and the power steering box. I sand blasted them and repainted them with caliper paint. I resealed the power steering box, which wasn't as bad as I thought it would be.
ID:	154832   Click image for larger version
Old July 31st, 2016, 10:25 AM
defenderholty
Russell
I got all of the suspension, axles , tie rods prepped and new bushings and nuts and bolts all
around. I had to buy a 22 ton press. I wouldn't have gotten far without it. Some of those bushings are really in there, and the D link on the back was quite stubborn.
I removed the 2.5na. Going back is a 200tdi that I bought from a member. It will be getting a new water pump and timing belt after I finish prepping the body to be sent off for paint.
The frame is a special order from RN, with side and rear fuel tank mounts. It should put my fuel capacity around 27 gal.
ID:	154835   Click image for larger version
ID:	154837   Click image for larger version
Old July 31st, 2016, 10:29 AM
defenderholty
Russell
This was a big anxiety day for me. Cutting the body to mount the series fuel filler cowl. I took my time and it turned out just fine. The cowl wasn't all that easy to find but after finally figuring out the part number, a google search put me on to one pretty quickly.
ID:	154849   Click image for larger version
Old July 31st, 2016, 10:57 AM
defenderholty
Russell
I am going back with a drop down lift gate. I saw this swing away tire carrier, and am interested, I believe it is Brit Part. Can anyone speak to the quality?
Old July 31st, 2016, 12:04 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Sweet, I have an '85 Ninety also. Looking good thus far!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old July 31st, 2016, 12:24 PM
defenderholty
Russell
Thanks. I had to wait for months on the frame and some of the body parts, in the mean time I have been collecting parts to finish it. I was shooting for the first of Sep. But thinking about how slowly I work, I will be lucky to have it finished by the first of the year.
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
I spy a Chris Craft! Looking good so far!
Rovers, Guns, and Airplanes... Willing to share my Ramen Noodle Recipes!
'95 RRC CountyLWB - dripping all over central TX
'83 110 HCPU - in piceces, all over central TX
'90 RRC Truggy - loud and proud
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old August 1st, 2016, 08:44 AM
defenderholty
Russell
The Chris Craft is feeling a little neglected this summer. About the extent of its use this summer has been holding tools on the fenders of the trailer.
Old August 1st, 2016, 06:24 PM
defenderholty
Russell
Checking inventory on lift gate and mounting parts. One more work day and I should be able to send it off for paint..
Name:	lift gate (1).jpg
Old February 11th, 2017, 03:11 PM
defenderholty
Russell
The build went on hold for a while getting the new member settled in. I have started back. I have most of the body back from paint.
ID:	206354   Click image for larger version
Old February 11th, 2017, 03:15 PM
defenderholty
Russell
Just finishing up some wiring before I put the dash back in.
ID:	206378   Click image for larger version
Old February 11th, 2017, 03:22 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
An 18 month break? Good to see you picking the build up again. Keep us posted.
KGH - Defender Snob
defenderholty
Russell
I installed a Revotec electric cooling fan and a YRM radiator/intercooler frame. They work nicely together.
The plan was to finish in time to go to Uwharrie, but I still have a ways to go, and little time to work on it.
Old February 13th, 2017, 03:48 PM
defenderholty
Russell
I am getting ready to sit the tub on the chassis. Shoud there be isolation or padding between the tub and chassis?
Old February 13th, 2017, 06:08 PM
There should be rubber pads isolating the steel tub reinforcements from the chassis.
Old February 13th, 2017, 07:20 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Looks great Russell.
Old February 13th, 2017, 08:35 PM
defenderholty
Russell
Thanks, that's what I thought.
------ Follow up post added February 13th, 2017 09:37 PM ------
Thanks Mack. I changed the water pump and timing belt on the 200tdi. I'm close to firing it off.
Old February 18th, 2017, 10:13 AM
defenderholty
Russell
Getting ready to bolt the tub down. Finishing up a little plumbing and wiring to the rear fuel tank and new brake lines.
Name:	with tub on.jpg
Old February 19th, 2017, 07:56 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I installed a Revotec electric cooling fan and a YRM radiator/intercooler frame. They work nicely together. The plan was to finish in time to go to Uwharrie, but I still have a ways to go, and little time to work on it.
don't leave that blue tape on too long, even though it's 'safe release' I find if it sits for too long it can still damage paint
White Ninety :: 1990 Land Rover Ninety V8 County gavin. Defender & Series Truck Registry 7 July 24th, 2015 07:58 PM
1985 LHD Defender Ninety 300 tdi rivermike For Sale - Vehicles 32 April 4th, 2012 05:51 AM
Stuff the PO left in the ninety Gardner Misc. Chit-Chat 26 February 4th, 2011 10:37 AM
Swinging NAS Tire Carrier - fitted to an ROW Ninety? DNinety Defender Technical Discussions 6 August 30th, 2010 09:40 AM
'84 petrol Ninety on ebay - not mine hillstrubl The Flea Market 1 July 23rd, 2010 11:04 AM
