'85 110 Facelift - Page 2 - Defender Source
Join the Defender Source Community Today
Old January 28th, 2016, 09:50 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Removed the headliner and was shocked how the underside of the roof looks brand new!!
ID:	140718   Click image for larger version
Old January 28th, 2016, 09:51 PM
RBBailey
RBBailey
1965 IIa
Looks great!
How clean did you get the surface, and what type of prepping did you do before applying the bedliner?
Project:
1965 IIa SWB
Old January 28th, 2016, 10:34 PM
ATX_D110's Avatar
ATX_D110
Victor
Originally Posted by RBBailey View Post
Looks great! How clean did you get the surface, and what type of prepping did you do before applying the bedliner?
Blew it out several times with air and scrubbed with hot soap and water - That's it!!!!
Old January 28th, 2016, 11:55 PM
JASEcrest
Jason
'88 Defender 110
Did you get a new headliner or are you going to run bare?
Do you pics of the door sill work?
Old January 29th, 2016, 12:59 AM
RBBailey
RBBailey
1965 IIa
Well.... uh... maybe I'm overdoing it a bit then... For the seatbox and floor, I blasted, am setting up to spray epoxy etch primer, then I'll go over with two-part Hippoliner.
Did you attempt any dings and scratches on a sacrifice piece to see how it holds up?
BTW, your truck sure looks a lot like mine!
Project:
1965 IIa SWB
Old January 29th, 2016, 09:13 AM
ATX_D110's Avatar
ATX_D110
Victor
Originally Posted by JASEcrest View Post
Did you get a new headliner or are you going to run bare? Do you pics of the door sill work?
Tried to buy the 2 pcs of headliner from a member but he is pretty proud of it 😃 but I'll prob keep it bare - End goal is to be a ST
------ Follow up post added January 29th, 2016 08:16 AM ------
Well.... uh... maybe I'm overdoing it a bit then... For the seatbox and floor, I blasted, am setting up to spray epoxy etch primer, then I'll go over with two-part Hippoliner. Did you attempt any dings and scratches on a sacrifice piece to see how it holds up? BTW, your truck sure looks a lot like mine!
I wouldn't say you're over doing it - Different strokes for different folks plus really depends on the condition prior. I fixed a nasty spot on the drives footwell prior so Alls good now
Old February 2nd, 2016, 07:32 PM
ATX_D110's Avatar
ATX_D110
Victor
Loadspace mat / Check! Rear inside wheel arches mat / Check! Middle row floor / Check! Front floors and footwells / Check! 3x4' 1/2" Stall Mats from Tractor Supply!!! $21.00 each!!! Will tackle seat box next
ID:	141183   Click image for larger version
ID:	141185   Click image for larger version
Old February 2nd, 2016, 08:36 PM
nice
Old February 5th, 2016, 09:51 PM
ATX_D110's Avatar
ATX_D110
Victor
Middle and rear seats installed - Before and after pics....
ID:	141667   Click image for larger version
Old February 6th, 2016, 12:59 PM
vrivas
Victor Rivas
1994 D90
Looking good!!!!
Old February 6th, 2016, 07:22 PM
ATX_D110's Avatar
ATX_D110
Victor
Seat box carpeted, mats and cubby installed!!!
ID:	141711   Click image for larger version
Old February 6th, 2016, 07:28 PM
ATX_D110's Avatar
ATX_D110
Victor
Before
Old February 7th, 2016, 12:59 PM
RBBailey
RBBailey
1965 IIa
Very nice!
Project:
1965 IIa SWB
Old February 8th, 2016, 04:52 PM
ATX_D110's Avatar
ATX_D110
Victor
For those who have asked regarding the carpet - Local upholstery shop calls it Thermo Bond Carpet and contact cement was used. Here are pics of the front (Left) and back (Right)
ID:	141888   Click image for larger version
Old February 16th, 2016, 10:52 AM
Truck is looking great! Out of curiosity, what is this?
Old February 16th, 2016, 01:39 PM
ATX_D110's Avatar
ATX_D110
Victor
Thanks - Storage area
Old February 16th, 2016, 01:50 PM
your modification?? i like it
Old February 16th, 2016, 02:29 PM
ATX_D110's Avatar
ATX_D110
Victor
Came over with it!
Old February 17th, 2016, 10:44 AM
Whidbey's Avatar
Whidbey
86' 110
bull
The teardown has begun........
Nice bull!!
Old February 17th, 2016, 11:39 AM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Looks great! Excellent idea with the horse stall mat for the load space liner! Especially since most places want $200-$300 for a thinner piece...
Defender Facelift Kit rtcgb For Sale - Parts 6 June 23rd, 2014 10:13 PM
