68 Series IIa Awakening - Defender Source
Old May 3rd, 2013, 01:51 PM
LRover's Avatar
LRover
J. Michael McCaig
The old girl has been sleeping in the barn for for awhile and, after I sold my D90, I decided I wanted to put her back on the road. I thought about sticking this in the Series Tech section but one thing is leading to another as so often is the case with Rovers and its turned into a project. Itís not a restoration as the truck is in pretty good shape but the original engine leaks oil profusely, needs brake work, steering work, etc.
I got this Rover while I was a senior in high school in 1971. I rebuilt it on a good used frame back in the early 80s as salt from running on the beach had worked its magic on the original frame. At the time I didnít do much to the engine as it was still in pretty good shape.
My plan is for it to get a 2.5TD as a repower and Iím working on a power steering conversion while I'm gathering other parts. I'm keeping my original steering wheel and most of the column as I want things to look as original as possible...plus you kinda get attached to things after 40 years. Using a P38 steering box and intermediate shaft. I've married the internal IIa shaft with a RRC shaft which works with the intermediate shaft.
ID:	71345   Click image for larger version
ID:	71347   Click image for larger version
Old May 3rd, 2013, 01:54 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Cool!!!!
Perfect timing, I'm looking into a 66 SIIa and have a bunch of RRC and DI parts I was wondering if I could use on the Series.
I'm very interested in your project. Thanks for sharing!
John C.
Old May 3rd, 2013, 02:06 PM
Mike, just FYI, the 3/4-48 steering shaft is a common size. It is standard V-dub, so there are oodles of steering shaft pieces available. You can get the u-joints fairly cheap, and a flange mounted 3/4 inch bearing from mcmaster. I know you are already along the way on this aspect of the project, so I am not second-guessing you or anything. There are plenty of ways to make it work.
Old May 3rd, 2013, 02:21 PM
I love the capstan and the rare tropical pick up can roof.
Old May 3rd, 2013, 03:16 PM
LRover's Avatar
LRover
J. Michael McCaig
Bill - thanks for the info. I didn't know that the shaft had a common spline count. I had an extra Series steering box so it got sacrificed for the project. The P38 box came with the intermediate shaft and is working out to be the right length. I'm working on the steering box mount now so I hope to have some more photos up once is is bolted to the frame.
Ron - I don't know if I can use the capstan with the 2.5TD. The front pulley bolt looks different from the 2.25 petrol.
Old May 3rd, 2013, 03:18 PM
Certainly 2.5 were fitted with capstans. I hope it is just a matter of finding the right crank part and adapting the shaft (maybe). If nothing else, I would leave it on for decoration.
Old May 3rd, 2013, 03:27 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
There a couple different "starting dogs" for the capstan winches. For sure there was one that will fit your engine.
Your winch looks like this one, is it?
http://www.ovlr.org/jberg/capstan.pdf
great story BTW.. restoring your HS truck. -awesome.
~Steve
Old May 3rd, 2013, 03:39 PM
LRover's Avatar
LRover
J. Michael McCaig
Steve - Thanks for the pdf. Looks like there is a different starting dog for the 5 bearing engines so hopefully I can track one down. My winch is made by Fairey so it is a little different than the one in the pdf.
Old May 3rd, 2013, 03:56 PM
For the capstan drive, I would be caught trying to adapt a 30MM socket to the drive. chuck it in a lathe and bore the square drive out, and then weld it on the drive shaft (or cross drill it for a shear pin). I'm not 100% on this but I'd be willing to bet that the Fairey drive, if it is square shaft, is your standard issue farmer Bob 15hp square PTO drive stuff, available from every Tractor Supply on earth.
Hey if it fails, you can try taking it back to Sears.
Old May 3rd, 2013, 04:21 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Aah a Fairey, yep thats different. Check Ebay for the part, you'll probably find what you need! At least a pic is something to start with.
