#646 prep for paint... - Page 5 - Defender Source
Old September 1st, 2013, 06:05 PM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
Originally Posted by RX6RCROL View Post
Happy Birthday big brother!!
Thanks Matt!
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old September 1st, 2013, 07:56 PM
rovertrader's Avatar
rovertrader
Dale
Hap Hap Happy B-Day my friend!!
Old September 1st, 2013, 08:15 PM
Willh's Avatar
Willh
Will Hedrick
I raise my glass to you! Happy Birthday.
-Jeff
Many thanks gentleman! It's been a good day!
Old September 1st, 2013, 08:34 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Hope you had a great day! Happy bday dude!!!
Old September 1st, 2013, 10:37 PM
Willh's Avatar
Willh
Will Hedrick
Thanks man!
Old September 2nd, 2013, 08:58 PM
Willh's Avatar
Willh
Will Hedrick
My plan was to mount the plinths for the tail lamps. But in order to do that....I had to remount the rear SD ladder...so I could mount the tail lamp guards. The SD ladders already had the previous mounting holes drilled. I simply mounted it up. The driver's side rear lamp guards then abut the lower ladder mount. By marking, drilling and mounting those, life was made much easier for mounting the new plinths. I used a level to make sure the lamp screws were in line, so as to keep them uniform across the back.
So far, so good! Now just need the correct hole saw to fit the lamps through the body. Hopefully I have corrected enough for the known problem with the '94 cage supports. We'll see....
Also installed new bulkhead air vent pins and connected the handles.
ID:	78906   Click image for larger version
ID:	78908   Click image for larger version
ID:	78910   Click image for larger version
Old September 9th, 2013, 10:02 AM
Willh's Avatar
Willh
Will Hedrick
I've been away at the beach this past week with my family. And a glorious time it was! When we arrived back home last night, I had a nice parcel waiting on my porch from our friends at Rovers North. Many thanks Les!
Old September 11th, 2013, 08:12 AM
Willh's Avatar
Willh
Will Hedrick
Update: Set to work reinstalling the doors last night. First, installed new door seals all around. We purchased full SW door seals so I used the excess on the rear tailgate. Next, I installed the freshly painted door hinges. I haven't seen many of this type of hinge painted (most leave them black), so we'll see how they hold up. Also installed the rearview mirrors.
Then I set to work lining up the doors. This included installing the door handles. They had a bit of surface rust on them, so I hit them with some black paint before installing to make them look a little better. Once the doors were lined up, I installed the door stops with new bolts. Then I set to work reconnecting the speakers and reattaching the door cards. They are the original cards, and a little worn, but they cleaned up pretty well. I did get a set of new door pulls (handles) since the originals had gone missing. You never realize how much you miss these until they are gone!
All of that and voila', doors!
P.S.- Still have to install the lower door seals.
ID:	79550   Click image for larger version
ID:	79552   Click image for larger version
ID:	79554   Click image for larger version
ID:	79556   Click image for larger version
ID:	79558   Click image for larger version
Old September 22nd, 2013, 10:11 PM
Willh's Avatar
Willh
Will Hedrick
No real progress to report. Just been busy with other obligations these past couple of weeks.
That being said, she has seen the light of day. I let her stretch her legs a couple of times around the block this afternoon and then left her to idle in the driveway for a bit. Just wanted to keep the battery charged and fluids circulating. You know how these trucks hate sitting!
Funny thing is, last time I drove her, she was leaking like a sieve from the front of the motor. And today not a drop! That's a Rover for you.....
ID:	80575   Click image for larger version
Old September 22nd, 2013, 10:13 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Is out of fluid? Can you give me a quick call? I need to ask you a question if possible
Old September 30th, 2013, 10:28 PM
Willh's Avatar
Willh
Will Hedrick
Had a little time this evening, so I set to cutting the holes for the rear lights. Only had enough time and battery on the cordless drill to get the passenger side done. I'll have to finish the other side up tomorrow. Then on to wiring them!
