1966 Series IIA Rebuild - Page 2 - Defender Source
Old September 19th, 2010, 10:37 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
And that does not mean a cop will not write you a ticket or harass you for not having them as I found out with my 1955 M38A1 / CJ5
Old September 19th, 2010, 10:42 AM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
WOW. I never considered that...thanks Charles. Also, in regard to the wife comment, maybe all the more reason why Scott may not want to have seat belts. Scott, no insult intended here.
Dave, this is exactly why I want to know the facts surrounding the legalities of seat belts.
I started a new thread to take this seat belt topic off line.
Old October 5th, 2010, 03:55 PM
punter
1966 Series IIA
Yeah, they aren't required, but I intend to keep them anyway. I expect to have this truck for a long time and who knows what might be in the future in terms of kids and such. Best to be safe.
Old November 12th, 2010, 11:41 PM
punter
1966 Series IIA
I haven't been too good about taking photos of my progress lately... mainly because it's been a frustrating several weeks of dealing with parts that have been rusted together for decades. Needless to say the angle grinder, sawzall, and BFH have gotten a lot of use.
Here's a few pick of the axle tear down... over a half dozen broken bolts, and several more bolts that I had to cut and later extract (i.e. upper arm bushing bolts, radius arm bushing bolts). The spring seat mounts were pretty rotted out on the rear axle, as you can see in one of the pics... I ended up cutting them off and welding some 3/4" plate on in their place. I'll post some pics of that later.
Name:	fronty axle 1.jpg
ID:	32965   Click image for larger version
Name:	front axle 2.jpg
Name:	rear axle 1.jpg
ID:	32967   Click image for larger version
Name:	rear axle 2.jpg
Name:	rear axle 3.jpg
ID:	32969   Click image for larger version
Name:	rear axle 4.jpg
Name:	rear axle 5.jpg
ID:	32971   Click image for larger version
Name:	rear axle 6.jpg
Old November 12th, 2010, 11:54 PM
punter
1966 Series IIA
The leveling unit was the next big challenge... that entire assembly was/is completely seized together. After days of fighting with it, I decided to just pitch the entire leveling unit. A few minutes with the angle grinder and my truck lost a good 40 pounds.
I managed to get one of the upper arms off of the fulcrum bracket... the other one is still seized on there (all of which is soaking in the oil bath). The fulcrum ball joint took a few days with the angle grinder, sawzall, dremel, hammer and chisel... but I fianlly got it out.
Here's a few pics of the upper arms and what I had to do in order to extract the bushings and/or bolt sections. They were so rusted in there that nothing would free them... I let them soak in penetrating oil for weeks, I tried heat, I tried burning the rubber bushings out... nothing worked.
Finally, I grabbed the drill and a small bit and started drilling holes through the rubber bushing all around the center steel tube... kind of perferating it until I could get it out. Then it was another 20 minutes with a punch and a hammer to get the inner steel collar out.
Name:	Upper Arms 1.jpg
ID:	32973   Click image for larger version
Name:	Upper Arms 2.jpg
Name:	Upper Arms 3.jpg
ID:	32975   Click image for larger version
Name:	leveling unit 1.jpg
Name:	leveling unit 2.jpg
ID:	32977   Click image for larger version
Name:	leveling unit 3.jpg
Name:	leveling unit 4.jpg
Old November 13th, 2010, 12:09 AM
punter
1966 Series IIA
I put together a makeshift paint booth in the back yard, so I can start spraying the axles, steering and suspension parts.
I framed in an 8'X12' building on a concrete slab out back, encased the whole thing in 6mil plastic sheeting (doubling over and sealing all the seams), cut out an air intake and put some filters in it (yes I did realize that I put one in backwards and I did fix it before I started), cut out an exhaust and doubled the filters up on it with a big exhaust fan on the outside, threw together a few racks and I was good to go.
I've got pretty much all the axle, steering, and suspension parts painted now... just need to get the fulcrum bracket and upper arms apart, then disassemble the steering box, and I'll be ready for the last batch. All in all, the parts look great. A couple of small runs, (some of the angles were tough to shoot and I'm still pretty new at painting) but other than that... perfect. No dust, no orange peel, nothing. Just a nice even flat black finish (the parts are still wet in the photos, that's why they look glossy).