Not a bad idea Bill, and the torque load on the parts is not beyond good socket specs I'm sure. The shear pins are pretty thin.
Old May 3rd, 2013, 06:59 PM
So clean how they trimmed the front apron panel and riveted on side pieces and I like the extra supports under the bumper there. Very nice mount. Nicest I have seen.
Old May 6th, 2013, 08:34 AM
LRover's Avatar
LRover
J. Michael McCaig
Thanks for the comments on the capstan. I installed that back in the early 80s when you could still by them new. I did find the right winch drive/starter dog and bolt for the 2.5 on ebay UK and it's on the way so I hope to get it working after the engine swap.
I had some time on Sunday afternoon to work in the shop and got the powersteering box mounted. Still have to fab up a draglink. I'll work on the hoses after I get the 2.5 in.
ID:	71603   Click image for larger version
Old May 24th, 2013, 04:25 PM
LRover's Avatar
LRover
J. Michael McCaig
Finally had some time to make up the drag link. I'll try to post up a photo or two later. The capstan winch drive for the 19j came in from HNJ Engineering in the UK. Really a nice replacement with the correct metric bolt with a dished head. I've been giving a lot of thought to a disk brake upgrade but in the meantime I will work on pulling the old 2.25...
Old May 25th, 2013, 03:20 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
2.5 TD... Not the most reliable engine ever produced. I've heard putting an intercooler on but not upping the fuel/boost helps with the reliability. They had a tendency to blow the engine oil through the intake and rev to destruction on the engine oil as they couldn't be shut off
200 tdi's can do it too!
Bad maintenance I think has much to answer for
Great job on the steering, look forward to reading about the rest of the build.
Mike Hammond
Old May 30th, 2013, 04:43 PM
LRover's Avatar
LRover
J. Michael McCaig
The 2.5TD does have a bad rep in some circles but plenty of well maintained examples have clocked over 200k miles. I think it is a good choice for a light weight IIa 88 like mine because it allows me to do the install with a minimum of mods and is an upgrade from the 2.25. Seems to be a fairly common engine swap for Series trucks in the UK from what I've read. If this was a heavy equipped 110 it might be a different story. The engine I'm using has very little blowby so oil in the intake shouldn't be an issue.
The old 2.25 is out and the battery tray and right side engine mount are gone so there is no turning back now. I have decided to go to a dual brake circuit and disc brakes. I will run the new brake lines and clean up some wiring before the 19j goes in. Photo of the extended drag I worked up is attached. It will do until I can get someone to make one for me out of stainless
ID:	73512   Click image for larger version
Name:	battery tray gone.jpg
Old May 30th, 2013, 07:32 PM
I see you are of the rag-joint-at-the-top school of thought. I put mine at the bottom.
Old June 1st, 2013, 08:59 AM
Why didn't they just put it in gear and let it stall out?
Old June 1st, 2013, 12:49 PM
mikeslandrover
Mike Hammond
It's doing Max revs! It'd just take off across the field until it crashed into something immovable!
Mike Hammond
Old June 1st, 2013, 12:56 PM
Fifth gear, handbrake, standing on the brakes might have worked.
Plywood over the air intake might have worked.
Old June 1st, 2013, 01:51 PM
mikeslandrover
Mike Hammond
I think that by the time an engine does that it's pretty much toast.
Proper maintenance would have prevented it!
Mike Hammond
series
Series IIA 88 Rolling Chassis and 2.5 Turner engine, tub, drivetrain, etc Macker For Sale - Parts 21 July 24th, 2013 11:20 AM
1962 Land Rover Series IIa 88'' refurbished Mike Sandone For Sale - Vehicles 2 October 22nd, 2012 04:25 PM
Series IIa short wheel base TDI Guy Wanted 3 August 12th, 2004 01:15 PM
Great looking Series IIA on EBay boshea Misc. Chit-Chat 3 April 24th, 2004 12:14 PM