Also, installed the brand new half tonneau cover we acquired from RDS a few weeks ago.
Getting there, slowly but surely.
ID:	81245   Click image for larger version
Old October 4th, 2013, 11:44 PM
Willh's Avatar
Willh
Will Hedrick
Update: Let there be light....
Worked on finishing out the holes for the rear lamps. Then moved on to cutting in the holes for the front side marker lamps. With those mounted, I was able to start on the wiring for the front lights. Having the front headlamp already out gave easy access to the wiring. While I was at it, I went ahead and wired in a new horn, as the old one was missing.
I also went ahead and did the turn signal conversion using a Series rear brake light in place of the lower front marker lamp. It will now stay lit when the marker lamps are on and flash brighter when the turn signal is used. Also installed new bezels from RN and tossed the old cracked ones.
She's starting to look road worthy once more!
ID:	81557   Click image for larger version
ID:	81559   Click image for larger version
Old October 5th, 2013, 12:41 AM
rovertrader
Dale
Looking good William!! Matt must be getting stoked...
Old October 9th, 2013, 09:53 PM
Willh's Avatar
Willh
Will Hedrick
Update: Brothers & Wrenching
My family unexpectedly suffered the loss of my oldest brother, Robert, this past weekend. And in our time of sorrow, we've come to truly know just how much he was loved and will be missed by his family and his friends.
As unfortunate as the circumstances have been surrounding Robert's passing, I was glad to see my brother Matt, as he came home to pay his respects and visit with our family, even if only briefly. Not having seen each other face to face in 6+ months, we did what I imagine many of us would do under the circumstances, and spent some time working and chatting together in the garage.
I was very glad for him to see, in person, the progress which I'd made on his 90 since he left it with me back in the spring (he's been following this thread just as many of you have). And I was more than appreciative to have his help in reinstalling the roll cage, which I'd been putting off for a little while . It took a little more torquing and adjusting to get it refitted than I think either of us anticipated when we started on it this afternoon, but we got it done, and with enough time leftover for dinner at our folk's house before taking him back to the airport.
As nice as it was to see fewer rover parts sitting on the floor of my garage, it was even nicer to see my brother. Matt, hope you have a safe flight and I'll look to have her finished and sorted before your next visit home!
ID:	81860   Click image for larger version
Old October 9th, 2013, 10:06 PM
Will,
Truly sorry for your loss! Will keep your family in my thoughts and prayers.
See you at ure?
Old October 9th, 2013, 10:28 PM
Willh's Avatar
Willh
Will Hedrick
Originally Posted by woldd90 View Post
Will, Truly sorry for your loss! Will keep your family in my thoughts and prayers. See you at ure?
Thanks Scott. We appreciate it.
And well, as for URE....I'm not saying "yes"..... (.....but I'm not saying "no" either).
Old October 9th, 2013, 11:38 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
The man at work.
Old October 10th, 2013, 02:25 AM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Sorry to hear about your loss. I'll keep you in my prayers.
My Rover doesn’t leak oil, she is marking her territory.
Old October 10th, 2013, 06:00 AM
rovertrader
Dale
While it is always sad to see a close friend suffer such a loss, it is even more so to when said family consist of several friends- our condolences to you, Matt, Ben, Kat, and the rest of your amazing family!! You are all in our prayers my friends.
Old October 10th, 2013, 09:50 AM
Looks great guys, that truck has really come a long way.
I'm sorry to hear about your loss!
1994 D-90 #646 RX6RCROL Wanted 17 December 12th, 2012 02:47 PM
Land Rover Defender KOH 2011 Prep Buckon37s Defender Technical Discussions 44 February 15th, 2011 08:33 AM
Upgraded Hinge Prep and Install gas-man Defender Technical Discussions 2 May 18th, 2010 10:39 PM
Winter prep thewap Defender Technical Discussions 16 October 7th, 2006 11:42 PM
Painting prep kellymoe Defender Technical Discussions 2 February 9th, 2004 10:05 PM