In the picture of the rear axle, you can kind of see those pieces of 3/4" steel that I welded on to replace the spring seat mounting brackets. I'll post a better picture when I start reassembly.
Name:	paint booth 1.jpg
ID:	32980   Click image for larger version
Name:	paint booth 2.jpg
Name:	painted parts 1.jpg
ID:	32982   Click image for larger version
Name:	painted parts 2.jpg
Name:	painted parts 3.jpg
ID:	32984   Click image for larger version
Name:	painted parts 4.jpg
Name:	painted parts 5.jpg
ID:	32986   Click image for larger version
Name:	painted parts 6.jpg
Name:	painted parts 7.jpg
ID:	32988   Click image for larger version
Name:	painted parts 8.jpg
Old November 17th, 2010, 10:50 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Damn Scott, seeing pictures of your axle rebuild brings back a lot of good, and bad, memories for me! I was lucky as most of my bolts came off without shearing. Looking good though.
MUDSUX
Old November 29th, 2010, 09:12 PM
punter
1966 Series IIA
Yeah, kinda hurt when I learned that those 4 bolts that secure the ball joint mounting bracket (where the upper arms connect to the rear axle) cost about $20.00 each ...and all four of them broke.
Just waiting for the last few parts to arrive (hopefully this week) and I can start putting it all back together. If all goes well, I'll have a rolling chassis for Chrstmas.
Old December 14th, 2010, 08:37 PM
punter
1966 Series IIA
Finally getting to the final build of the engine... it's been sitting here as more-or-less a long block for quite some time.
Unpacked the engine and did a quick layout of all the parts... then a test fit of most of the parts to make sure I had all the right hardware and so on.
I'll try to post some pics of the final build and finished product asap.
Name:	engine prep 1.jpg
ID:	33972   Click image for larger version
Name:	engine prep 2.jpg
Name:	engine prep 3.jpg
ID:	33974   Click image for larger version
Name:	engine test fit 2.jpg
Name:	engine test fit 3.jpg
Old December 14th, 2010, 09:10 PM
punter
1966 Series IIA
Forgot to get pictures of the axles as I got everything laid out and as they went together... but the suspension parts are all laid out now and I'll be sure to get some photos up of all that as it gets bolted in.
Name:	suspension prep 1.jpg
ID:	33977   Click image for larger version
Name:	suspension prep 2.jpg
Name:	suspension prep 3.jpg
Old December 15th, 2010, 12:39 AM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Oh, man. Sorry to hear about your galvanizing experience. If it's any consolation (and it's a bit late even if it is), I had my frame galvanized locally (acid dipped first) and those images you shared could easily be mistaken for my chassis. And we (mechanic and I) did a lot of prep work on the frame prior to galvanizing.
Good luck with the project. Please keep the updates and photos coming.
Old December 16th, 2010, 12:34 PM
LFORGUE8
Lucas Forgue
2011 Rangie
PUNTER......just a quick suggestion from my experience....i would use the coated intake gasket for sure instaed of spraying tacky sealant onto that metal gasket....imo
great top to bottom build by the way!
59 SII....on the back burner!
11 Rangie
Old December 19th, 2010, 01:26 PM
punter
1966 Series IIA
Where can you get them? ...I haven't seen anything other than this kind. You're talking about the Valley Pan, right?
,,,what's the bennefit? ...quieter? ...just easier to work with? ...or something else?
------ Follow up post added December 19th, 2010 01:33 PM ------
Yeah, the ash, drips, and runs I could have dealt with... that stuff can be sanded off without damaging the finish (it's just a lot of work).
My real issue was all the bad welds underneath the galvanization... and all the weld spatter underneath (can't sand that off... if you do, you'll breach the protective coating and then you've got patches of raw metal all over your nice new galvanized chassis.
Oh well... it's all cleaned up and powder coated now. The coater did a great job, too ...flawless finish. Really happy with it.
