1985 L/R 90 2.5 petrol into something Mo better - Page 10 - Defender Source
Old March 4th, 2010, 08:33 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Would the ones from a 97 disco be the wide or the narrow? I haven't measured yet, I'm just holding on to both(all 4 actually). I was hoping to do the bushing on the disco ones I have laying around, to save time when I swap them.
Old March 4th, 2010, 08:42 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
97 is wide
Tom, if you need some I have a spare set that you can have
Old March 4th, 2010, 10:22 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks for the offer Dave, but I have the 97 axle and arms from the Disco
Old June 25th, 2010, 04:10 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Aight, so a disco rear disc axle housing setup will swap right over to a 90. Anybody know about if it'll do it to a 110 with a sals rear end?
You little rebel, I like you.
Old June 25th, 2010, 08:51 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
You could swap it but the sals diff is wayyy stronger than the rover diff so you should keep the rear sals in there. If you want rotors instead of drums you can swap in new rotors.
Since you are in the UK you could also go to the breakers and buy a sals that will come with the rotors from the factory but I think either way you should keep the sals in a 110.
Itís pretty much a Dana 60 so it is strong and when / if you decide to buy gears or a locker you can use Dana 60 parts and save some money compared to rover stuff.
Old June 25th, 2010, 10:54 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I'm aware of the strengths of the sals. It's a 24 spline set-up from my 98 Disco with ARB GBR axles and 4.11s so I'm ok with swapping down from the sals. The idea is to just get the shit off the Disco and onto the 110 so I can completely scrap the remains of the Disco and then rebuild the sals into equivalent to the Disco set-up and have a toy to play with then have the remaining rear 24 spline to throw onto the 90 down the road for funsies.
Old June 25th, 2010, 02:37 PM
Since you have a 90, not a 110, the disco rear will bolt right up. To fit a 90 axle to a 110 (or vice versa) you need to account for the 1in extra diameter in 110 rear springs by moving the spring plate (drill a couple more holes and/or reposition captive nuts ie no big deal) and fitting the proper spring plate. You will have to use a shorter driveshaft with a sals than a rover rear axle due to pinion length.
Old June 28th, 2010, 03:04 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Word. Thanks for the input. Originally the stuff was going onto the 110, but it's received some dents on the front wing so it's going to become the offroader... onto the 90 the parts shall go.
Old August 1st, 2010, 10:27 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Cheapest/Best improvement yet. For all us Guys with the Older trucks, fell like your driving a much newer truck every time you look behind you!
Disco I rear-view Mirror!
Know if I only knew what the three wires were for?
Old August 2nd, 2010, 04:10 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Alright. Disco LHD front axle housing to a RHD 90. What was the verdict on ease and extra stuff I'll need. Deployed now but going to take this on when I get back and putting all the Disco goodies onto the 90.
Old August 2nd, 2010, 08:05 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
My truck is LHD so I can't help you, plus I've only done the rear so Far.
Stay Safe
Old August 2nd, 2010, 09:01 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Roger that. I'll report back later in August once I've figured it all out. Thanks.
Old October 5th, 2010, 08:34 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Actually taken off road
Finally got a chance to take the truck somewhere besides the beach. It wasn't MAR, but it was close to home.
Dog wasn't crazy about it though.
ID:	31860   Click image for larger version
Old October 6th, 2010, 06:55 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Is that Calverton path?
Truck looks great Tom!
Old October 6th, 2010, 08:25 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Its Montauk, at the end of the stretch. Up by the overlook.
Old November 20th, 2012, 08:26 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Re-Re Build
Bringing this back to life.
Trucks getting:
1997 frame I got from a friend
New Paint
Look, even pulling out all the windows to paint it!
Removed the Side windows and used the Garrison Oufitters deal (very nice)
Switching to TD5 style wipers
Bulkhead repair
Newer tub
ETC
ID:	61289   Click image for larger version
ID:	61291   Click image for larger version
Old December 4th, 2012, 12:03 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Frame is going to the galvanizer, finally listened to everyone. Still contemplateing the bulkhead.
Had a Fuel fill cut to match the NAS truck so it would work with my under seat tank. It would of been easy, but the tub had some bondo right in that spot.
Roof is getting painted
middle section is the color, 26173 semi gloss gray
ID:	62163   Click image for larger version
Old December 4th, 2012, 01:41 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Are you going to pull the alpine windows? Should only take a few mins
Old December 4th, 2012, 02:00 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Do they go back in easy?
Old December 4th, 2012, 02:09 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I have done it before. Not hard, not very easy either but the end result will look better if you are painting.
MUDSUX
2.5 petrol specific question mgreenspan Defender Technical Discussions 3 December 8th, 2009 04:19 PM
2.5 Petrol tomaco1 Defender Technical Discussions 3 August 19th, 2008 11:14 PM
2.5 Liter Petrol Power Steeering pump tomaco1 Defender Technical Discussions 0 April 16th, 2008 09:57 PM
285 75 16's with a 2.5 petrol tomaco1 Defender Technical Discussions 3 January 27th, 2008 11:49 PM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
