#646 prep for paint... - Page 2 - Defender Source
Old July 9th, 2013, 11:30 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Looking good guys!!! Paint on it will make the biggest difference!! If you guys need anything let me know!
Old July 9th, 2013, 11:36 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Looking good. Since you've already stripped the truck down to its current state, you should go ahead and pull the wings and bonnet. The further you can disassemble the truck, the more thorough the paint job will be. The body seams on these trucks are prone to paint buildup, and that extra disassembly can make the difference between a great job and one that's just good.
Old July 9th, 2013, 11:52 AM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
Originally Posted by rijosho View Post
Those rear panels that Will fabricated look great. And those cappings are always forgiving for any edges that weren't cut quite perfectly. Are you going to put the 1994 style rear lights back there or 1995/97 style, or something else?
Thanks Josh! They should be good to go once painted and riveted back in place. As for the tail lamps, Brian (below) is holding a set from a '95 NAS for us. I'm not 100% sure if they'll fit though. We'll see.
------ Follow up post added July 9th, 2013 11:53 AM ------
Thanks Brian! I think so too. I still need to make it out your way to pick up those lights!
------ Follow up post added July 9th, 2013 12:00 PM ------
Thanks Ash! The body shop is supposed to be pulling the hood (i.e., bonnet) off as well, so they can get to the section of bulkhead that it sits in front of. We're not going to worry with removing the front wings, just not a concern for us at this point. Again, she's not meant to be a show queen.
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old July 9th, 2013, 12:11 PM
I've seen quite a few of the 1995/97 lights utilized with the 1994 cappings. I've never inspected them closely (only seen them in pics) but there may be a little wedge space between the body and the lights, because the cappings are different. If all else fails, you can probably use the extra aluminum you probably have laying around, to cut it to the dimensions of the light housings, and then cut off the odd side where the capping would overlap, and the aluminum piece would act as your "wedge" to even out the backing surface of the lights. Probably not clear in words, but maybe you get my point. FlaD90 also posted a thread with a good template on it for 1994 to 1995 light conversion. Or just cut down the cappings to the correct 1995-97 specs while you have them off.
Old July 9th, 2013, 12:29 PM
Willh's Avatar
Willh
Will Hedrick
Thanks Josh, I've actually read his post. However, he's using LED's and not factory '95 tail lights. ECR did a write up on this subject too here on the forum. From what I've investigated, the lights furthest out on either side may not fit because the mounting for the bulbs used by the factory lights extends into the area occupied by the '94's rear roll cage support. I might be able to modify, but won't know for sure until I can get my hands on them.....
Old July 9th, 2013, 12:43 PM
You're right - LEDs = no plinths, just pigtails, so there is the potential for interference with the under tub supports with the plinths. I remember ECR had a good write-up on it a ton of years ago, but I thought that was for NAS 110s for some reason. I know JimC did it on his NAS 110. That was the only conversion I had seen up close, and there was still a little space where you could see the old 1994 light hole. Of course, since you'll be starting with a naked rear panel, you won't have any pre-existing hole to deal with, and you can probably move the template in a few mm's to suit any interference you may otherwise have with the unter tub supports.
Old July 9th, 2013, 01:45 PM
Willh's Avatar
Willh
Will Hedrick
That is what I'm hoping....so long as I don't have to move them too far. This may not be a concourse quality restoration, but I do have OCD moments regarding certain particulars.
Old July 16th, 2013, 08:48 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Old July 16th, 2013, 08:56 AM
Willh's Avatar
Willh
Will Hedrick
Looks good, brother!
Old July 16th, 2013, 09:41 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
What body shop are you using?
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old July 16th, 2013, 09:57 AM
87 D110 (Ruby)
Get those wheels covered up quickly
Old July 16th, 2013, 10:14 AM
Willh's Avatar
Willh
Will Hedrick
I though the new panels were going to go on before paint.
-Jeff
Jeff, no they'll be going on afterwards. I had them painted separately. This is in part due to the facts that they are held on by the rear tub cappings, and I wanted them painted separately as well.
------ Follow up post added July 16th, 2013 10:14 AM ------
Maaco in Raleigh.
------ Follow up post added July 16th, 2013 10:17 AM ------
No worries. The wheels were covered up. They had to uncover them to roll it into the baking booth last night. We knew there would be a bit of overspray in some areas, so we're not concerned. However, I noticed that the rear crossmember bolts for the tub look to be painted. They were supposed to be taped, and hopefully, they are.
Old July 16th, 2013, 10:33 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Old July 16th, 2013, 10:58 AM
Did they paint the vent screens on the bulkhead? I'm hoping there's tape there and they just painted over that! Coming along nicely.
Old July 16th, 2013, 11:37 AM
Willh's Avatar
Willh
Will Hedrick
Josh, they are taped over. And thanks! We're very pleased!
Old July 16th, 2013, 01:17 PM
rovertrader's Avatar
rovertrader
Dale
Frigging hot in the barn today, so needed some noon time updates- looks great guys, well done and for the budget, just awesome!!
Well done!!
Will, I'll try to check on parts request today- gotta get some of Matts $$ ;-)
Old July 16th, 2013, 02:05 PM
Willh's Avatar
Willh
Will Hedrick
Well done!!
Thanks Dale! Hopefully picking her up tomorrow. After that, I'll need to schedule a trip down your way.
Old July 17th, 2013, 05:02 PM
Willh's Avatar
Willh
Will Hedrick
Back home from the paint shop! Hope to have some time to begin some reassembly thus weekend.
ID:	76051   Click image for larger version
Old July 18th, 2013, 12:18 PM
rovertrader
Dale
Found a brand new set of new take off stock front springs if Matt is still going that direction.
Old August 17th, 2013, 10:46 PM
Willh's Avatar
Willh
Will Hedrick
My apologies for the delay in any updates. We had some issues with the paint which required taking the 90 back to the painters.
That being said, I had a productive day today. Did a semi restoration on the rear # plaque (amazing what you can do with a Sharpie!). Body capping a have been reinstalled along with the new rear panels I fabricated. Also installed the soft top rails, fuel filler neck, tailgate, spare tire carrier, spare tire, spare tire cover license plate lamp, and license plate mount.
ID:	77845   Click image for larger version
ID:	77847   Click image for larger version
ID:	77849   Click image for larger version
1994 D-90 #646 RX6RCROL Wanted 17 December 12th, 2012 02:47 PM
Land Rover Defender KOH 2011 Prep Buckon37s Defender Technical Discussions 44 February 15th, 2011 08:33 AM
Upgraded Hinge Prep and Install gas-man Defender Technical Discussions 2 May 18th, 2010 10:39 PM
Winter prep thewap Defender Technical Discussions 16 October 7th, 2006 11:42 PM
Painting prep kellymoe Defender Technical Discussions 2 February 9th, 2004 10:05 PM
