83 110 restored - Page 5 - Defender Source
Old March 24th, 2012, 11:22 AM
usadventureracing's Avatar
usadventureracing
Brett
110
I am getting no juice to the key
1983 ROW D110
1970 Series III (Parting out)
Old March 24th, 2012, 06:21 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
That's the numbering for a relay other than that I don't know.
It's obviously a LUCAS part so the smoke may well have already come out rendering it useless.
Mike Hammond
Old April 1st, 2012, 05:23 PM
usadventureracing
Brett
110
Great day today....I got all rear lights working and the front turn signals done. The fuel pump is ready to be hooked up as soon as all lights are working, do not want the pump to run every time I turn the power on to check the lights.
Still need to get the headlights and small white lights in front hooked up. Also need to tuck all wiring neatly under the hood once I have everything worked out.
Question.... Do the small lights in front go on with the headlights or should I be able to turn those on by themselves?
1983 ROW D110
Old April 1st, 2012, 05:35 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I think they should come on with the tail lights, at the first position on the light switch
Old April 1st, 2012, 05:54 PM
usadventureracing
Brett
110
Than you, that makes sense with the wiring configuration I have.
1983 ROW D110
Old April 6th, 2012, 05:07 PM
usadventureracing
Brett
110
Got her running and lights done. Bringing her home on a trailer on Saturday.
ID:	50020   Click image for larger version
ID:	50022   Click image for larger version
1983 ROW D110
Old April 8th, 2012, 06:34 PM
usadventureracing
Brett
110
Brought the truck he on saturday. Finished the rear wiring, it is tucked away neatly and installed the rear windows. Planning on installing the windshield and roof next weekend. Will them begin aligning the body.
1983 ROW D110
Old April 14th, 2012, 05:00 PM
usadventureracing
Brett
110
Any recommendations on fixing this issue with the door alignment. Thank you!!
ID:	50291   Click image for larger version
1983 ROW D110
Old April 15th, 2012, 03:04 AM
mikeslandrover
Mike Hammond
Is the roof on? As I said in my PM that can sort a lot out, I spent days agonising over the door gaps only for it to sort itself out when the roof went on.
If pic 2 is of the front door to the B post try pulling the front bulkhead forward at the top ( slacken the bolts for the small brackets that mount to the footwell and main chassis rail or take one of he alli spacers out from between the footwell and bracket. Rear door - any scope for movement in the bolt holes? Support the bottom of the door with a jack.
Hope this helps.
Mike Hammond
Old April 15th, 2012, 08:56 AM
usadventureracing
Brett
110
Yes the roof is on. I took the spacers out this morning and seems to make a difference. Now just need to tighten the brackets on the frame rails. Thanks again.
1983 ROW D110
Old April 15th, 2012, 09:57 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Best advice I can give you is to leave everything somewhat loose till you have it all where you want it.
Start with the bulkhead and get it at 90 degrees from the frame and start adding other stuff from there using the string method. Go slow and try not to force anything it took me days of slightly moving little things around to get it right but it looks better that it did when it left the factory. FWIW having the fenders on might make it a little harder but not sure.
String method
http://www.defendersource.com/forum/...ing#post225573
Old April 16th, 2012, 08:54 PM
usadventureracing
Brett
110
Any recommendation on where to get stainless bolts for the door hinges.
1983 ROW D110
Old April 16th, 2012, 09:08 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Got mine at http://www.a2stainless.co.uk/
Shipping took a while, but they warned me that the royal post/USPS was taking a looong time (about a month or so). Very pleased overall.
1970 SIIA 88, Sold
Old April 16th, 2012, 09:12 PM
A lot of folks like these guys (similar beveled head to the bolts as factory):
http://nakatanenga-tours.de/shop/cat...aram=cid%3D%26
But I went with Stig and like it:
http://www.a2stainless.co.uk/Defende...s-3_B22EP.aspx
------ Follow up post added April 16th, 2012 09:13 PM ------
Ha that's funny....crossed posts with Paul, we both got them from Stig!
Old April 17th, 2012, 07:09 PM
usadventureracing
Brett
110
Ordered a set from Stig today.
1983 ROW D110
Old April 24th, 2012, 07:21 AM
usadventureracing
Brett
110
Anyone know the size of the bolts that are needed for the top of the Front Radiator Panel to the wing. There are 2 bolts per side.
1983 ROW D110
Old April 24th, 2012, 09:21 AM
Naplm00
Matthew
If you are talking about the part that the slam latch is on. Mine were just M6 bolts, I replaced them with SS and new well nuts
Old April 24th, 2012, 10:05 AM
usadventureracing
Brett
110
it is actually the bolts that go through the front panel into the wings.......there is no nut as it looks threaded into the wings.
1983 ROW D110
Old April 24th, 2012, 10:49 AM
Pretty sure they are normal metric bolts.
Old April 25th, 2012, 11:06 AM
usadventureracing
Brett
110
I put the rear floor in and there are many areas that are not completely sealed. What have others used to seal to make it "water tight"?
1983 ROW D110
Will new rear door fit an 83 110 Stork17 Defender Technical Discussions 8 November 7th, 2008 08:56 AM
'83 110 Ujoint steinhnj Defender Technical Discussions 9 September 8th, 2008 08:47 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
