1966 Series IIA Rebuild - Page 4 - Defender Source
Old May 5th, 2012, 08:52 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Looks great. All very clean and and thorough. Inspiring...
Old May 14th, 2012, 01:33 AM
punter
1966 Series IIA
Uploaded soem more pics today...
Here are the photos of the front mud shield/brake hose bracket that I made, installed.
Then after that are some photos of the stainless steel brake lines (from the hose to the caliper) that I bent.
Name:	Front Mudshield Bracket 1.jpg
ID:	51537   Click image for larger version
Name:	Front Mudshield Bracket 2.jpg
Name:	Front Mudshield Bracket 3.jpg
ID:	51539   Click image for larger version
Name:	Front Mudshield Bracket 4.jpg
Name:	Front Mudshield Bracket 5.jpg
ID:	51541   Click image for larger version
Name:	Front Caliper Brakeline 1.jpg
Name:	Front Caliper Brakeline 2.jpg
ID:	51543   Click image for larger version
Name:	Front Caliper Brakeline 3.jpg
Name:	Front Caliper Brakeline 4.jpg
ID:	51545   Click image for larger version
Name:	Front Caliper Brakeline 5.jpg
Old May 14th, 2012, 01:40 AM
punter
1966 Series IIA
Even after the rear caliper brackets were machined, the rotors weren't perfectly centered inside the calipers. They weren't off by much... 1/100th of an inch here, 15/1000th of an inch there... Just enough to cause fit issues with the pads.
So I took some spare swivel ball pin shims and cut them down to create some shims for the calipers. Not as elegant of a solution as I would have liked, but it will do until I can figure out a way to make something better.
Here are some before and after pics as well as the cut down shims...
Name:	Rear Caliper Off Center 1.jpg
ID:	51547   Click image for larger version
Name:	Rear Caliper Off Center 2.jpg
Name:	Rear Caliper Shims.jpg
ID:	51549   Click image for larger version
Name:	Rear Caliper Shim Intallation.jpg
Name:	Rear Caliper On Center 1.jpg
ID:	51551   Click image for larger version
Name:	Rear Caliper On Center 2.jpg
Name:	Rear Caliper Pads In 1.jpg
ID:	51553   Click image for larger version
Name:	Rear Caliper Pads In 2.jpg
Old May 14th, 2012, 08:17 AM
Very impressive!
Originally Posted by pendy
I'm here for the D's
Old May 14th, 2012, 09:00 AM
You're kidding, right?
Old May 14th, 2012, 11:13 AM
punter
1966 Series IIA
Not kidding at all.
It was literally enough to cause a fit issue with the pads. I couldn't believe it either. Seems ridiculous to have to shim it down to that kind of accuracy, but I'd rather do that than have my brakes dragging until a sufficient amount of pad has worn off. In fact, in the case of one caliper, I had to shim the lower end 0.020 over... I couldn't even get one of the pads in until I did it.
Old May 14th, 2012, 04:29 PM
punter
1966 Series IIA
Upgraded the front axle shafts; so, I had to swap out the front Stub Axles, Hubs, and Drive Flanges to accommodate the higher spline count. Once I got everything together, I realized that the clearances weren't quite right and I couldn't get the circlips onto the axle shafts.
So, off came the drive flanges... I ended up removing about 2mm of material off of the face of the drive flanges so that I would be able to install the circlips and have some degree of end play.
Name:	Axle Shaft End Play 1.jpg
ID:	51600   Click image for larger version
Name:	Axle Shaft End Play 2.jpg
Name:	Axle Shaft End Play 3.jpg
ID:	51602   Click image for larger version
Name:	Axle Shaft End Play 4.jpg
Name:	Axle Shaft End Play 5.jpg
ID:	51604   Click image for larger version
Name:	Axle Shaft End Play 6.jpg
Name:	Axle Shaft End Play 7.jpg
ID:	51606   Click image for larger version
Name:	Axle Shaft End Play 9.jpg
Old May 14th, 2012, 04:33 PM
punter
1966 Series IIA
Started plumbing the rear brakes also...
Name:	Rear Axle Brake Lines 1.jpg
ID:	51608   Click image for larger version
Name:	Rear Axle Brake Lines 2.jpg
Name:	Rear Axle Brake Lines 3.jpg
ID:	51610   Click image for larger version
Name:	Rear Axle Brake Lines 4.jpg
Name:	Rear Axle Brake Lines 5.jpg
ID:	51612   Click image for larger version
Name:	Rear Axle Brake Lines 6.jpg
Name:	Rear Axle Brake Lines 7.jpg
ID:	51614   Click image for larger version
Name:	Rear Axle Brake Lines 8.jpg
rebuild, series
'71 Series IIa - $6,500 Winston-Rover For Sale - Vehicles 15 August 25th, 2009 12:43 PM
1967 Series IIa 95% rebuilt with Galvy chassis Dfndr90 For Sale - Vehicles 1 July 12th, 2007 01:27 PM
Series IIa short wheel base TDI Guy Wanted 3 August 12th, 2004 01:15 PM
Great looking Series IIA on EBay boshea Misc. Chit-Chat 3 April 24th, 2004 12:14 PM
