83 110 restored - Page 4 - Defender Source
Old February 29th, 2012, 03:06 PM
usadventureracing's Avatar
usadventureracing
Brett
110
No modification to the headers as they are stock to me, as they came with the truck when I got it.
1983 ROW D110
1970 Series III (Parting out)
Old March 11th, 2012, 05:59 PM
usadventureracing
Brett
110
Some pictures of my progress.
ID:	48933   Click image for larger version
ID:	48935   Click image for larger version
ID:	48937   Click image for larger version
1983 ROW D110
Old March 11th, 2012, 06:36 PM
usadventureracing
Brett
110
What type of
Brake fluid
Transmission fluid (99 auto trans from a discovery)
Power steering fluid
Should I get?
Thank you!
1983 ROW D110
Old March 11th, 2012, 06:43 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Originally Posted by usadventureracing View Post
What type of
Brake fluid
Should I get?
Thank you!
Brake fluid - D.O.T 4 is what I use.
Mike Hammond
Old March 11th, 2012, 07:25 PM
What type of
Brake fluid
Should I get?
Thank you!
Brake fluid = Castrol GT LMA (prob only from AB, not available anywhere else I've found).
Power Steering = ATF (auto tranny fluid, type IV I believe).
Old March 11th, 2012, 09:52 PM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
Castrol brake fluid is also available at Autozone.
Sal
Old March 11th, 2012, 10:32 PM
Sal
Are you sure? I checked Advance & AutoZone recently with nothing.
Old March 12th, 2012, 08:42 AM
Naplm00
Matthew
I use generic brand Dot 4 for brake fluid, and cheap universal mercon IV for PS fluid
Old March 12th, 2012, 11:09 AM
ATF type IV for the auto tranny as well as the power steering.
Originally Posted by pendy
I'm here for the D's
Old March 12th, 2012, 05:00 PM
budzny
Real4X4
Bought a big bottle two months ago from Autozone. Also try Pepboys!
Sal
Old March 12th, 2012, 05:07 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Does anyone have any advice/recommendation on cut the old footwells out? Should I cut them out?
I was in your shoes not too long ago. Looks like you are making great progress. I ended up cutting out all the cancer in my bulkhead with a sawzall and made my own footwells. Back then YRM would not ship to the US and RN did not have replacement panels. I would just buy from RN and be done with it. It only cost me $50 to make mine but they are no where as nice as the ones you can get now.
http://www.defendersource.com/forum/...7&postcount=74
http://www.defendersource.com/forum/...7&postcount=83
http://www.defendersource.com/forum/...&postcount=113
To install the footwells I made mine overlap the original bulkhead and I just glued them in with panel glue I got from home depot, as suggested by some members here, and bolted all along the edges. It is a very strong bond and I am not concerned. Welding would be better though.
http://www.defendersource.com/forum/...ad.php?t=22036
While you have the engine and tranny out, why not redo the clutch?
MUDSUX
Old March 16th, 2012, 03:05 PM
usadventureracing
Brett
110
Any recommendation on aligning the body? Meaning the t-posts, rear tub and bulkhead.
1983 ROW D110
Old March 16th, 2012, 03:14 PM
mikeslandrover
Mike Hammond
When I did mine nothing lined up at all until the roof went on. Bolt everything together reasonably loosely and then it'll pull together when the roof goes on. Having a little slack means you can adjust alignments, door gaps etc.
Mike Hammond
Old March 16th, 2012, 08:17 PM
usadventureracing
Brett
110
Thank you that is what I thought I was going to have to do. Going to install the front fenders on sat. Then start the wiring.
Does anyone know if I can buy a center cubby for an auto trans? If so do you have a recommendation.
1983 ROW D110
Old March 16th, 2012, 10:17 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I used the "string method". I'll try and find a link for you.
MUDSUX
Old March 17th, 2012, 08:19 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
String method outlined by JimC for lining up the tub:
http://www.defendersource.com/forum/...3&postcount=45
http://www.defendersource.com/forum/...&postcount=253
MUDSUX
Old March 21st, 2012, 07:47 PM
usadventureracing
Brett
110
So this ATF should work for the trans and power steering?
1983 ROW D110
Old March 21st, 2012, 09:01 PM
I've never used that but it should be fine.
Old March 22nd, 2012, 10:58 AM
I would NOT use synthetic fluid in a rover auto. It can clean out too much stuff and gum up the works. Get the cheap stuff.
Old March 24th, 2012, 10:53 AM
usadventureracing
Brett
110
Does anyone know what this for looks like main power goes in and then stops
1983 ROW D110
Will new rear door fit an 83 110 Stork17 Defender Technical Discussions 8 November 7th, 2008 08:56 AM
'83 110 Ujoint steinhnj Defender Technical Discussions 9 September 8th, 2008 08:47 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
