1987 Restoration 90 - Page 3 - Defender Source
Old November 21st, 2014, 01:01 AM
RANGEROVERSURFER's Avatar
RANGEROVERSURFER
Tony
95/Range Rover Classic
Time well spent, I understand the desire to go thru each and every area that requires attention.
Great pictures and detail inspire me to chronicle my own progress with our 3 LR RRC SWB always something to do, extended members of our own Family..
Thank You, Keep up the build!
Tony
1995 RRC SWB Chawton White
1990 RRC SWB Eastnor Green
1990 RRC SWB Mettalic Blue
Old November 21st, 2014, 01:38 PM
seaswood
Diesel
Fixes
Fixing all the things I did not want to do you eventually have to do, go figure.
Starter is next
Old November 22nd, 2014, 09:24 AM
seaswood
Diesel
Repainted rear door this time both sides inside & out.
These can be cumbersome to hang properly the paint on the hinges took a beating.
The 110 PU that I started last year is continuing, axles first front is almost done then the rear axle bits. Once the 90 has a starter replaced I can I think consider it done for now & work on the 110.
Old May 13th, 2015, 10:45 AM
seaswood
Diesel
Rear windows
Someone had commented why the rear windows were painted.
Why do you buy a NAS version, because there is a chance it is correct.
When you buy a used X-Mod there is little chance it is done properly!
Maybe a better chance now.
This truck not likely thanks to Rover Special Vehicles hardly did anything right.
Anyways the top of the window was sealed with B-200 that stuff you use for parts not to be removed. & I just knew this window 's were are going to be a pain first one was.
Had to use a razor to get it off the side panel!
Old May 13th, 2015, 10:53 AM
seaswood
Diesel
Rear window
Garrison idea of the sheet helped keep the debris off the truck but definitely not as easy as the utube.
Old May 15th, 2015, 02:00 PM
seaswood
Diesel
Rear windows
The Left side had 28 rivets & the right side had 24 rivets came out easier.
Started stripping the paint old & new paint to bring it all back to Black paint.
Old June 23rd, 2015, 04:17 PM
seaswood
Diesel
rear windows
Managed to drill out screws fwd & rear of windows replaced with 6/32" x 1/4"
In process replacing all rubber bits, pillar with wiper.
Photos of rear stationary glass fitted for sizing.
When a good day shows up will paint frames Black & window surrounds.
ID:	123451   Click image for larger version
Old July 16th, 2015, 08:49 PM
seaswood
Diesel
Windows
Re paint again for rear windows
Old August 5th, 2015, 07:28 PM
seaswood
Diesel
Rear windows
Rear windows
MWC7612 the rear glazing strip or runner for the window fits into the frame fine but to get the glass to fit into the strip once it has snapped into place is not possible. So I installed everything together with sliding glass in the runner not snapped in. Now that the frame is together I can push snap the runner into place with glass, hopefully.
First the glazing rubber for the stationary window has to be installed MWC7617 around the window & installed into the frame. Then the center pillar MUC3770 is installed with rubber seal
MWC7615 in the pillar that holds the glass in place. To hold the pillar is a screw top & bottom, it is best to install the bottom screw first then use a good block & wooden mallet to set the rubber seal properly. Then fit the sliding glass with runner & fit the top of the frame installing the two screws on the fixed glass end of the frame. These screws I had to originally drill out replace with 3mm screws cut to fit the frame. This took some time to sort out cleaning painting etc.
the hard part was using the advanced technical method of wooden block & wooden mall a good heavy one at that. The pillar had to to be lined up to fit the top screw meaning fully seating the rubber glazing for the stationary window. This required a good amount of force with the frame situated on wood using a wooden block & mall. Will try to get pictures of this later.
This left the two screws on the other end of the frame to install once everything else is lined up properly. & yes I have used the original window runner & felt seal CZL000020.
The thought was to get everything back to Original first then down some road I could do the new Garrison if I wanted to.
Pictures of black frames in Black rubber seals with black glass are hard to show any fine detail as why I decided to write something first.
Old August 15th, 2015, 09:50 AM
seaswood
Diesel
Rear windows
I used a wooden mallet & wood to seat the rubber/glass together.
The seals plastic slide need encouragement.
Lots of heavy handed to seat everything
Old September 28th, 2015, 06:29 PM
seaswood
Diesel
Windows
Windows fitted although they appear to be fixed as they do not slide.
Old September 28th, 2015, 06:33 PM
seaswood
Diesel
Windows
This truck is done except for wiring heated wind screen & escape hatch next year.
90, restoration
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Electrical Issues & the best repair manuals for a 1995 D90 agavelvr Defender Technical Discussions 18 August 23rd, 2011 12:54 PM
1994 Defender 90 - Hardtop and A/C silver_defender For Sale - Vehicles 4 August 14th, 2009 03:31 PM
90 parts blowout Ren Ching For Sale - Parts 35 March 9th, 2009 12:39 PM
110 for sale(maybe) or my 90 mpsteil Misc. Chit-Chat 6 January 29th, 2009 10:43 PM
