63 Series IIA 109 PU Hybrid Electric - Page 16 - Defender Source
Old July 2nd, 2015, 11:06 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Absolutely nothing wrong seeing Rover chrome and custom milled suspension pieces up:
Old July 5th, 2015, 06:10 PM
I got the rear air springs installed. These line up perfectly, and after a closer look I realize the holes for the turret parts are exactly like the front so my custom pucs are fine.
At maximum compression allowed, it looks like I need 1.5" extension to the bump stops
ID:	124333 Click image for larger version
They have 10" of travel. Sam for the front although it still doesn't look right to me.
ID:	124335 Click image for larger version
I zinc plated some bolts for the anti-sway bars. I am waiting for hardware to finish installing the rears and then will take pictures of the anti-sway bars installed
ID:	124337 Click image for larger version
Bolted on a few more bits before running out of hardware...again.
Originally Posted by pendy
I'm here for the D's
Old July 5th, 2015, 08:18 PM
Baller! Looking good, Charles!
Old July 5th, 2015, 09:50 PM
Nice to see you got the bloom under control. Plating is the shiz.
Old July 6th, 2015, 12:08 PM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
Great progress, Charles. Looking awesome. Love all the home engineering/fabrication.
Old September 20th, 2015, 09:03 PM
This thread is overdue for an update, although it doesn't look like over 2 months of progress!
At some point I spruced up the steering box. Replaced the seals and gave it an old change and a coat of paint.
ID:	130225 Click image for larger version
ID:	130227 Click image for larger version
I also zinc plated the nut and washer, and painted the pitman arm since I had to use a map gas torch to remove the galvy from the splines. I'll take pictures once I get the steering hooked up.
I don't seem to have taken any pictures but I had the drag link and steering arm powder coated a while ago, and today I screwed in the new tie rod ends. It required significant force and it looks like I split the small piece on one side that allows you to turn it and adjust the drag link without undoing the ball joints (RRC setup). So I'll need to lookup that part number and get a replacement.
Old September 20th, 2015, 09:11 PM
Diff rebuild
Over a protracted period I collected new bearings and HD 4.75 gears for my diffs and rebuilt them. First the bearings
ID:	130229 Click image for larger version
ID:	130231 Click image for larger version
ID:	130233 Click image for larger version
ID:	130234 Click image for larger version
Then the new crown rings
ID:	130235 Click image for larger version
Old September 20th, 2015, 09:17 PM
I borrowed Jeff's awesome tool he made to hold the diff and allow you to turn it to the orientation most useful for the task.
ID:	130242 Click image for larger version
ID:	130245 Click image for larger version
And this is what I ended up for a gear pattern. Still really not 100% sure this is a good pattern, but I'm calling this good.
ID:	130240 Click image for larger version
ID:	130247 Click image for larger version
Old September 20th, 2015, 09:25 PM
With the diffs done, I could install the front and finish up building out the front axle. I put on the rrc brake bracket but suspect I'll want to get the defender ones.
ID:	130249 Click image for larger version
ID:	130251 Click image for larger version
I have run into a problem with the brakes. I have bought D90 front brake calipers but they use a larger bolt than the RRC. The RRC uses a M12 1.25 thread bolt, but the D90 calipers use a bolt with a larger shoulder and 1/2" -13 course thread. Not sure what the proper fix is but if I have to drill and tap the hubs to 1/2" -13 it will suck since everything is now mounted.
But being able to put wheels on it allowed me to do a maiden roll!
Oh, this week i scored some free used LiFeP04 batteries to do some testing and experimenting with. They are a bit janky but hopefully will give me some experience with this chemistry and test some of my gear. I need to pick a direction for a battery management/monitoring system and this would be a good test bed for that too.
Old September 20th, 2015, 09:28 PM
99% sure it's the RRC arm - is this bad? I have not tried to hook up the steering arm yet.
The box is a manual one from a defender but I don't think it's drop is any different.
Are you running a Disco or a RRC/Defender arm?
-Jeff
Old September 20th, 2015, 09:45 PM
Aah, this is the Disco style then as I have tie rod ends on both ends of the rod and just a tapered hole in the arm. Basically flat as well. So maybe it came with the box. I really don't remember.
Old September 20th, 2015, 09:58 PM
nice! Is that a little Yuasa 6V on the ground by those used LiPos? Those batts are gigantic...
