63 Series IIA 109 PU Hybrid Electric - Page 14 - Defender Source
Old April 15th, 2015, 10:23 PM
Originally Posted by lordhelemt View Post
Looking good. I can appreciate how much of a pita it is to prep all those greasy and rusted parts.
Yeah I know better and I am still amazed at how much time it takes.
Originally Posted by Brewie212 View Post
Can we get a side shot of the rear of the chassis with that cool custom gas tank cradle?
You mean those sweet things you got cut and bent up for me?
ID:	118464 Click image for larger version
ID:	118465 Click image for larger version
More in my build album
109" Project - Our Albums - Powered by Phanfare
A little more progress
ID:	118462 Click image for larger version
Originally Posted by pendy
I'm here for the D's
Old April 15th, 2015, 10:40 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Looks awesome man
Old April 15th, 2015, 10:55 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Wow - looking really good Charles!
Old May 3rd, 2015, 08:34 PM
I got some garage time this weekend and made some progress, although it took way longer than I would have thought (as usual). Someone didn't order new inner mud shields for the rear so I couldn't finish the rear outers (and need to rebuild my diffs anyway). Did some bushing prep and tapped the holes for a-arm ball joint. Hopefully it won't take too much longer to press in all the bushings and get these finished up and under the frame!
Rear housing. Didn't take any detail pics of the front, but had to clean the inside out as it was really dirty (didn't do so before powder coating).
ID:	119905 Click image for larger version
ID:	119906 Click image for larger version
ID:	119907 Click image for larger version
Rear hub. Hopefully the powder coat on the rotor mounting faces won't be an issue. I'll check the runout once the hub is on the stub axle.
ID:	119908 Click image for larger version
ID:	119909 Click image for larger version
ID:	119910 Click image for larger version
ID:	119917 Click image for larger version
ID:	119918 Click image for larger version
Front hub
ID:	119911 Click image for larger version
ID:	119912 Click image for larger version
Front stub
ID:	119913 Click image for larger version
ID:	119914 Click image for larger version
ID:	119916 Click image for larger version
ID:	119915 Click image for larger version
Current status
ID:	119924 Click image for larger version
Check out the grease I am using (what I had on the shelf). They had me at "irregular maintenance". LOL
Old May 4th, 2015, 09:26 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Looking awesome!!
Old May 5th, 2015, 03:50 PM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
Looks like progress, Charles. Nice job.
Old May 5th, 2015, 07:38 PM
That's a cheap kit from HF!
Yeah I figured I'd keep the ABS rings in case I want to use the wheel speed sensors. For now I'm going to just 3D print plugs and not install the sensors, but it will all be ready if/when I decide I want it.
Old May 5th, 2015, 09:02 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Ultra clean axle build!
Btw - got that piece out today in the post - you should see it in a couple days.
Old May 5th, 2015, 09:14 PM
Thanks Don!
Old May 25th, 2015, 03:32 PM
Finally got some time to work on the truck. I had started pressing in the a-arm ball joint a few weeks ago and broke my (ok, Loic's) little 12 ton press I have had in the garage for years.
ID:	121577 Click image for larger version
I decided was time for an upgrade and scored this 20 ton press on Mothers day with a 25% coupon!
Anyway things went well after that. Pro tip - clean out the bushing surfaces really well or you might struggle pressing in the bushes. The a-arm ball joint was the only one to give trouble but I think it's because it is solid and has no give, but if I were to do it again I'd clean most if not all of the galvy out of that hole. The rest went fine, although it could have been because of the new press.
ID:	121581 Click image for larger version
ID:	121582 Click image for larger version
ID:	121584 Click image for larger version
ID:	121585 Click image for larger version
I did the pan hard rod bushings too but forgot to take pictures.
Then I chased some more threads and put the rear stub axles and hubs on.
ID:	121587 Click image for larger version
ID:	121588 Click image for larger version
Oh and I bought these sweet thread finders which make it super easy to identify the thread and pitch on all the bolts I need to replace or get nuts for
Old May 31st, 2015, 12:32 AM
very nice!
Old May 31st, 2015, 02:09 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by cgalpin View Post
I need a 8mm and 10mm tap if anyone has one.
I have not followed your build... Good progress! is it fair to say you find those taps already? If not, I should have them.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 31st, 2015, 04:03 PM
Yeah I borrowed a tap set from Jeff. I have been able to do everything needed so far, although still have a few left to do.
Old June 7th, 2015, 08:30 PM
Not making a tremendous amount of progress, but I did manage to break a rivet tool and a 2 jaw puller today, so job done! I have acquired 24 spline axles (thats Randy) and diffs (thanks Carlos and Jeff) and have stripped the old diff bearings and pulled the old R&P. Once I get bearings I will rebuild them with 4.75 gears and get these axles under the frame. I'm 4 months in to what feels like should be a 4 week effort!
I did make some plugs for the ABS/speed sensor holes until I use them. Here is the front
ID:	122532 Click image for larger version
ID:	122533 Click image for larger version
ID:	122534 Click image for larger version
And then the rear. Note the screw hole to make it easy to pull them one day.
ID:	122535 Click image for larger version
ID:	122538 Click image for larger version
In case you were wondering they are not solid. I could make them solid, but to speed up printing and use less ABS I made them 25% internally.
Old June 7th, 2015, 09:20 PM
nicely done!
Old June 7th, 2015, 09:57 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Charles - do you have any more of those? Those look slick!
Old June 8th, 2015, 05:40 PM
The plugs? They are 3D printed, so I guess I have an endless supply of them. Need some?
Old June 8th, 2015, 07:24 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I am probably fine using the brake line brake bracket with sealant to keep gear oil in but those look so much nicer!
Old June 20th, 2015, 01:49 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Nice plugs. I made a plug then filled the holes with liquid electrical tape.
Legend in My Own Mind.
Old June 22nd, 2015, 09:21 PM
Some updates
On the plugs, it's easy if you have toys like a 3D printer, so why not. And in general I figure if you are going to bother doing something, you might as well do it right, or just don't bother.
I got held up on the axle build because I need to rebuild the diffs to continue, but before that I did finish mounting the swivel balls and setting the preload.
Fresh seals and bearings
ID:	123365 Click image for larger version
ID:	123366 Click image for larger version
I have one of these damping thingies on backwards. Need to figure out which one is right.
Checking the preload with a fish scale I picked up
And I manage to have lost one of these little bolts or I'd call this part done.
109, series
Brake options for my 109' IIA hybrid electric cgalpin Series Technical Discussions 13 July 30th, 2013 02:14 PM
1965 Land Rover Series IIa 109 Frame-up Restoration - $100,000 (Asheville, NC) rijosho The Flea Market 11 September 18th, 2011 01:58 PM
67 Series IIA 109 5 Door C-Delta For Sale - Vehicles 1 August 10th, 2006 02:40 AM
