83 110 restored - Page 6 - Defender Source
Old April 25th, 2012, 11:20 AM
Do you have a picture? If you want to be able to remove the floor, something like the black 3M sealer strips might be best (i forget the exact brand name), otherwise seam sealer is more permanent.
Originally Posted by pendy
I'm here for the D's
Old April 25th, 2012, 01:34 PM
Originally Posted by usadventureracing View Post
I put the rear floor in and there are many areas that are not completely sealed. What have others used to seal to make it "water tight"?
Unpossible
Better to let it drain. Factory was thin foam tape on a NAS 110.
Old April 25th, 2012, 08:00 PM
usadventureracing's Avatar
usadventureracing
Brett
110
Thanks guys that is what I used but still some gaps
Here is how she looks now
ID:	50783   Click image for larger version
1983 ROW D110
1970 Series III (Parting out)
Old April 28th, 2012, 04:03 PM
usadventureracing
Brett
110
My brake booster seems to be leaking around the edges will this stop after I bleed the brakes or does people think the seal has dried up because it was put of the truck so long ( abbott 4 months with no fluid in it? Can the seal be replaced?
1983 ROW D110
Old April 29th, 2012, 04:00 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Depends if the bore has corroded or it's just the seal that's gone, with brakes I'd always err on the side of caution and replace the master cylinder if at all suspect.
Mike Hammond
Old April 29th, 2012, 08:12 PM
usadventureracing
Brett
110
Thank you for the info, I am going to purchase a new brake servo.
1983 ROW D110
Old April 30th, 2012, 04:59 PM
Booster aka servo or master cylinder?
Old April 30th, 2012, 08:09 PM
usadventureracing
Brett
110
This part in the picture, I believe it is the servo
1983 ROW D110
Old April 30th, 2012, 08:14 PM
The servo/booster itself doesn't have any fluid in it. So if something is leaking it's coming from the master/reservoir. Whee is the leak?
Old April 30th, 2012, 08:54 PM
usadventureracing
Brett
110
Thanks for the info I cancelled my order. It looks to be leaking where the master goes into the servo.
1983 ROW D110
Old May 1st, 2012, 10:24 AM
Naplm00
Matthew
most likely the brake master is letting go. It is a easy 15min job with a power bleeder.
Just make sure you have some flare nut wrenches
Old May 1st, 2012, 11:13 AM
usadventureracing
Brett
110
Are you talking about replacing the brake master is only 15 min. job?
1983 ROW D110
Old May 1st, 2012, 11:17 AM
Maybe a bit longer, but replacing the MC is not hard if the lines come out of it.
Old May 1st, 2012, 07:03 PM
usadventureracing
Brett
110
Ok on to the next issue. For the life of me I cannot figure how to install the rear door bottom seal. There are two metal pieces and the seal, can anyone tell me how these all come together? Thanks!
1983 ROW D110
Old May 2nd, 2012, 01:46 PM
mikeslandrover
Mike Hammond
Post a piccy of the bits!
Mike Hammond
Old May 3rd, 2012, 05:54 PM
usadventureracing
Brett
110
Here are pictures.
ID:	51058   Click image for larger version
1983 ROW D110
Old May 3rd, 2012, 05:59 PM
mikeslandrover
Mike Hammond
I'll snap a pic of mine this weekend.
Mike Hammond
Old May 3rd, 2012, 06:12 PM
The metal sandwiches the rubber, but there are two versions so you might have the wrong seal if it is not lining up right.
Old May 4th, 2012, 05:34 PM
usadventureracing
Brett
110
That is what I thought, I am thinking the wrong seal also.
------ Follow up post added May 4th, 2012 04:36 PM ------
Installed the drive shafts and brake master. Everything is wired , just need to correctly install battery with cutoff switch.
------ Follow up post added May 4th, 2012 04:38 PM ------
Bleeding brakes tonight. Only now have to clean up and install the seats and she will be drive able. A new interior will be a work I'm progress later this year.
1983 ROW D110
Old May 12th, 2012, 12:41 PM
usadventureracing
Brett
110
Tool her on her first trip around the block. Now on to the interior.
ID:	51474   Click image for larger version
ID:	51476   Click image for larger version
1983 ROW D110
Will new rear door fit an 83 110 Stork17 Defender Technical Discussions 8 November 7th, 2008 08:56 AM
'83 110 Ujoint steinhnj Defender Technical Discussions 9 September 8th, 2008 08:47 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