Old December 19th, 2010, 05:48 PM
LFORGUE8
Lucas Forgue
2011 Rangie
yes the valley pan quieter and i find seals better.....you can them from a dealer or AB and RN
11 Rangie
Old April 2nd, 2011, 07:42 PM
punter
1966 Series IIA
I got a little hung up with a short-notice move and haven’t had a chance to post anything in a long time. Ended up getting a new job out west, so I had to pack everything up and move over the holidays. The move couldn’t have come at a worse time (in terms of the rebuild)… EVERYTHING was in pieces.
With less than two weeks to have everything packed up and ready to go, I decided to enlist the help of some professionals. I really didn’t want to (as I wanted to complete this entire build all by myself), but there was no other way to get it rolling that fast.
First, I got a recommendation for a good engine builder, from one of the local hot rod shops and talked to him about finishing my engine build. I asked him to finish assembly, put it on a test stand, run it for the initial break-in, and tune it. I knew I wasn’t going to have time to touch it for a while and I didn’t want a fresh build to sit for months before it got run for the first time. Organized, boxed-up, labeled, and delivered everything that day.
Then, I asked around and found the ‘best 4X4 shop in the area.’ They agreed to build my axles and install the lockers. So, I laid out all the parts, boxed everything up, labeled the boxes, and dropped everything off. When I dropped off all the parts, I made sure to show them what I was dropping off, how everything was organized, and told them that if anything is missing to give me a call, it’s probably just sitting on a shelf in my garage. I gave them all of the manuals and support materials as well. I don’t think the mechanics paid attention to a work I said. “yeah, it’s basically just a Dana 60 and a Toyota-type axle… built hundreds of them, not a problem.”
About a week later the first call came. “You’re missing two seals for your rear axle, the special bearing that comes with your rear locker isn’t there, and your front locker won’t fit in your differential housing… you got the wrong one”
Seals… got ‘em, forgot to put them in the box, my bad. Dropped them off within the hour along with every spare seal, gasket, and bearing that I had in my garage. Special bearing? …if it’s not in the box, I never got it. Wrong locker? …doubt it. So I called Keith over at Rover Tracks; he had set me up with everything and I figured that if anyone would know what was going wrong, he would.
Keith was awesome… he spoke with the mechanics, and then jumped through his @** to get the ‘special bearing’ overnighted to the shop as well as track down another differential housing and have it overnighted to the shop too.
A day or two later, I get another call, “You’re missing some sort of spacer from your rear hubs, or your hubs are wrong. There’s all kinds of play (in-out).”
[Note: I’m converting the rear drum breaks to disk, and the front axles to 24 spline.]
I was at their shop within two hours with every hub, stub axle, and drive flange I had, to see what we could do. We ended up putting my old fronts on the rear and the problem was solved.
A couple days later the third call came, “Your axles are done, you can pick ‘em up whenever you want.”
So, I head down to their shop, totally stoked… all the BS from the previous days forgotten… just completely jazzed that my axles are done and I can get my chassis up on wheels. When I get there, I see my rear axle build up with rusty old hubs (I hadn’t painted my old fronts as I had not intended to use them), just as I had expected. What I didn’t see was my front built up with a rusty old differential housing, as I had expected (I assumed the one Keith had sent would’ve been unfinished).
“No, that’s your differential housing, not the one that he sent… turns out yours was the right one. We just had the wrong bearing in it and that’s why it didn’t fit right.”
So, just as I thought, Keith was spot on with the Locker he sold me… these guys are just complete tools! Maybe if they took the bearing out of the box marked front differential, they wouldn’t have had that problem.
Then I notice that the drive flanges had not been installed on the front hubs. “Oh, yeah, those hubs don’t fit on there right… the lock nuts are only on by like one or two threads. It can’t run like that… but it’ll roll and you can at least get it up on your trailer for the move.”
So, now I’m pissed off to the point that I don’t even want to open my mouth, because I know I’m not going to be able to control what comes out of it. We load the axles and several boxes of (I assume) old parts into my truck. I pay my bill, which was of course almost 50% more than they had quoted, and they go on to pat themselves on the back for a job well done, “yeah man, in the 4X4 world, that Land Rover stuff is some ninja $h**.”
