1965 Series 2a - Page 3 - Defender Source
Old December 23rd, 2013, 08:16 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by o2batsea View Post
What are you priming with on bare aluminum?
Consider the source... it is a trick question. Don't answer it!
Looking great, Craig. Thinking we all have progress envy as well.
Old December 23rd, 2013, 07:52 PM
87 D110 (Ruby)
A self etching primer - but there isn't a lot of bare - most of it still has that yellow stuff from the factory if the paint is gone - over painted surface i use a normal metal filler primer -
Old January 1st, 2014, 12:30 PM
87 D110 (Ruby)
A question for the officianados (aka Bill) - I have a bunch of "holes" in the aluminium everywhere - do I fill them with stainless nuts-n-bolts or screws, or with grommets, or with plugs?
What is the preferred method?
Obviously the ones required to pass wires through will be grommets...but there are some that don't have any function - most had nuts-n-bolts in them. If I stay that course should I paint the nut-n-bolts too?
Old January 1st, 2014, 12:37 PM
Call me. I am at work and it's so dead here.
Old January 1st, 2014, 01:48 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Looking good.
Mike Hammond
Old January 1st, 2014, 01:56 PM
JohnBullsBollocks's Avatar
JohnBullsBollocks
Don
1963 IIA 109
TIG welding is your friend!
TIG welding is your friend! Grind down and smooth with a D/A. Alternatively, I have found that ACE hardware carries an AMAZING supply of stainless fasteners, grommets and goof plugs.
Old January 1st, 2014, 10:12 PM
87 D110 (Ruby)
Thanks fellas. And thanks for the call Bill. I have some work to do....all good.
Old January 4th, 2014, 06:08 PM
87 D110 (Ruby)
well I braved the cold today in the garage...actually used the propane blower heater to make it bearable.
Worked on the doors, they are now done and prepped - now I need to get new window tracks and trim for them.
Getting held up now, as I need to paint it. With this cold I have to wait for some nicer - above 50deg days - weather so I can open the garage doors and blow it out as I paint. I have probably killed some brain cells with the priming I have done
Old January 6th, 2014, 02:53 PM
87 D110 (Ruby)
Alrighty - 10cans of APSTowers premixed 1K paint on their way. now...bloody weather needs to cooperate or the wife will kill me for stinking up the garage!!
Old January 12th, 2014, 08:35 PM
87 D110 (Ruby)
Extremely lucky that the weather cooperated enough that a little propane heat in the garage helped to enable me to paint. Now the interior is done! VERY happy with the results. I now have to get all the rubber/gaskets etc and then put it all together.
Long pole in the tent is the Rocky Mountain Parabolics kit (shocks, straps, ubolts etc) - then the biggie....the rear crossmember.
I am going to wait until spring for the xmember though....so I hope to have it at Feb Happy Hour...albeit the exterior will be rockin in primer until I hit up Maaco or Earl Shieb!
Sorry - bad pictures...better ones to come.
ID:	87783   Click image for larger version
Old January 12th, 2014, 10:00 PM
skupetz
Gustaf Kupetz
NAS110, HCPU, Disco, Toylander, 2
Looking good!
Old January 13th, 2014, 10:57 AM
I tig welded all my holes closed.
Looks good, Craig! You are moving so fast it's great!
Old January 16th, 2014, 08:49 AM
The Dro
Dro
1988 Ninety
Dam Jonesy... You are putting all of us to shame... Good Job!
Hopefully in 10 years I'll get this done to my truck. HA!
Old January 17th, 2014, 07:19 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Great work!
Old January 18th, 2014, 10:24 AM
87 D110 (Ruby)
I thought I should upload a few more pics...I have the sides on, roof goes on today. I am waiting for some parts from the UK, RovaFarm, AB & RN.
To Do:
1) Power booster - servo and master cylinder for disc brakes
2) replace all rubber boots, grommets, hoses etc
3) refit floor, tunnels, seat box
4) refinish seat rails and reattach
5) redo sills and spray
6) restore wings - both of them require it inside & out
7) fit new (refurbed) window wiper units
8) redo lights ensure all markers etc work
9) refit wings
10) details details details...
11) drive it to Feb Happy Hour - I hope!!!!!
ID:	88060   Click image for larger version
ID:	88062   Click image for larger version
Old January 18th, 2014, 11:49 AM
Looking good. I nearly called you earlier as I had to run out to get welding gas, but the Leesburg TS didn't have any so I ended up going to Warrenton.
Originally Posted by pendy
I'm here for the D's
Old January 18th, 2014, 12:30 PM
87 D110 (Ruby)
should have called dummy - I had a bottle of Argon
Roof is on. LOVE the Zebra pattern headliner - it's got bling
Old January 18th, 2014, 01:07 PM
Well, I needed 100% Argon (TIG) and since I'm borrowing Ed's rig, the least I can do is get him more gas!
Old January 19th, 2014, 01:58 PM
87 D110 (Ruby)
OK - now I gotta take a break - BRONCO'S vs the Brady Bunch in an hour and a half - gotta make the wings!
So, all is ready to be bolted in - just gotta get the floor kit from Trevor as the PO threw all the hardware away?? Seat box is secure, all other panels are just sitting there...waiting.
Sure is a complete PITA to refit stuff and not scratch the nice new paint job!
ID:	88144   Click image for larger version
Old January 20th, 2014, 09:46 AM
Awesome. I hope the second picture is the more recent one because in the first you have the tunnel under the front piece and that's not right. The second one looks spot on.
1965 V8 Series 2a RoverLover5023 For Sale - Vehicles 0 August 7th, 2012 10:37 PM
1965 Series 2a. RoverLover5023 For Sale - Vehicles 1 July 18th, 2012 10:10 PM
series 2a land rover parts ron The Flea Market 0 December 20th, 2011 03:12 PM
1965 Land Rover Series IIa 109 Frame-up Restoration - $100,000 (Asheville, NC) rijosho The Flea Market 11 September 18th, 2011 01:58 PM