Old September 20th, 2015, 10:12 PM
Yeah, that's a standard UPS battery for scale. They are huge and heavy - about 30 lbs each I think. 25 of those have the same capacity as 100 of the ones I am getting, although these in series are not high enough voltage to drive my inverter. Who knows, if these test out as good, maybe we'll be seeing a DC motor based wheeling build one day! Think a quick and dirty conversion of a disco maintaining the transmission and doing nothing but pulling the motor and putting in an electric motor and batteries. No rehab or anything other than saws work where desired :0.
Old December 26th, 2015, 09:07 PM
enzorover
Bill
1960 Series 2a Hybrid
Glad to see you're still working on this conversion.
Are those 400ah Winston cells? What on Earth are you going to do with those?
I assume you're using CA100's? Have you bought them yet?
If you haven't bought a charger or DC-DC converter yet, salvaged Volt parts are cheap and will work perfectly for you.
I started working at EVTV a couple months ago. If you need help with anything just let me know!
Bill
Old December 28th, 2015, 08:45 PM
Yes, 400ah Winstons. Really just using them to learn and test stuff (got them free). Santa brought me a powerlab which I plan to use to start charging and measuring them, and then try bottom balance them.
I have not bought my call 100ah yet. Holding off till the very end since I'm going so slow. I have not ruled out leaf batteries or other options since they are so expensive, but realistically I need to get this thing done so avoid too many diversions
I have the DC-DC convertor but still need a charger. Holding off on that too, but have my heart set on a liquid cooled one so I can mount it under my front battery box or under the motor - plenty of room but a harsh environment. I was planning on a bru$a but will look into the volt stuff too.
I haven't had time to keep up with Jack's videos but did watch one a couple weeks ago when doing my year end book keeping and was pleased to see you on (although I hadn't made the connection to you here). Good to know, and congrats!
Old December 28th, 2015, 10:34 PM
enzorover
Bill
Well, bottom balancing is like watching paint dry...BBing 400ah cells is watching for a very, VERY long time.
If your cells are sitting at 3.3v it will take about 8-10hrs to get them down to 2.5v using a 250w resistor.
I've never used a Powerlab but don't underestimate the amount of energy in those cells...keep a close eye on the voltage in your 12v battery.
Leaf cells are more energy dense and about 8x cheaper than LiFEPO4 cells but they're also more dangerous if something goes wrong. They can't really be bottom balanced so need some sort of low-voltage disconnect system. If the pack over discharges, it's possible that the weakest cell could go to 0 which, in turn, could create an explosive over charge situation. <-- That's what happened to Jack's shop...
It's no reason to avoid them. They really are great value and plentiful. They just require some awareness and respect.
Tesla modules are becoming available also and are more energy dense than the Leaf.
85kwh pack for less than 100 CALB's: 2013 Tesla Model s P85 Battery 85KWH 1014114 00 B 16 458 Miles | eBay
Your 109 could have a 200mi range.
Old December 30th, 2015, 09:05 PM
Haha, who knows - i might be able to buy direct from the giga-factory by the time I am ready for batteries. But seriously, I have decided the very last thing I am doing is buying the batteries. I already have to redo the front battery box, so why not the rear too
Old March 29th, 2016, 09:20 AM
enzorover
Bill
Any updates??
Summer cometh!
Old March 29th, 2016, 06:12 PM
Sadly none. Still barely keeping my head above water.
Old May 15th, 2016, 09:11 PM
Some progress
Finally some progress, and hopefully the beginning of more, and not an anomaly.
This week I tore down the LT230 and gave it a bath. Just a clean and re-seal since it's in great shape otherwise. Will get it put back together with new o-rings, seals, gaskets, high capacity sump, and flanges this week.
ID:	149602 Click image for larger version
I still need to powder coat the brake drum and locate the galvanized backing plate before being able to mount the drum brake, as well as drill and tap the sump for a temperature sender. I probably need to buy another difflock switch and breather too if I can't find them
109, series
Brake options for my 109' IIA hybrid electric cgalpin Series Technical Discussions 13 July 30th, 2013 02:14 PM
1965 Land Rover Series IIa 109 Frame-up Restoration - $100,000 (Asheville, NC) rijosho The Flea Market 11 September 18th, 2011 01:58 PM
67 Series IIA 109 5 Door C-Delta For Sale - Vehicles 1 August 10th, 2006 02:40 AM
