1990 RRC repairs - Page 3 - Defender Source
Join the Defender Source Community Today
Old August 30th, 2015, 06:29 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Originally Posted by Kevin88RRC View Post
I might have some in my bin if you want to try.
Can you PM or post a picture?
1990 Range Rover - being rebuilt
1995 Range Rover LWB - daily driver
Old September 1st, 2015, 08:52 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
ID:	128500Click image for larger version
Floor and part of the firewall is tacked in
Old September 13th, 2015, 12:29 AM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
I've been in NY, working, and was talking to my Dad about this project. Long story short, we were able to pick up the steel to become the frame mounts along with the rear-cross-member.
1. Should anyone need NY parts and/or pieces: Please text me.
2. This project is going to take a serious term once I'm back in the south! T-minus hours.
Old September 13th, 2015, 11:57 AM
Nice to see progress!
Originally Posted by pendy
I'm here for the D's
Old September 19th, 2015, 02:29 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
making progress!
ID:	130116   Click image for larger version
Old September 19th, 2015, 06:20 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
ID:	130154Click image for larger version
I bumped the jacks holding the front of the truck... Luckily nothing broke or snapped. For the first time in a year, the truck doesn't have a nasty lean
Old September 28th, 2015, 10:24 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Test fit the cross member tonight. I forgot about the frame when it was initially built but the adjustment was made quick with the angle grinder. I also discovered that the body mounts were not to be reused.
It still needs some tweaking but is coming together nicely. The worst is yet to come... Tailgate hinges.
My goal is to have the cross member finished and body resting on it by the end of the week.
Old October 30th, 2015, 11:27 AM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Rear cross-member is mounted and load-bearing. I installed temporary corners and bolted them to good metal on the body in order to hold everything up.
Tires on the passenger side of the truck are off so that I can install a piece of box-steel to connect the inner-body-mounts. I can't use the sill because there wouldn't be enough support for the rest of the body.
Making progress
ID:	133472   Click image for larger version
Old November 1st, 2015, 03:04 PM
I still think you are crazy, but congrats on the progress.
Old November 1st, 2015, 03:06 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Aren't you building a LR EV?
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old November 1st, 2015, 03:08 PM
Would it help if I said "crazier than me"?
Old November 1st, 2015, 03:11 PM
pl626's Avatar
pl626
Peter
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Old November 5th, 2015, 07:08 AM
applause!!
Old December 5th, 2015, 06:15 AM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Finally had a day to work on this some more. Wheel well and part of the floor are put in place. Most importantly is that the door open and closes fine and the tailgate still fitsClick image for larger version
Old December 5th, 2015, 08:03 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I have a lower tailgate you can have if you can get from Maine to your place. Also aluminum cargo floor with ghetto FP access hole cut into it and if your front is rusted out too, I have that from head light to head light from a southwest RR.
Parts truck will be gone sometime this week so let me know asap.
Old January 31st, 2016, 09:02 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Almost one full year later
Old February 7th, 2016, 08:57 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Cross members in place
Wheel wells welded in
Floor and tailgate fit
The list just keeps getting shorter
ID:	141832   Click image for larger version
Old February 7th, 2016, 10:59 PM
Go Patrick go
Old June 28th, 2016, 09:24 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Been a while since I updated this, but i'm still making progress. one step closer to getting it back on the road
Short List:
  • lower tailgate hinges
  • move old tailgate components over to the new
  • fix brakes - repair rear calipers, replace front rotors
  • seam seal everything
  • undercoat/paint everything
  • get the pass-front door back on
  • put seats back in
  • add oil to everything
  • new filters all around
ID:	152747   Click image for larger version
Old June 29th, 2016, 12:02 AM
pl626's Avatar
pl626
Peter
How are the axles? I just replaced all the seals on mine.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Off road 1990 RRC for sale draaronr For Sale - Vehicles 41 March 6th, 2014 02:01 PM
1990 RRC with some good mods. Not mine bitz The Flea Market 0 July 26th, 2010 10:03 PM
1990 RRC For Sale TXRover For Sale - Vehicles 0 May 17th, 2006 02:14 PM
1990 RRC Parting Out!!! harrellee For Sale - Vehicles 0 June 6th, 2005 11:04 PM
1990 RRC $3000 obo in So Cal kellymoe For Sale - Vehicles 2 December 2nd, 2004 11:14 PM
