85 110 3 door - Page 3 - Defender Source
Old October 18th, 2010, 01:09 PM
Yes that looks correct. The older style calipers had smaller holes for the cotter pins as opposed to the newer solid pins.
Old October 18th, 2010, 05:31 PM
adamdh1
ad
none
Thanks, cgalpin. Started on the other side today. Got it torn down and put a couple fresh coats of paint on the hub. Should have it back together tomorrow.
85 110 200tdi
Old November 14th, 2010, 12:26 PM
seaswood
Diesel
shocks
[QUOTE=adamdh1;
Are you doing the shocks? Yours look like mine did rusty 87-90 & they needed some convincing to come off.
I just finished the front axle rebuild, still need to fiddle with brakes as you are. SS lines are also easy once you are in there. Good Luck. Seems everything will need more work than would appear at onset.
Old November 23rd, 2010, 05:31 PM
adamdh1
ad
none
I'm not doing shocks at the moment. I think that I will soon though. Possibly new springs, shock towers and bushings as well. It seems the rear end has a whine now too. It's at the shop now getting a new head gasket and they are also looking at the rear end. If I do need new gears (which takes precedence over suspension), I might go with a full detroit. Should get news this week.
85 110 200tdi
110, door
Help Needed - NAS 110 New Style Door Sill Seals R. Kurk Defender Technical Discussions 14 December 12th, 2008 11:48 AM
110 top, 3-door solid sides, full rear door Method PHX For Sale - Parts 7 March 10th, 2006 04:07 PM
97 D90 SW - Inner rear door panel Kimos Wanted 5 December 2nd, 2004 09:26 AM