I get everything home and download my truck. As I start unpacking all the boxes of parts, I see that there are all kinds of new seals, bearings, and gaskets in there. There should have only been a couple seals and a few bearing sets (that I knew were extra). This probably explains why the front hubs aren’t seating correctly… they probably used the wrong bearings. Of course, I also realize that I have no idea what they replaced, what they didn’t, what was done correctly, or what was not.
Now, I get to disassemble and rebuild my ‘professionally built’ axles. Now, I did want to do this build all by myself… so, I guess there is an upside to all this… of course, then there is the $1500.00 I pissed away on nothing.
So, then I’ve got to go out west for about 5 days to in-process at me new job (just before the holidays). While I’m out there, I realize that I hadn’t heard from the engine builder yet. I give him a call and he tells me, “Oh, yeah, I haven’t gotten around to starting that yet.”
I remind him that he told me he’d have it done a week ago and ask him if he can have it built, test run, and tuned before the holidays. His response was something to the effects of, “I might be able to get it together, but there’s no way I can get it installed in your vehicle, run it and tune it by Christmas.”
Not sure how many of you picked up on that part… who the h*!! said anything about putting it in my truck? So, he goes on to explain that he has no test stand and he didn’t understand what I was asking him to do. “Don’t touch anything, don’t unpack anything, I’ll be by on the 23rd to pick it up.”
Needless to say, the engine was moved in pieces. Christmas Eve and Christmas Day were spent putting the axles and suspension on the chassis. The following days were spent dropping the body back on the chassis, loading it on my trailer for the move and getting everything else packed up. The New Year and following couple of days were spent driving across the country.
Here’s a few pics…
ID:	37532   Click image for larger version
Name:	front axle in.jpg
Name:	front axle in 2.jpg
ID:	37534   Click image for larger version
Name:	rear axle in.jpg
ID:	37536   Click image for larger version
Name:	upper links.jpg
Name:	upper links in.jpg
ID:	37538   Click image for larger version
Name:	upper link in 2.jpg
Old April 2nd, 2011, 07:49 PM
punter
1966 Series IIA
Moral of this story... whenever possible just do it yourself. If you screw it up, you've got no one to be mad at but yourself.
Special thanks to Keith at Rover Tracks for all his help.
Here's a couple more pics...
ID:	37540   Click image for larger version
Old April 2nd, 2011, 07:51 PM
punter
1966 Series IIA
almost forgot... the other kicker to all this is that the rear differential doesn't even hold oil. Still gotta take a look and see, but i'm betting that they didn't even put the gasket in when they put the cover on.
Old April 2nd, 2011, 07:53 PM
punter
1966 Series IIA
So, after that ordeal... made the move, got unpacked, set up the garage, and finally got a chance to start working on the truck.
The garage door is a bit shorter than at my old place, so I had to take the roof off to get it inside... then I was able to eek it in with about 3/4 an inch of clearance.
Interior is out (except the front seats... they're supporting the bulkhead for the time being), roof is off, doors are off and the dash is coming out next. If all goes well, by the end of the weekend the entire body will be disassembled and off of the chassis.
Here's a few pics...
ID:	37542   Click image for larger version
Name:	door clearance.jpg
Old April 3rd, 2011, 07:40 PM
punter
1966 Series IIA
Got a bit more work done today...
ID:	37573   Click image for larger version
Name:	steering wheel out.jpg
Old April 4th, 2011, 09:56 AM
love those valve covers.
rebuild, series
'71 Series IIa - $6,500 Winston-Rover For Sale - Vehicles 15 August 25th, 2009 12:43 PM
1967 Series IIa 95% rebuilt with Galvy chassis Dfndr90 For Sale - Vehicles 1 July 12th, 2007 01:27 PM
Series IIa short wheel base TDI Guy Wanted 3 August 12th, 2004 01:15 PM
Great looking Series IIA on EBay boshea Misc. Chit-Chat 3 April 24th, 2004 12:14 PM
