63 Series IIA 109 PU Hybrid Electric - Page 2 - Defender Source
Old December 2nd, 2012, 07:21 PM
Got time to work on the truck today. I pulled the right wing, sills (PITA), seat box and undid the tub bolts. I was going to scrounge up help to remove it and decided it was better to leave it in place while I strip all the top end steel since I have nowhere to work on it anyway. I gave the drivetrain a quick powerwash instead!
ID:	62003 Click image for larger version
ID:	62005 Click image for larger version
That is actually very cool. Are you a '63 vintage yourself?
No but the wife is.
Originally Posted by pendy
I'm here for the D's
Old December 2nd, 2012, 08:20 PM
Attachment 62003 Attachment 62005 Attachment 62004
No but the wife is.
You've giving me hope for my timeline on the 88 rebuild.
Old December 2nd, 2012, 08:22 PM
I don't plan on sizing the drivetrain to be a whole lot more than stock, but can't say how many HP yet. But I can tell you that shifting gears should happen less often than with a gas engine due to a larger power band on the electric.
I think it's important to note that power output of the 3phase AC motor is electronically controlled. EV controllers are able to use PWM and other techniques to adjust torque variably up to the peak maximum available to the motor. Even if one had a 300hp 300Nm torque motor, it could easily be to controlled to account for the weaknesses of the drivetrain.
I'm personally a fan of ditching the transmission altogether. There are dana end yokes available to fit on motors which can couple to driveshafts directly.
But of course the best solution is sometimes whatever is easiest and available. Given the cost of 3phase motors and controllers, it might be more of an issue of what one can find for cheap and building around it.
Maybe the best way to start would be to pull the transfer case and transmission from the truck and put the rest of the truck somewhere else. Make a tranny stand out of wood 2x4's on wheels and bolt the transfer case and transmission to it. Now you are free to look at it and take critical measurements and slowly add pieces to the assembly until you have a working drivetrain.
Old December 2nd, 2012, 08:23 PM
Don't get too excited. The tear down is the easy/fast part part and I'm taking off big chunks at a time and haven't separated any steel from aluminum yet
Old December 2nd, 2012, 08:35 PM
I think this would be nice however it might make the most sense to keep the transfer case and send power to both the front and the rear since the pumpkins are offset. I seem to remember reading someone was using a LT230 divorced from some other transmission so I assume adapters are available. I could of course put a different rear axle in with a centered pumpkin with a driveshaft direct to a motor that can do high rpms. I need to run the numbers using different gear ratios and see what would be needed.
But I need to spend some time looking at my options. AC stuff will be much more expensive but would allow direct drive and regen. Those siemens motors from evtv I was telling you about are looking tempting but then I need an expensive inverter, and controller to match - none of it supported or warrantied. Probably not a good first time conversion choice.
Old December 2nd, 2012, 08:42 PM
Yes, now is the time to pray to the DIY gods that they deliver something powerful and cheap. Of course I am doing reading on my own also since you've gotten me interested in the topic, lol
Old December 2nd, 2012, 09:01 PM
A forklift motor and a bunch of 8D AGM deep cells, divorced LT230, and lots of beer. Winning!
Old December 2nd, 2012, 09:05 PM
I agree with everything except the batteries. It's a false economy with LA.
Know of any forklifts going cheap?
Old December 2nd, 2012, 09:12 PM
Look in Baltimore, I think there's a used forklift place. Also look on gov liquidation. They sell stuff like that at Ft Meade regularly.
Old December 6th, 2012, 11:13 PM
There is a lot more steel on the tub than you might think!
ID:	62343 Click image for larger version
Old December 7th, 2012, 06:42 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I like the idea of keeping the t-case and 4WD. I'm running a divorced LT230. I did not find an off the shelf adapter. I used a stock input shaft and had a flange welded to the front end of it. Also had to build mounts to hold it in place with out the tranny on the front end.
Old December 7th, 2012, 07:16 AM
Thanks Dan, that's great to know.
Old December 7th, 2012, 07:37 AM
Oh boy, that's rivet-licious.
Old December 8th, 2012, 11:29 PM
Charles,
What was the fastest/easiest way you found to remove the solid rivets on the bed?
I ground a couple down with a grinder and flap discs but it was noisy and took forever?
Old December 8th, 2012, 11:32 PM
I always hit them with a punch and then drill them out.
Old December 8th, 2012, 11:33 PM
Thanks to Bill, a wood chisel on the steel side, and then knocked the rivet out with a punch. In some cases I punched and drilled a hole in the center first if I didn't have good clearance.
Old December 9th, 2012, 08:21 AM
Thanks charles and jeff, will let you know how it goes , ron I will try you method also
Old December 10th, 2012, 10:20 PM
No love with the cold chisel and hammer.
I found out that my truck doesn't use solid rivets. It uses something called a Huck Magnagrip.
The heads are steel and pounding on them with the chisel doesn't seem to do anything.
I guess I am drilling these out.
Old December 10th, 2012, 10:53 PM
Are we talking your 90 or your CRV? What rivets are you trying to remove? How sharp is your cold chisel?
-Jeff
Believe it or not, the truck made in 1984! There are maybe...16 of them holding down the floor of the bed onto the tub supports, which I am trying to remove for galvanizing. Apparently Charles's children can do it, but I can't, hah!
Well, OK, maybe they're not magnagrips. But they look like a magnagrip. In the photo you'll see there is a collar pressed around the shaft. I cut one in half with a dremel so you can see the cross section.
The cold chisel is sharp although the angle isn't particularly acute. That picture is after I tried banging on the rivet hard for a while. It just doesn't budge.
ID:	62577   Click image for larger version
Old December 10th, 2012, 11:07 PM
Believe it or not, the truck made in 1984! .
Yeah but what year is it really ?
109, series
Brake options for my 109' IIA hybrid electric cgalpin Series Technical Discussions 13 July 30th, 2013 02:14 PM
1965 Land Rover Series IIa 109 Frame-up Restoration - $100,000 (Asheville, NC) rijosho The Flea Market 11 September 18th, 2011 01:58 PM
67 Series IIA 109 5 Door C-Delta For Sale - Vehicles 1 August 10th, 2006 02:40 AM
