1994 RRC LWB Daily Driver - Page 7 - Defender Source
Old December 19th, 2014, 11:33 AM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
Originally Posted by Kevin88RRC View Post
The center console or something else? I have grey center console from an '88 in ok condition minus the cubby & shifter boot. It's an auto but maybe a better starting point….
Yeah, the center console around the high/low selector as shown by nomar. I appreciate the offer but my interior is the brown color and I'll just take my time on it.
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old April 4th, 2015, 01:40 PM
Update:
Blew top hose in Januray while at the Bay. Fortunately only 2 miles from home, so I was able to refill the radiator with some ditch water and get back to the house.
Doesn't appear that any major engine damage was done before I shut it down.
Made repairs with some boat exhaust hose so that I could drive back to Kensington. Had next door neighbor take me into town for more coolant. Thankful that Walmart was open on sunday!
Still running that boat hose. Sooner or later I will have to take the intake off and get the hose situation sorted out with all new.
Futzed about with a few items today. The threads on the water pump flange were stripped so that the fan was on cockeyed and not very secure. I took a file to it while the engine was running and "lathed" off the bad threads by tapering it. That let me thread the fan on properly, so now that and the radiator shroud are back in place after the above incident.
I also wanted to install these LED reverse lamps. That of course engendered much in the way of messing with tail light lenses, captive nuts and plain old dirt. Did get them in and in the process had to temporarily remove the stupid guard thingys.
Can't shift the transfer case. I think the problem is the detent. It's a on-my-back job that I'm waiting for better weather for.
In addition the other fair weather chores like refitting the interior are still waiting for the ambition of your humble author to invigorate.
Old April 4th, 2015, 07:35 PM
Mtanzania
Frank
Lt-230 update
Since I asked you about doing this, I thought I would show you the result. I think it came out alright.
94 D1 300tdi - Sold
Old April 4th, 2015, 07:59 PM
Looks awful good
Old April 5th, 2015, 12:37 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Oh, man! That's looks killer! I really miss my manual transmission when driving the classic. My P38 feels normal as an auto, but the classic has that bit of je ne sais quoi that begs for a five speed like the 90! Very nice work! Factory, and then some. ;-)
Old April 5th, 2015, 07:30 AM
Mtanzania
Frank
Thanks. But here's the best part!
94 D1 300tdi - Sold
Old April 5th, 2015, 09:09 AM
Man I really really what to swap in an R380
Old May 5th, 2015, 10:35 AM
Latest issue is an intermittent power loss on rear window lift circuit. I suspect a bad lift ECU cz when I wiggle it sometimes the windows work. I pulled it open and I don't see anything like burned or broken so it may be a sticky relay in there. I should swap it with a known good one and see if that's the bug.
Old May 5th, 2015, 11:01 AM
It is always the same joint. Even if it does not look bad, resolder that joint.
Old May 5th, 2015, 12:29 PM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
That's odd, Bill. They worked great when we drove it up. Intermittent issues can be a pain, though.
Old May 5th, 2015, 02:03 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
What joint, Ron?
Damn, if my LWB rear windows started acting up....or else I just noticed it.
I never sit back there.
Rent my
Old May 5th, 2015, 07:00 PM
There is or was a picture on discoweb in the repairs or trail fix section or something. Not a post in a thread but the actual help section. It was always the same joint. I must have fixed a dozen of them.
here it is:
http://www.discoweb.org/window/index.htm
Old May 5th, 2015, 08:37 PM
Thanks ron, that link is for a '95. I'll go look at mine again maybe there's a bad solder joint on it.
Old May 5th, 2015, 09:04 PM
Looks like the problem is just plaiin old dirt. I took the board out of the plastic housng and plugged it in and it all works fine. Apparently there is some corrosion or what that is keeping the pins from making good contact. I'll clean more thoroughly at some point but for now it's all worky worky.
Old May 6th, 2015, 05:01 PM
Rover Lover
Ron Dade
97/D90 Soft Top
Dirt in that truck? Say it ain't so! Shoulda seen it when we picked it up. Dirt is the reason I ran out and bought contact cleaner when I couldn't get the seats to move. Glad it wasn't anything more.
Old May 6th, 2015, 05:09 PM
You remember it was coated with a monomolecular layer of Texas red clay. It infused into everything.
Old May 6th, 2015, 06:29 PM
Rover Lover
Ron Dade
97/D90 Soft Top
Now who would get 'infused' with mono_____?! Get it the old fashioned way....kissing girls!
Old May 7th, 2015, 07:56 PM
Headliner back in. Transformative.
Old May 8th, 2015, 03:06 PM
Rover Lover
Ron Dade
97/D90 Soft Top
Dude, you should have called me. I'd have happily helped. Did you recruit Sarah to help? I'll bet it really was transformative. However, I have fond memories of the bullfrog clips along the driver's side of the headliner! The rhythmic flopping of the fabric! I'm anxious to see how it turned out. Do you have all the interior back in now?
Old June 1st, 2015, 07:04 PM
AC now works and blows ice cold. Bad selector switch was allowing both heater and aircon fans to blow at the same time.
Added two cans of R 134a.
1994, lwb
Defender As Daily Driver D90DAILY Misc. Chit-Chat 35 November 8th, 2015 03:17 PM
D1 or RRC daily driver wanted bearskinrug Wanted 0 November 19th, 2012 01:46 PM
Daily driver RHD defenders from $12,000 landed east coast USA globallandrovers The Vendors Loft 5 April 15th, 2008 07:40 PM
Daily Driver/Off-Road Only/Garage Queen? Grover Misc. Chit-Chat 41 November 12th, 2007 12:09 AM
D90 - Daily Driver - Yes, No or Maybe? uzj100 Misc. Chit-Chat 31 July 26th, 2005 05:43 PM
